Checking battery status or charge available in the battery in BBBL
I have connected my LIPO battery to my BBBL. I would like to know the charge lever in my battery. Is that feature available in BBL?
I have checked in /sys/class/power_supply
noting I found, any driver I need to attach ?
And battery_monitor.service is running fine.
Thanks in advance.
Jeshwanth,
You can approximate battery SOC from resting voltage, see the following links for the extended discussion:
https://www.rcgroups.com/forums/showthread.php?956764-LiPoly-Capacity-versus-open-voltage
http://www.helifreak.com/showthread.php?t=333661
The BBBL battery per-cell voltage is available with rc_check_battery
Adam
