Hello!
I try to create a Kernel driver which uses the DMTimer capture mode to catch triggers on the GPIO of the timer. Therefore I use timer4 PIN (P8.7). For this driver I basicly use the Code of Dan Drowns pps-gmtimer [1].
In the initialization of the timer I changed the catch mode from OMAP_TIMER_CTRL_TCM_LOWTOHIGH to OMAP_TIMER_CTRL_TCM_BOTHEDGES:
ctrl = __omap_dm_timer_read(timer, OMAP_TIMER_CTRL_REG, timer->posted);
ctrl &= ~(OMAP_TIMER_CTRL_PRE | (0x07 << 2));
ctrl |= OMAP_TIMER_CTRL_AR;
__omap_dm_timer_write(timer, OMAP_TIMER_LOAD_REG, 0, timer->posted);
ctrl |= OMAP_TIMER_CTRL_ST | OMAP_TIMER_CTRL_TCM_BOTHEDGES | OMAP_TIMER_CTRL_GPOCFG;
__omap_dm_timer_load_start(timer, ctrl, 0, timer->posted);
In the interrupt routine I also want to save the edge of the trigger. My first question: Does the DMTimer somehow save the trigger reason? In the documentation of the Sitara AM335x I can’t find any register of the DMTimer where this might be stored.
For now I put the signal also to another GPIO and read out the value of that GPIO at the timer the interrupt happens. But I think I might miss a edge.
Another way of distiguishing the edges I thought of was to set the trigger to “OMAP_TIMER_CTRL_TCM_LOWTOHIGH” first and then to reconfigure it to “OMAP_TIMER_CTRL_TCM_HIGHTOLOW” (or vice versa) in the interrupt routine. My second and third question: Is this possible? And: Can I keep the timer value if I do that?
Thanks for the help,
Christoph
