Change Device Tree Beaglebone Black
I’m attempting to learn about the device tree. I am starting by just modifying my existing device tree. In this case that’s here in the kernel-source directory
tmp/work-shared/beaglebone-yocto/kernel-source/arch/arm/boot/dts/am335x-bone-common.dtsi. I added this to the am33xx_pinmux section
&am33xx_pinmux {
pinctrl-names = “default”;
pinctrl-0 = <&clkout2_pin>;
    ui_button_pins: ui_button_pins {
            pinctrl-singl,pins = <
                    AM33XX_PADCONF(AM335X_PIN_GPMC_A1, PIN_OUTPUT, MUX_MODE7)/* (U13) gpmc_a1.gpio1_17 */
                    AM33XX_PADCONF(AM335X_PIN_GPMC_AD10, PIN_OUTPUT, MUX_MODE7)/* (U13) gpmc_a1.gpio0_26 */
                    AM33XX_PADCONF(AM335X_PIN_GPMC_AD14, PIN_OUTPUT, MUX_MODE7)/* (U13) gpmc_a1.gpio1_14 */
                    AM33XX_PADCONF(AM335X_PIN_MCASP0_FSR, PIN_OUTPUT, MUX_MODE7)/* (U13) MCASP0_FSR.gpio3_19 */
I’m expecting to see a change in root@beaglebone-yocto:/sys/kernel/debug/pinctrl/44e10800.pinmux-pinctrl-single
but I do not. What am I missing?
You are only declaring the pin mux but not instantiating it.
In
You need to add your pinmux after clkout2_pin. Separate by a space
I’m not sure what my pinmux is?
^ that… :wink:
pinctrl-0 = <&clkout2_pin &ui_button_pins>;
thanks @benedict.hewson @RobertCNelson that did it
