codesourcery toolchain 2009: Linker Script
Hello!
I've been wandering around the net to resolve my linker script problem
using arm-none-eabi (e.g. Codesourcery g++ lite edition)
I hope you guys can help me.
Here is my condition:
I have beagleboard running Angstrom Linux
I have arm-none-eabi-gcc compiler on my host computer.
I tried to compile this simple hello.c:
#include <stdio.h>
int main(){
        printf("hello!\n");
        return 0;
i.e. ./bin/arm-none-eabi-gcc hello.c -o hello
but it gave me:
/home/dio/sandbox/toolchain/arm-2007q3/bin/../lib/gcc/arm-none-eabi/
4.2.1/../../../../arm-none-eabi/bin/ld: warning: cannot find entry
symbol _start; defaulting to 00008018
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-makebuf.o): In
function `__smakebuf':
makebuf.c:(.text+0xf8): undefined reference to `isatty'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-sbrkr.o): In function
`_sbrk_r':
sbrkr.c:(.text+0x18): undefined reference to `_sbrk'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-writer.o): In
function `_write_r':
writer.c:(.text+0x20): undefined reference to `_write'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-closer.o): In
function `_close_r':
closer.c:(.text+0x18): undefined reference to `_close'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-fstatr.o): In
function `_fstat_r':
fstatr.c:(.text+0x1c): undefined reference to `_fstat'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-lseekr.o): In
function `_lseek_r':
lseekr.c:(.text+0x20): undefined reference to `_lseek'
4.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-readr.o): In function
`_read_r':
readr.c:(.text+0x20): undefined reference to `_read'
collect2: ld returned 1 exit status
If I put "-T generic.ld" it is compiled OK but gives segmentation
fault message on my Beagle.
How to generate the correct linker script?
Thanks for your attention!
Best,
Dio
Dio wrote:
Hello!
#include <stdio.h>
int main(){
        printf("hello!\n");
        return 0;
Assuming you want to run above program as Linux user space application
(under Angstrom), have you tried to use
arm-none-linux-gnueabi-gcc
instead of arm-none-eabi-gcc?
http://www.codesourcery.com/sgpp/lite/arm/portal/release858
Best regards
dirk
[mailto:beagleboard@googlegroups.com] On Behalf Of Dio
Sent: Thursday, September 03, 2009 9:04 PM
To: Beagle Board
Subject: [beagleboard] codesourcery toolchain 2009: Linker Script
Hello!
Koen is going to blow a gasket!!!
You should use the OE cross compiler if you are targeting the Angstrom file
system. If you have OE installed, you will find the compiler in
tmp/cross/armv7a/bin
