I wanted to compile the omap kernel!
So i:
1. Cloned the "git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/
linux-omap-2.6.git linux-omap-2.6" git
2. cd in "linux-omap-2.6"
3. make CROSS_COMPILE=arm-none-eabi- distclean
4. make CROSS_COMPILE=arm-none-eabi- omap3_beagle_defconfig
5. make CROSS_COMPILE=arm-none-eabi- uImage
When i start compiling it show me:
michi@michi-laptop:~/Beagle/kernel.org/linux-omap-2.6$ make
scripts/kconfig/conf -s arch/arm/Kconfig
CHK include/linux/version.h
UPD include/linux/version.h
Generating include/asm-arm/mach-types.h
CHK include/linux/utsrelease.h
UPD include/linux/utsrelease.h
SYMLINK include/asm -> include/asm-arm
CC kernel/bounds.s
GEN include/linux/bounds.h
CC arch/arm/kernel/asm-offsets.s
GEN include/asm/asm-offsets.h
CALL scripts/checksyscalls.sh
<stdin>:1097:2: warning: #warning syscall fadvise64 not implemented
<stdin>:1265:2: warning: #warning syscall migrate_pages not
implemented
<stdin>:1321:2: warning: #warning syscall pselect6 not implemented
<stdin>:1325:2: warning: #warning syscall ppoll not implemented
<stdin>:1365:2: warning: #warning syscall epoll_pwait not implemented
<stdin>:1421:2: warning: #warning syscall preadv not implemented
<stdin>:1425:2: warning: #warning syscall pwritev not implemented
HOSTCC scripts/genksyms/genksyms.o
SHIPPED scripts/genksyms/lex.c
SHIPPED scripts/genksyms/parse.h
SHIPPED scripts/genksyms/keywords.c
HOSTCC scripts/genksyms/lex.o
scripts/genksyms/lex.c: In Funktion »yylex1«:
scripts/genksyms/lex.l:97: Warnung: Der Rückgabewert von »fwrite«, der
mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert
SHIPPED scripts/genksyms/parse.c
HOSTCC scripts/genksyms/parse.o
HOSTLD scripts/genksyms/genksyms
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/mod/modpost.o
scripts/mod/modpost.c: In Funktion »get_markers«:
scripts/mod/modpost.c:1545: Warnung: Der Rückgabewert von »asprintf«,
der mit dem Attribut warn_unused_result deklariert wurde, wird
ignoriert
scripts/mod/modpost.c: In Funktion »add_marker«:
scripts/mod/modpost.c:1965: Warnung: Der Rückgabewert von »asprintf«,
ignoriert
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
HOSTCC scripts/kallsyms
scripts/kallsyms.c: In Funktion »read_symbol«:
scripts/kallsyms.c:74: Warnung: Der Rückgabewert von »fgets«, der mit
HOSTCC scripts/conmakehash
CC init/main.o
CHK include/linux/compile.h
UPD include/linux/compile.h
CC init/version.o
CC init/do_mounts.o
CC init/do_mounts_rd.o
CC init/do_mounts_initrd.o
LD init/mounts.o
CC init/initramfs.o
CC init/calibrate.o
LD init/built-in.o
HOSTCC usr/gen_init_cpio
usr/gen_init_cpio.c: In Funktion »cpio_mkfile«:
usr/gen_init_cpio.c:357: Warnung: Der Rückgabewert von »fwrite«, der
GEN usr/initramfs_data.cpio
AS usr/initramfs_data.o
LD usr/built-in.o
CC arch/arm/kernel/compat.o
CC arch/arm/kernel/elf.o
AS arch/arm/kernel/entry-armv.o
AS arch/arm/kernel/entry-common.o
CC arch/arm/kernel/irq.o
CC arch/arm/kernel/process.o
CC arch/arm/kernel/ptrace.o
CC arch/arm/kernel/setup.o
CC arch/arm/kernel/signal.o
CC arch/arm/kernel/sys_arm.o
CC arch/arm/kernel/stacktrace.o
CC arch/arm/kernel/time.o
CC arch/arm/kernel/traps.o
CC arch/arm/kernel/armksyms.o
CC arch/arm/kernel/module.o
CC arch/arm/kernel/sys_oabi-compat.o
arch/arm/kernel/sys_oabi-compat.c: In function 'sys_oabi_epoll_wait':
arch/arm/kernel/sys_oabi-compat.c:288: error: implicit declaration of
function 'kmalloc'
arch/arm/kernel/sys_oabi-compat.c:288: error: 'GFP_KERNEL' undeclared
(first use in this function)
arch/arm/kernel/sys_oabi-compat.c:288: error: (Each undeclared
identifier is reported only once
arch/arm/kernel/sys_oabi-compat.c:288: error: for each function it
appears in.)
arch/arm/kernel/sys_oabi-compat.c:288: warning: assignment makes
pointer from integer without a cast
arch/arm/kernel/sys_oabi-compat.c:301: error: implicit declaration of
function 'kfree'
arch/arm/kernel/sys_oabi-compat.c: In function 'sys_oabi_semtimedop':
arch/arm/kernel/sys_oabi-compat.c:324: error: 'GFP_KERNEL' undeclared
arch/arm/kernel/sys_oabi-compat.c:324: warning: assignment makes
make[1]: *** [arch/arm/kernel/sys_oabi-compat.o] Fehler 1
make: *** [arch/arm/kernel] Fehler 2
And stopped compile!
What the problem?
p.s i use the Sourcery G++ Lite 2008q3-66 toolchain
Michael
