How can I use the CAN0 device with a Buildroot image?
I have a Beaglebone black rev C and have build an image using Buildroot. I used the standard beaglebone_defconfig and installed can-utils as well as iproute2.
My understanding is that the i2c2 pins should be reconfigured to be able to use the CAN0 device. In order to keep things simple (and avoid overlays) I edit the “am335x-bone-common.dtsi” file in two ways.
- Comment out the i2c2 and insert the CAN0 pin setup:
// i2c2_pins: pinmux_i2c2_pins {
// pinctrl-single,pins = <
// 0x178 (PIN_INPUT_PULLUP | MUX_MODE3) /* uart1_ctsn.i2c2_sda /
// 0x17c (PIN_INPUT_PULLUP | MUX_MODE3) / uart1_rtsn.i2c2_scl */
dcan0_pins: pinmux_dcan0_pins {
0x178 (PIN_OUTPUT_PULLUP | MUX_MODE2) /* P9.20 (0x178), ddcan0_tx /
0x17c (PIN_INPUT_PULLUP | MUX_MODE2) / P9.19 (0x17c), ddcan0_rx */
- Replace i2c2 with
&dcan0 {
#address-cells = <1>;
#size-cells = <1>;
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <&dcan0_pins>;
Once I log in I can not get any CAN device going anywhere:
ifup can0
Cannot find device “can0”
ifconfig can0 up
ifconfig: SIOCGIFFLAGS: No such device
And looking at the available networks
ls -al /sys/class/net/
total 0
drwxr-xr-x 2 root root 0 Jan 1 00:00 .
drwxr-xr-x 43 root root 0 Jan 1 00:00 …
lrwxrwxrwx 1 root root 0 Jan 1 00:00 eth0 → …/…/devices/platform/ocp/4a100000.ethernet/net/eth0
lrwxrwxrwx 1 root root 0 Jan 1 00:00 lo → …/…/devices/virtual/net/lo
lrwxrwxrwx 1 root root 0 Jan 1 00:02 sit0 → …/…/devices/virtual/net/sit0
I have exhausted all resources and am truly stuck. Any information which may help will be greatly appreciated.
Thank you
