NB-IoT is sadly not in scope because the carriers still have full cranio-rectal impaction.
I have had several cases where fleets of NB-IoT devices simply went dead because the carrier did an upgrade. If you don’t have a way to do out of band firmware upgrades, the carriers will hose you at some point.
That’s why I’m looking for a bog-standard cellular modem that uses the same infrastructure as normal phones.
I’ve had great experiences with Nimbelink. If you are in the US, their modems are end-device certified on Verizon and other networks. Currently using the Nimbelink Quectel Cat-M BG96 module on Verizon. I think the BG96 is no longer available, so they recommend the BG95 version as a replacement.
The BG96 has performed very well, is reliable, and seems to work well on VZ networks. I’ve not run into any issues that required modem FW upgrades like I did with the u-blox Cat-M modem.
I’ve also been working on modem management software:
(currently BG96, but should be adaptable to other modems)
This is used on several projects and will be integrated into the simpleiot binary releases soon.
