Hi folks,
I got a 4 GB SD-card that does work well with my BeagleBoard xM, see attachment “BeagleBoard booting SuSE on 4GB-SD ok.txt“. I cloned that card just to have a backup if that card gets corrupted one day. I did so using dd and ended up with a clone that boots just a bit. Booting the clone fails as soon as disc mmc-00000_0x0f4de006-part2 has to bee mounted, see attachment “BeagleBoard booting SuSE on 8GB-SD fails.txt”.
I don’t have the slightest idea what is going wrong. The original 4 GB works just fine but the same image cloned / transferred to an 8 GB card (that should easily do) fails?! Could anybody help me out with just an idea what do to or where to search?
Beat regards
Christian
fdisk -l /dev/sdc
Platte /dev/sdc: 3974 MByte, 3974103040 Byte
255 Köpfe, 63 Sektoren/Spur, 483 Zylinder, zusammen 7761920 Sektoren
Einheiten = Sektoren von 1 × 512 = 512 Bytes
Disk identifier: 0x64c9641e
Gerät boot. Anfang Ende Blöcke Id System
/dev/sdc1 * 2048 411655 204804 83 Linux
/dev/sdc2 411656 6731235 3159790 83 Linux
/dev/sdc3 6731240 7759394 514077+ 82 Linux Swap / Solaris
OMAP SD/MMC: 0
U-Boot 2013.04-rc2 (Apr 17 2013 - 07:41:39)
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #452000029ff800000168580217028015
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 1.800
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 480ab000 using PIO, IRQ 0
Net: usb_ether
mmc0 is current device
gpio: pin 173 (gpio 173) value is 0
gpio: pin 4 (gpio 4) value is 0
SD/MMC found on device 0
** File not found uEnv.txt **
1516 bytes read in 9 ms (164.1 KiB/s)
Running bootscript from mmc0 …
Executing script at 80200000
kerneladdr=0x80200000
ramdiskaddr=0x81000000
4242872 bytes read in 338 ms (12 MiB/s)
4351196 bytes read in 333 ms (12.5 MiB/s)
Booting kernel from Legacy Image at 80200000 …
Image Name: Linux-3.7.10-1.16-omap2plus
Data Size: 4242808 Bytes = 4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading init Ramdisk from Legacy Image at 81000000 …
Image Name: Initrd
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 4351132 Bytes = 4.1 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image … OK
OK
Starting kernel …
// many lines cut off here
Boot logging started on /dev/ttyO2(/dev/console) at Mon Sep 2 02:00:05 2013
Waiting for device /dev/disk/by-id/mmc-00000_0x0f4de006-part2 to appear: ok
fsck from util-linux 2.21.2
[/sbin/fsck.ext4 (1) – /] fsck.ext4 -a /dev/mmcblk0p2
/dev/mmcblk0p2: clean, 24847/195200 files, 188497/789947 blocks
fsck succeeded. Mounting root device read-write.
Mounting root /dev/disk/by-id/mmc-00000_0x0f4de006-part2
mount -o rw,noatime,nobarrier -t ext4 /dev/disk/by-id/mmc-00000_0x0f4de006-part2 /root
[ 10.257232] EXT4-fs (mmcblk0p2): barriers disabled
[ 10.347106] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: nobarrier
[ 11.011016] EXT4-fs (mmcblk0p2): re-mounted. Opts: nobarrier
[ 12.021148] systemd[1]: systemd 195 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ; suse)
Welcome to openSUSE 12.3 (Dartmouth) (armv7hl)!
fdisk -l /dev/sdc
Platte /dev/sdc: 7969 MByte, 7969177600 Byte
255 Köpfe, 63 Sektoren/Spur, 968 Zylinder, zusammen 15564800 Sektoren
OMAP SD/MMC: 0
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
Net: usb_ether
1516 bytes read in 7 ms (210.9 KiB/s)
4242872 bytes read in 320 ms (12.6 MiB/s)
4351196 bytes read in 318 ms (13 MiB/s)
Image Name: Initrd
OK
Starting kernel …
Creating device nodes with udev
[ 7.418151] systemd-udevd[90]: starting version 195
mount: devpts is already mounted or /dev/pts busy
devpts is already mounted on /dev/pts
Waiting for device /dev/disk/by-id/mmc-00000_0x0f4de006-part2 to appear: …Could not find /dev/disk/by-id/mmc-00000_0x0f4de006-part2.
Want me to fall back to /dev/disk/by-id/mmc-00000_0x0f4de006-part2? (Y/n)
