yoder
1
I’ve just downloaded https://rcn-ee.com/rootfs/bb.org/testing/2018-04-22/buster-iot/bone-debian-buster-iot-armhf-2018-04-22-4gb.img.xz and booted it up.
Everything seems to be running fine, but cloud9 isn’t responding on port 3000. In fact, I’m not getting a response on port 80 either.
systemctl status cloud9
● cloud9.service - Cloud9 IDE
Loaded: loaded (/lib/systemd/system/cloud9.service; static; vendor preset: enabled)
Active: active (running) since Mon 2018-04-23 16:36:53 EDT; 4s ago
Process: 6153 ExecStartPre=/opt/cloud9/cloud9-symlink (code=exited, status=0/SUCCESS)
Main PID: 6159 (nodejs)
Tasks: 6 (limit: 1032)
Memory: 7.5M
CGroup: /system.slice/cloud9.service
└─6159 /usr/bin/nodejs server.js --packed -w /var/lib/cloud9
Apr 23 16:36:53 beaglebone systemd[1]: Starting Cloud9 IDE…
Apr 23 16:36:53 beaglebone systemd[1]: Started Cloud9 IDE.
Apr 23 16:36:56 beaglebone cloud9ide[6159]: Starting standalone
It seems to be running…
sudo ./version.sh
git:/opt/scripts/:[871a0ada4779d046081f2b29f4a95d44db2f954d]
eeprom:[A335BNLT0A5C3513BBBK3281]
dogtag:[BeagleBoard.org Debian Image 2018-04-22]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2016.03-00001-g9a81f4a]:[location: dd MBR]
kernel:[4.14.35-ti-r44]
nodejs:[v8.11.1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
pkg:[bb-cape-overlays]:[4.4.20180412.0-0rcnee0~buster+20180412]
pkg:[bb-wl18xx-firmware]:[1.20180328-0rcnee2~buster+20180328]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~buster+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[ 1.072466] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[ 1.079165] gpio-of-helper ocp:cape-universal: ready
END
–Mark
I've just downloaded
and booted it up.
Everything seems to be running fine, but cloud9 isn't responding on port
3000. In fact, I'm not getting a response on port 80 either.
preset: enabled)
status=0/SUCCESS)
Memory: 7.5M
Apr 23 16:36:53 beaglebone systemd[1]: Starting Cloud9 IDE...
It seems to be running...
With buster, we are trying out "nginx", the server config has this setup:
location / {
#Cloud9
proxy_pass http://127.0.0.1:3000;
location /bone101 {
proxy_pass http://127.0.0.1:8000;
location /nodered {
proxy_pass http://127.0.0.1:1880;
thus http://beaglebone.local/ should be -> cloud9.. unless something
else broke...
sudo ./version.sh
PS, 2016.03 in eMMC is going to mess things up..
nodejs:[v8.11.1]
568
END
no it looks like cloud9 needs to be rebuilt:
Apr 23 21:29:53 beaglebone systemd[1]: cloud9.service: Main process
exited, code=killed, status=6/ABRT
Apr 23 21:29:53 beaglebone systemd[1]: cloud9.service: Failed with
result 'signal'.
Apr 23 21:29:53 beaglebone systemd[1]: Starting Cloud9 IDE...
Apr 23 21:29:53 beaglebone systemd[1]: Started Cloud9 IDE.
Apr 23 21:29:54 beaglebone cloud9ide[1805]: Starting standalone
Apr 23 21:29:55 beaglebone cloud9ide[1805]: LISTEN_FDS = 1
Apr 23 21:29:55 beaglebone cloud9ide[1805]: /usr/bin/nodejs[1805]:
../src/pipe_wrap.cc:131:static void node::PipeWrap::New(const
v8::FunctionCallbackInfo<v8::Value>&): Assertion `args[0]->IsInt32()'
failed.
rebuilding the nodejs package:
Apr 24 16:08:45 beaglebone cloud9ide[1746]: /usr/bin/nodejs[1746]:
failed.
@mark - fix seems to be here:
https://github.com/rubenv/node-systemd/pull/15
Testing.
