Hello I am trying to check if a Beaglebone AI is getting correctly I2S from a TIDA-1454 so if I try to arecord --device="hw:1,0" -f S16_LE test.wav I get:
debian@beaglebone:/var/lib/cloud9$ arecord --device="hw:1,0" -d 20 -f S16_LE test.wav
Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
arecord: pcm_read:2145: read error: Input/output error
The card is detected since i get this output from arecord -l:
**** List of CAPTURE Hardware Devices ****
card 1: PCM5102a [PCM5102a], device 0: davinci-mcasp.0-pcm5102a-hifi pcm5102a-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
or arecord -L :
debian@beaglebone:/var/lib/cloud9$ arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
onboard
onboard_capture_left
onboard_playback_left
onboard_capture_right
onboard_playback_right
plug_onboard_capture_left
plug_onboard_playback_left
default
sysdefault:CARD=PCM5102a
PCM5102a,
Default Audio Device
dmix:CARD=PCM5102a,DEV=0
PCM5102a,
Direct sample mixing device
dsnoop:CARD=PCM5102a,DEV=0
PCM5102a,
Direct sample snooping device
hw:CARD=PCM5102a,DEV=0
PCM5102a,
Direct hardware device without any conversions
plughw:CARD=PCM5102a,DEV=0
PCM5102a,
Hardware device with all software conversions
But I dont fully understand the changes that must be made in ALSA configuration since my asound.conf splits channels:
pcm.onboard{
type hw
card 0
ctl.onboard {
type hw
card 0
### Dsnoop splited channels
pcm.onboard_capture_left {
type dsnoop
ipc_key 32
slave {
pcm "onboard"
channels 2
rate 48000
format S32_LE
bindings.0 0
pcm.onboard_playback_left {
type dmix
ipc_key 33
slave {
pcm "onboard"
channels 2
bindings.0 0
pcm.onboard_capture_right {
type dsnoop
ipc_key 32
slave {
pcm "onboard"
channels 2
rate 48000
format S32_LE
bindings.0 1
pcm.onboard_playback_right {
type dmix
ipc_key 33
slave {
pcm "onboard"
channels 2
bindings.0 1
### PLUGS ##
### used with darkice
### device = plug:plug_onboard_left
pcm.plug_onboard_capture_left{
type plug
slave.pcm "onboard_capture_left"
pcm.plug_onboard_playback_left{
type plug
slave.pcm "onboard_playback_left"
pcm.!default {
type asym
playback.pcm "plug_onboard_playback_left"
capture.pcm "plug_onboard_capture_left"
This is where probably I haave to make changes but I dont know which one. Or if there is anything that I am missing just let me know.
Thanks in advance.
