Looking at your reply does this mean that CDCETHER is enabled in my kernel version (assuming you are saying it is in there as I see =y)? Is CDC_ETHER and CDCETHER the same thing?
If it is, why would I not see the device?
The document for the module I am looking claims that it will simply appear when connected on boot in Debian 8.3 (kernel 4.1.15) but is not supported in Debian 7.x (kernel 3.8.x)
lsusb
Bus 001 Device 004: ID 1e2d:00a0
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Still working on this and really not sure what my next step is.
When I plug the module into both my old device running 3.8 and now a new device (just compiled 4.1.21-bone-rt-r20) I do am not getting a connection. Tailing the syslog it gets up the poingt of declaring it ttyACM0: USB ACM device but then nothing happens:
[12990.725461] cdc_ether 1-1:1.0 usb0: unregister ‘cdc_ether’ usb-musb-hdrc.1.auto-1, CDC Ethernet Device
Apr 20 21:28:05 arm kernel: [12990.719975] usb 1-1: USB disconnect, device number 4
Apr 20 21:28:05 arm kernel: [12990.725461] cdc_ether 1-1:1.0 usb0: unregister ‘cdc_ether’ usb-musb-hdrc.1.auto-1, CDC Ethernet Device
[12993.532521] usb 1-1: new high-speed USB device number 6 using musb-hdrc
Apr 20 21:28:08 arm kernel: [12993.532521] usb 1-1: new high-speed USB device number 6 using musb-hdrc
[12993.823315] usb 1-1: New USB device found, idVendor=1e2d, idProduct=00a0
[12993.830122] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12993.837381] usb 1-1: Product: SQN
[12993.840731] usb 1-1: Manufacturer: Sequans Communications
[12993.846221] usb 1-1: SerialNumber: 700400708002
Apr 20 21:28:08 arm kernel: [12993.823315] usb 1-1: New USB device found, idVendor=1e2d, idProduct=00a0
Apr 20 21:28:08 arm kernel: [12993.830122] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 20 21:28:08 arm kernel: [12993.837381] usb 1-1: Product: SQN
Apr 20 21:28:08 arm kernel: [12993.840731] usb 1-1: Manufacturer: Sequans Communications
Apr 20 21:28:08 arm kernel: [12993.846221] usb 1-1: SerialNumber: 700400708002
[12993.922298] cdc_ether 1-1:1.0 usb0: register ‘cdc_ether’ at usb-musb-hdrc.1.auto-1, CDC Ethernet Device, 02:80:70:00:04:70
[12993.942669] cdc_acm 1-1:1.2: ttyACM0: USB ACM device
I have also now taken this module and plugged it hot into my dev desktop computer running ubuntu ( 3.16.0-70-generic #90~14.04.1-Ubuntu ) and it just fires up all the way! Auto detects and I instantly have an established connection thru the module.
I attached my syslog from when I did this and you see much more going on after ~ line 11 where we have the same ttyACM0: USB ACM device.
Do you know how a cdc_ether device works ? Because according to the text you’ve got there, and the output from dmesg, you should be able to run sudo ifconfig, and see it listed.
