I want to configure some of my gpio pins (P8_07 to P8_10) of my beagle bone black revC board as inputs with active high state.
OS running in my board is Debian 9.3, with Kernel 4.1.
4.1.x? we dropped that over a year ago..
So the current doc's are not going to be relavent..
Start with the latest image:
https://beagleboard.org/latest-images
and use config-pin on those pins..
Thanks @Robert
I could solve the issue by setting active_low value in /sys/class/gpio/gpio66
But I think that’s not the recommended method.
Comments please!!
write a device overlay to do all of this then load it in /boot/uEnv.txt
Hi Wulf Man,
I’ve added the related dtbo files in /lib/firmware/ and the links I’ve kept in the /boot/uEnv.txt as follows:
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/.dtbo
#uboot_overlay_addr1=/lib/firmware/.dtbo
But, it didn’t help!!
The "#" sign must be removed or it will not load
not sure if you did that
Probably worth subsituting <file0> with the name of the actual file too.
Yea… I had removed that ‘#’ sign…
It was not working yet.
