Confusing message while attempting to build systemd-image
I just updated my Angstrom build system using ./oebb.sh update and obtained the following errors. Any suggestions?
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 189 of systemd not available (for item udev)
NOTE: versions of systemd available: v189
NOTE: preferred version 189 of systemd not available (for item systemd)
NOTE: versions of systemd available: git v189
NOTE: preferred version 189 of systemd not available (for item udev-systemd)
NOTE: preferred version 189 of systemd not available (for item udev-utils)
NOTE: preferred version 189 of systemd not available (for item systemd-dev)
NOTE: Preparing runqueue
ERROR: Multiple .bb files are due to be built which each provide systemd (/home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_v189.bb /home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb).
  This usually means one provides something the other doesn't and should.
followed by:
checking for pkg-config...
/home/dlambert/beaglebone/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/i686-linux/usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for UDEV... no
configure: error: Package requirements ( libudev >= 172 ) were not met:
No package 'libudev' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables UDEV_CFLAGS
and UDEV_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
ERROR: oe_runconf failed
NOTE: package systemd-git-r28: task do_configure: Failed
ERROR: Task 165 (/home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb, do_configure) failed with exit code '1'
Waiting for 1 running tasks to finish:
0: linux-ti33x-psp-3.2.34-r18a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 do_package (pid 29160)
