Hey Everyone,
I just pushed out a new Cloud9 IDE update. This fixes one of the
long-standing problems between github.com/c9/core and our version..
"hints" & "autocomplete" things now show up as you start typing stuff..
do i know why it now works, not really... i had tweaked the build
setup, and while testing I just noticed hints are working..
yoder
April 13, 2017, 2:13pm
2
Robert:
Presently Cloud 9 runs as root. Would it be possible for it to run as debian instead? That would mean the examples would have to run with sudo.
Seems like this would be much more secure.
–Mark
With yesterday's build It's actually really really easy:
https://www.freedesktop.org/software/systemd/man/systemd.exec.html#
User=debian
cat /lib/systemd/system/cloud9.service
[Unit]
Description=Cloud9 IDE
ConditionPathExists=|/var/lib/cloud9
[Service]
WorkingDirectory=/opt/cloud9/build/standalonebuild
EnvironmentFile=/etc/default/cloud9
ExecStart=/usr/bin/nodejs server.js --packed -w /var/lib/cloud9
SyslogIdentifier=cloud9ide
User=debian
Still a few issues:
https://i.imgur.com/amVHbaE.png
Apr 13 14:34:29 beaglebone cloud9ide[528]: LISTEN_FDS = 1
Apr 13 14:34:29 beaglebone cloud9ide[528]: Connect server listening at
http://127.0.0.1:3000
Apr 13 14:34:30 beaglebone cloud9ide[528]: CDN: version standalone
initialized /opt/cloud9/build/standalonebuild/build
Apr 13 14:34:30 beaglebone systemd-timesyncd[273]: Synchronized to
time server 154.16.245.246:123 (2.debian.pool.ntp.org ).
Apr 13 14:34:32 beaglebone cloud9ide[528]: Started
'/opt/cloud9/build/standalonebuild/configs/standalone' with config
'standalone'!
Apr 13 14:34:32 beaglebone cloud9ide[528]: Cloud9 is up and running
Apr 13 14:34:35 beaglebone cloud9ide[528]: cache
/opt/cloud9/build/standalonebuild/build/standalone/config/default.js
Apr 13 14:34:35 beaglebone cloud9ide[528]: cache hit
Apr 13 14:34:36 beaglebone bonescript-autorun[348]: 4:4:60-ti-r97
Apr 13 14:34:36 beaglebone cloud9ide[528]: cache
/opt/cloud9/build/standalonebuild/build/standalone/skin/default/dark.css
Apr 13 14:34:36 beaglebone cloud9ide[528]: cache hit
Apr 13 14:34:36 beaglebone bonescript-autorun[348]: info: Starting
bonescript autorun service
/opt/cloud9/build/standalonebuild/build/standalone/modules/ace/theme/cloud9_night_low_color.js
Apr 13 14:34:37 beaglebone cloud9ide[528]: cache
/opt/cloud9/build/standalonebuild/build/standalone/worker/plugins/c9.ide.language.core/worker.js
/opt/cloud9/build/standalonebuild/build/standalone/modules/ace/theme/idle_fingers.js
Apr 13 14:34:37 beaglebone cloud9ide[528]: cache hit
Apr 13 14:34:42 beaglebone cloud9ide[528]: 768: Error: EACCES:
permission denied, open '/opt/cloud9/.c9/user.settings'
Apr 13 14:34:42 beaglebone cloud9ide[528]: at Error (native)
permission denied, open '/var/lib/cloud9/.c9/project.settings'
permission denied, open '/var/lib/cloud9/.c9/state.settings'
Apr 13 14:34:42 beaglebone cloud9ide[528]: 768: Error: ENOENT: no such
file or directory, open '/var/lib/cloud9/.c9/metadata/tab2'
Apr 13 14:34:47 beaglebone cloud9ide[528]: 768: Error: EACCES:
Apr 13 14:34:47 beaglebone cloud9ide[528]: at Error (native)
Apr 13 14:34:59 beaglebone cloud9ide[528]: 768: Error: EACCES:
Apr 13 14:34:59 beaglebone cloud9ide[528]: at Error (native)
(i'm going to create "cloud9" group and tie /var/lib/cloud9/ and
debian to that group..
and all the examples are broken: (aka |> Run button)
https://i.imgur.com/rNt0TPR.png
So other then all bonescript examples broken, it works.
@Drew , in the python adafruit library you have a gpio/etc debian
permission script, wonder if we should enable that by default, then
the bonescript examples would work as debian user.
Still a few issues:
time server 154.16.245.246:123 (2.debian.pool.ntp.org).
'standalone'!
Okay, the permissions are now taken care of:
committed 02:44PM - 13 Apr 17 UTC
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
committed 04:01PM - 13 Apr 17 UTC
Here's the udev rules:
yoder
April 13, 2017, 4:26pm
5
Robert:
Wow, that was quick. So then Cloud 9 runs a debian now and the udev script sets all the gpio /sys/ files to be owned by debian.
So do I need to grab next week’s build to test it?
–Mark
Robert:
No, it's still root by default.. It's a one line change to get Cloud9
running as debian user via the service file (with a reboot). and i
think that udev rule should make it work without being root. We just
need someone to test it.
So do I need to grab next week's build to test it?
I just fired up a build, while you could tweak last Sunday's image,
you'd have to manually add the new cloud9ide group and run apt
update/apt upgrade.. or just wait for a test build in about an hour.
yoder
April 13, 2017, 5:44pm
7
I’ll wait for the new image. It hasn’t popped up yet.
–Mark
Hey Everyone,
Can a student run all the demos in the Cookbook? How do we make that an every 6 weeks task for students?
Okay give this a shot:
https://rcn-ee.net/rootfs/bb.org/testing/2017-04-13/stretch-iot/
add 'User=debian' to the end of /lib/systemd/system/cloud9.service
and also run:
sudo chown -R :cloud9ide /var/lib/cloud9/ || true
sudo chmod -R g+w /var/lib/cloud9/ || true
sudo chown -R :cloud9ide /opt/cloud9/.c9/ || true
sudo chmod -R g+w /opt/cloud9/.c9/ || true
as for some reason the package still didn't fix those...
yoder
April 13, 2017, 6:35pm
11
I’m flashing it now. Wow, things really download fast when you aren’t competing with 2000 students.
–Mark
yoder
April 13, 2017, 7:31pm
12
Well, it’s running. Here’s a couple of things I notice:
The message “Failed to write to ‘state.settings’. Access denied acccessing this file or folder.” Keeps flashing in red above the edit window.
The terminal window starts in /var/lib/cloud9 . (A good place to start.) Typing cd changes you to /opt/cloud9 which is owned by root. I think it should be /home/debian .
I’ll keep playing around with it.
–Mark
Well, it's running. Here's a couple of things I notice:
1. The message "Failed to write to 'state.settings'. Access denied
acccessing this file or folder." Keeps flashing in red above the edit
window.
That's what this would fix..
but you can try:
sudo apt update ; sudo apt upgrade
as i pushed another new bone101/c9-core-installer update which should do above ^
2. The terminal window starts in /var/lib/cloud9. (A good place to start.)
should be /home/debian.
/opt/cloud9/ is the home directory for cloud9 application.
otherwise i haven't found where that is spawn'ed yet..
finally, those directories have the correct permissions on a clean build.
Have you had any luck with Drew's udev rule?
yoder
April 13, 2017, 7:57pm
15
Yup, the chown/chmod fixed it, and the apt upgrade appears to have worked too.
As for the udev rules, no. I still need to sudo to access the gpio pins. Looks like everything is still root:root.
dmesg[1] doesn’t seem to show anything.
–Mark
[1] http://paste.debian.net/927517/
Did you add the udev rule? It's not packaged.. and i just tried it,
maybe Drew knows what's going on:
installed via:
wget https://github.com/adafruit/adafruit-beaglebone-io-python/raw/master/udev/80-non-root-gpio-permissions.rules
wget https://github.com/adafruit/adafruit-beaglebone-io-python/raw/master/udev/udev-non-root-gpio-permissions.sh
sudo mv udev-non-root-gpio-permissions.sh /usr/local/bin/
sudo chmod +x /usr/local/bin/udev-non-root-gpio-permissions.sh
sudo mv 80-non-root-gpio-permissions.rules /etc/udev/rules.d/
sudo reboot
BUT serial login is toast:
[ OK ] Reached target Host and Network Name Lookups.
[ TIME ] Timed out waiting for device dev-ttyS0.device.
[DEPEND] Dependency failed for Serial Getty on ttyS0.
[ TIME ] Timed out waiting for device dev-ttyGS0.device.
[DEPEND] Dependency failed for Serial Getty on ttyGS0.
[ OK ] Reached target Login Prompts.
[ OK ] Started Generic Board Startup.
Starting BB WL18xx Bluetooth Service...
[ OK ] Started BB WL18xx Bluetooth Service.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
<aka no login prompt>
ssh over eth0 works..
debian@beaglebone:~$ ls -lh /sys/class/gpio/
total 0
--w--w---- 1 debian debian 4.0K Apr 13 19:57 export
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio112 ->
../../devices/platform/ocp/481ae000.gpio/gpio/gpio112
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio114 ->
../../devices/platform/ocp/481ae000.gpio/gpio/gpio114
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio115 ->
../../devices/platform/ocp/481ae000.gpio/gpio/gpio115
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio116 ->
../../devices/platform/ocp/481ae000.gpio/gpio/gpio116
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio14 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio14
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio15 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio15
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio2 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio2
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio20 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio20
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio22 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio22
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio23 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio23
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio26 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio26
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio27 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio27
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio3 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio3
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio30 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio30
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio31 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio31
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio4 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio4
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio44 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio44
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio45 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio45
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio46 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio46
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio47 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio47
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio48 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio48
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio49 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio49
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio5 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio5
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio50 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio50
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio51 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio51
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio60 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio60
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio61 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpio61
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio65 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpio65
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio66 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpio66
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio67 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpio67
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio68 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpio68
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio69 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpio69
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpio7 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpio7
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpiochip0 ->
../../devices/platform/ocp/44e07000.gpio/gpio/gpiochip0
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpiochip32 ->
../../devices/platform/ocp/4804c000.gpio/gpio/gpiochip32
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpiochip64 ->
../../devices/platform/ocp/481ac000.gpio/gpio/gpiochip64
lrwxrwxrwx 1 debian debian 0 Apr 13 19:57 gpiochip96 ->
../../devices/platform/ocp/481ae000.gpio/gpio/gpiochip96
--w--w---- 1 debian debian 4.0K Apr 13 19:57 unexport
blinkled.js still fails...
yoder
April 13, 2017, 8:02pm
17
Hmmm… nothing in /etc/udev/rules.d . Looks like it didn’t install.
–Mark
yoder
April 13, 2017, 8:07pm
18
That was it. gpio seems to be working now as debian. I’ll keep playing…
–Mark
yoder
April 13, 2017, 8:10pm
19
I’ll ask about student support. If the student is directly supporting the class, I think it can be done. However if the student is supporting an outside project it get trickier.
Could we pay a student?
–Mark
