I am builiding kernel 2.6.37 for devkit 8000. I got the kernel src
from following location
git clone git://gitorious.org/devkit8000/linux-omap-devkit8000.git
I configured and created uImage. But I boot the kernel it get hung at
Starting Kernel ...
Here is the log.
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.37-rc3-g3153f68
Data Size: 2353760 Bytes = 2.2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
I am using following version of uBoot
U-Boot 2010.03
I compiled Uboot and linux src using ARM cross compiler version =
(Sourcery G++ Lite 2009q1-203) 4.3.3
Thank you very much. changing ttyS2 to ttyO2 solved my problem.
I am facing similar problem on Zoom2 board. there I have Android
kernel 2.6.32. I tried u-boot memory dump (md) to read the pritk
buffer data.I can see contents of __log_buf. It looks like kernel is
booting.
Could you please give me some pointers on that? I have also tried main
line linux 2.6.32 with zoom2 defconfig, and I was able to read the
debug messages but if I download android kernel 2.6.32, it gets hung
at starting kernel... ...
I tried various android sources. Tried to debug kernel using
printascii and md but could not see the kernel debug messages.
Hi Alok,
I am trying a similar task, will the source from http://gitorious.org/devkit8000/linux-omap-devkit8000.git run on embest devkit8000 as it is? or do we need to do some devkit specific changes to the kernel before loading it. In that case where can I get those changes?
The link doesn’t seem to work…any idea?
I am also running into some troubles with 2.6.38 kernel
Basically I cloned the git repos for u-boot and linux_devkit8000, than, in a straigthforward fashon I cross compiled them both usign the gcc toolchain that comes with an openembedded build using the standard kernel devki8000_defconfig.
U-boot works fine, console needs to changed to ttySO2 but my kernel stops at some point, most often afer the alsa.
Moreover the 7" LCD seems not to be working at all despite u-boot bootargs
