I’m trying to enable PWM and some GPIOs on the Beaglebone and I’m running into various problems.
Originally I tried to start PWM using the /sys/class/pwm/pwmchip1/export interface, but ran into a bunch of race conditions. I then tried using the Adafruit_BBIO.PWM library, which works around most of the race conditions (but still sometimes fails nonrepeatably). (I also tried writing the PWM registers directly, but there are a lot of them and I couldn’t find documentation on which ones are needed, so I figure I’m better off using the device drivers.)
But the Adafruit_BBIO library depends on using cape_universal, which configures some pins in ways that conflict with what I want in my dts file.
So my questions are:
a) Is there a simple, reliable way of enabling PWM?
b) Is there a way of overriding some cape_universal pin assignments? Or getting cape_universal to assign them the way I want? Or configuring the ocp:Px_xx_pinmux/state files that the Adafruit library needs without using cape_universal?
I can post my dts files and so forth, but I suspect that I need to change my approach entirely.
Ken
P.S. By “race conditions”, I mean that if I write to /sys/class/pwm/pwmchip1/export, and then try to write to /sys/class/pwm/pwm-1:0, sometimes the latter file isn’t there and I need to wait. But even sleeping a bit isn’t always enough. The Adafruit library has code to deal with this as well as various other situations, but even that code fails randomly about 20% of the time.
The answers are:
a) The simple and reliable way to enable PWM is using libpruio.
b) With libpruio you won’t need cape_universal at all (Adafruit library is also needless). But if you want to use cape_universal by any reason, then libpruio can override all its configurations in order to get you what you need.
libpruio can configure the PWM subsystems while the output is stopped, and afterwards start all subsystems synchronously by a single function call. It’s also possible to chain up (synchronize) the PWM output between multiple PWM subsystems.
… but I suspect that I need to change my approach entirely.
A good, but late brainchild. I proposed libpruio before you started your approach.
