I want to use the pins on my BeagleBoneBlack for UART. I tried configuring UART1 as such using the command -
sudo config-pin P9.24 uart
sudo config-pin P9.26 uart
but was hit with this error -
cape-universal overlay not found
run "config-pin overlay cape-universal" to load the cape
On running the command config-pin overlay cape-universal as per the suggestion, I got -
Loading cape-universal overlay
bash: line 0: echo: write error: File exists
Error loading device tree overlay file: cape-universal
I am running off of a custom image on an SD card, whose uEnv.txt looks like the following -
##Video: Uncomment to override:
##see: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/fb/modedb.txt
#kms_force_mode=video=HDMI-A-1:1024x768@60e
##Enable systemd
systemd=quiet init=/lib/systemd/systemd
##BeagleBone Cape Overrides
optargs=capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART3,BB-UART4
##BeagleBone Black:
##Disable HDMI/eMMC
#optargs=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-BONE-EMMC-2G
##Disable HDMI
##WIP: v3.13+ capes..
#cape=lcd4-01
#cape=
##note: the eMMC flasher script relies on the next line
mmcroot=/dev/mmcblk0p2 ro
mmcrootfstype=ext4 rootwait fixrtc
##These are needed to be compliant with Angstrom's 2013.06.20 u-boot.
console=ttyO0,115200n8
kernel_file=zImage
initrd_file=initrd.img
loadaddr=0x82000000
initrd_addr=0x88080000
fdtaddr=0x88000000
initrd_high=0xffffffff
fdt_high=0xffffffff
loadkernel=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${kernel_file}
loadinitrd=load mmc ${mmcdev}:${mmcpart} ${initrd_addr} ${initrd_file}; setenv initrd_size ${filesize}
loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} /dtbs/${fdtfile}
loadfiles=run loadkernel; run loadinitrd; run loadfdt
mmcargs=setenv bootargs console=tty0 console=${console} ${optargs} ${kms_force_mode} root=${mmcroot} rootfstype=${mmcrootfstype} ${systemd}
uenvcmd=run loadfiles; run mmcargs; bootz ${loadaddr} ${initrd_addr}:${initrd_size} ${fdtaddr}
##USB Boot problem
uhci-hcd.ignore_oc=y
Also, I just checked that my /sys/devices/bone_capemgr.9 file looks like the following -
0: 54:PF---
1: 55:PF---
2: 56:PF---
3: 57:PF---
4: ff:P-O-L Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G
5: ff:P-O-L Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI
7: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-UART1
8: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-UART2
10: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-UART4
What do I have to change to get it to work? Thanks
