jtaylo
June 24, 2024, 8:25pm
1
I am trying to activate a couple SPI lines using the config-pin tool. I have my HDMI disabled, and if I run “config-pin -q” on any of these pins I get back “default”. However when I run the following commands, I just get “ERROR: write() to /sys/devices/platform/ocp/ocp:P9_13_pinmux/state failed, no such device”
config-pin P9.13 spi_sclk
config-pin P9.14 spi_cs
config-pin P9.15 spi
config-pin P9.16 spi
config-pin P8.33 spi_sclk
config-pin P8.34 spi_cs
config-pin P8.35 spi
config-pin P8.36 spi
Is this no longer the way to set this up? Thanks for your help.
It’s best to use an spi overlay. If you run and report the output of:
sudo beagle-version
We can fine tune why that didn’t work.
jtaylo
June 24, 2024, 9:33pm
3
Sure thing, here you go. Is there a good spi template around I could use?
eeprom:[A335BNLTEIA02104SBB23069]
dogtag:[BeagleBoard.org Debian Bullseye IoT Image 2023-09-02]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-UIO-00A0.kernel]
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[BB-UART1-00A0.kernel]
UBOOT: Loaded Overlay:[BB-UART2-00A0.kernel]
UBOOT: Loaded Overlay:[BB-UART5-00A0]
kernel:[5.10.168-ti-r77]
nodejs:[v12.22.12]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_addr0=BB-UART1-00A0.dtbo]
uboot_overlay_options:[uboot_overlay_addr1=BB-UART2-00A0.dtbo]
uboot_overlay_options:[uboot_overlay_addr2=BB-UART5-00A0.dtbo]
uboot_overlay_options:[disable_uboot_overlay_video=1]
uboot_overlay_options:[disable_uboot_overlay_audio=1]
uboot_overlay_options:[disable_uboot_overlay_wireless=1]
uboot_overlay_options:[uboot_overlay_pru=AM335X-PRU-UIO-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~bullseye+20210821]
pkg:[bb-customizations]:[1.20240119.0-0~bullseye+20240119]
pkg:[bb-usb-gadgets]:[1.20240403.0-0~bullseye+20240403]
pkg:[bb-wl18xx-firmware]:[1.20230414.0-0~bullseye+20230414]
pkg:[kmod]:[28-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20210315-3]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input render bluetooth netdev i2c gpio admin tisdk weston-launch cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 12.691314] remoteproc remoteproc0: wkup_m3 is available
[ 46.880213] remoteproc remoteproc0: powering up wkup_m3
[ 46.880256] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 46.880574] remoteproc remoteproc0: remote processor wkup_m3 is now up
dmesg | grep pru
[ 4805.073090] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 5338.273021] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 5393.287078] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 5404.742897] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 7363.911081] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 7376.390887] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pruin
[ 7378.889641] bone-pinmux-helper ocp:P9_42_pinmux: Failed to find state pru
dmesg | grep pinctrl-single
[ 12.089412] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[ 12.091210] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[ 12.091240] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[ 13.014646] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[ 13.014926] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[ 13.015133] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[ 13.015366] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[ 13.016028] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[ 13.016260] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[ 13.016481] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[ 13.016675] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[ 13.016893] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[ 13.017106] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[ 13.017397] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[ 13.017617] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[ 13.017847] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[ 13.018068] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[ 13.018271] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[ 13.018467] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[ 13.018672] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[ 13.018882] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[ 13.019072] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[ 13.019290] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[ 13.019483] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[ 13.019687] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[ 13.020016] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[ 13.020217] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[ 13.020434] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[ 13.020635] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[ 13.020840] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[ 13.021042] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[ 13.021239] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[ 13.021459] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[ 13.021653] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[ 13.021877] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[ 13.022084] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[ 13.022290] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[ 13.022495] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[ 13.022706] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[ 13.022910] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[ 13.023107] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[ 13.023298] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[ 13.023504] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[ 13.023804] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[ 13.024026] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[ 13.024250] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[ 13.024445] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[ 13.024659] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[ 13.024882] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[ 13.025084] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[ 13.025293] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[ 13.025486] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[ 13.025728] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[ 13.025932] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[ 13.026144] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[ 13.026352] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[ 13.026543] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[ 13.026745] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[ 13.026947] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[ 13.027155] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[ 13.027371] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[ 13.028004] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[ 13.028254] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[ 13.028475] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[ 13.028674] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[ 13.028880] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[ 13.029080] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[ 13.029275] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[ 13.029492] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[ 13.029686] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[ 13.029919] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[ 13.030123] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[ 13.030136] gpio-of-helper ocp:cape-universal: ready
lsusb
END
jtaylo
June 24, 2024, 9:53pm
5
Would it be possible for me to just modify the numbers in those overlays to the desired pins (P9.13-16 and P8.33-36) and recompile to the .dtbos? I’m updating a legacy system and avoiding a hardware change.
Most of those are not offical modes for the pin: boneDeviceTree/docs at master · derekmolloy/boneDeviceTree · GitHub
I hope you counted wrong, otherwise your going to be using the emulated spi-gpio driver…
jtaylo
June 24, 2024, 10:11pm
7
Nope, this is just what previous devs had done. It seems that a working spi link for similar purposes just used
config-pin P9.13 gpio_pd
config-pin P9.14 gpio_pu
config-pin P9.15 gpio_input
config-pin P9.16 gpio_pd
In place of what I tried:
This has been reliably working for an older kernel version (~2020) so I suppose I’ll try that first…
What do you mean by an emulated spi-gpio driver?
Well those gpio_xyz are valid options for P9.13 → P9.16, and why your spi_xyz options failed…
Emulated/BitBang/etc… Manually toggling gpio pins to emulate spi bus, that’s exactly what the spi-gpio driver does… spi-gpio.c « spi « drivers - kernel/git/torvalds/linux.git - Linux kernel source tree
DeviceTree docs: spi-gpio.yaml « spi « bindings « devicetree « Documentation - kernel/git/torvalds/linux.git - Linux kernel source tree
jtaylo
June 24, 2024, 10:59pm
9
Aha – yes my setup is BitBanged SPI. I think it just does this on the PRU.
Thanks a ton! This helped.
Oh Cool! yeah if done right the pru is another option. Too much thinking about only the cortex-A8 side…
