CD40109B and Logic Level Translation/Beagleboard Boards and SBCs...
Hey There,
I was wanting to use the CD40109B for logic level translation and was trying to get some feedback on this specific chip.
Has anyone used this chip for translating logic and/or using it to handle the Pocket Beagle 2 for unidirectional serial communication? Also, if you have used it and other types of chips for translation, what would you recommend for bidirectional translation?
There are many chips to choose. I am sort of getting some background on what would work best with serial/GPIO communication and motors (DC and/or Stepper).
used
TXS0102D and
TXS0108E
for serial, i2c and gpio, no external pullups needed.
As you can see from the datasheet, the CD40109B is a part from a pre-3.3V era,
and I suspect that’s why it hasn’t been characterized for lower-than 5V operation.
While I won’t go as far as to say it can’t be done ever, I’d be very careful
around any 3.3V devices. Thorough investigation would be prudent.
As for the TXB / TXS lines, make sure you get the right one for your application.
In general, I’m not crazy in love with those auto-bidi style devices,
but as always, your application will be the determinator.
Thank you both for the heads up on this “outcome.”
I have taken prior consideration and @lranders , I was surprised by what you typed. I really thought the CD40109B handled 3.3v CMOS operation bi and unidirectional. I will research the datasheet again. Thank you.
And to @amf99 , thank you. I will go off and look for a replacement to the current purchased components. I will look at the TXS0108E and TXS0102D for translating. Hopefully, they have the PDIP package available.
In any light, we can call this cased closed. Thank you.
Dang it. A-Okay. I see they have breakout boards already mfg. for this TI part.
It is too bad the PDIP does not exist for those two parts. I will just go with the flow and NOT build my own for whatever reason.
PDIPS are old school, outdated. i’ve moved on to SMT. not ready for BGA devices.
I do not find too many BGA breakouts around for placing them in the sockets…
The main thing about PDIP is that they bug me. Yes. They are flimsy and prone to breaking on the first placement.
Secondly, I do not mind making from “scratch” to have a variety of builds available (hence the PDIP set ups).
@amf99 , my soldering skills are still weak now. SMT and SMD is over my payscale still. I have watched endless videos on it. Watched the high technology placement of solder one pin and then mask the rest with paste to finally heat it all.
Wash and whalla. But, I am just not ready.
Hey and this is just an update for those of us who perform simpler tasks… ME!
I found that sparkfun had some for about $5.00. I thought it was “modest…” Blah.
