I add my dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (koen@rrMBP) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Tue Jun 18 02:11:09 EDT 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c0688d80, node_mem_map c06e4000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0af3000 s9408 r8192 d15168 u32768
[ 0.000000] pcpu-alloc: s9408 r8192 d15168 u32768 alloc=84096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 run_hardware_tests quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 510560k/510560k available, 13728k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05d5914 (5943 kB)
[ 0.000000] .init : 0xc05d6000 - 0xc06174c0 ( 262 kB)
[ 0.000000] .data : 0xc0618000 - 0xc0689ca0 ( 456 kB)
[ 0.000000] .bss : 0xc0689ca0 - 0xc06e36bc ( 359 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000353] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015426] pid_max: default: 32768 minimum: 301
[ 0.015661] Security Framework initialized
[ 0.015754] Mount-cache hash table entries: 512
[ 0.025816] Initializing cgroup subsys cpuacct
[ 0.025853] Initializing cgroup subsys memory
[ 0.025916] Initializing cgroup subsys blkio
[ 0.026051] CPU: Testing write buffer coherency: ok
[ 0.026584] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026659] Setting up static identity map for 0x80370ee0 - 0x80370f2c
[ 0.028065] Brought up 1 CPUs
[ 0.028091] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029386] devtmpfs: initialized
[ 0.094265] pinctrl core: initialized pinctrl subsystem
[ 0.094481] rstctl core: initialized rstctl subsystem
[ 0.094966] regulator-dummy: no parameters
[ 0.095531] NET: Registered protocol family 16
[ 0.096426] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106380] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107148] platform 49000000.edma: alias fck already exists
[ 0.107180] platform 49000000.edma: alias fck already exists
[ 0.107256] platform 49000000.edma: alias fck already exists
[ 0.108403] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.108588] OMAP GPIO hardware version 0.1
[ 0.109984] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.111289] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.112584] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.113233] of_get_named_gpio_flags exited with status 52
[ 0.113264] gpio-rctrl rstctl.3: loaded OK
[ 0.118586] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.120741] cpsw.0: No hwaddr in dt. Using 90:59:af:51:3c:e5 from efuse
[ 0.120776] cpsw.1: No hwaddr in dt. Using 90:59:af:51:3c:e7 from efuse
[ 0.135303] bio: create slab at 0
[ 0.147281] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.147506] of_get_named_gpio_flags: can’t parse gpios property
[ 0.147733] vmmcsd_fixed: 3300 mV
[ 0.150612] SCSI subsystem initialized
[ 0.151035] usbcore: registered new interface driver usbfs
[ 0.151147] usbcore: registered new interface driver hub
[ 0.151427] usbcore: registered new device driver usb
[ 0.153499] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.155005] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.156710] DCDC1: at 1500 mV
[ 0.157858] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.158979] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.160117] LDO1: at 1800 mV
[ 0.161236] LDO2: at 3300 mV
[ 0.163223] LDO3: 1800 mV
[ 0.164345] LDO4: at 3300 mV
[ 0.165348] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.166104] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.166823] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.169184] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.169396] media: Linux media interface: v0.10
[ 0.169498] Linux video capture interface: v2.00
[ 0.170278] Advanced Linux Sound Architecture Driver Initialized.
[ 0.171587] Switching to clocksource gp_timer
[ 0.189711] NET: Registered protocol family 2
[ 0.190711] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.190853] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.191015] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.191107] TCP: reno registered
[ 0.191133] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191179] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191666] NET: Registered protocol family 1
[ 0.192242] RPC: Registered named UNIX socket transport module.
[ 0.192263] RPC: Registered udp transport module.
[ 0.192277] RPC: Registered tcp transport module.
[ 0.192291] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.193511] CPU PMU: probing PMU on CPU 0
[ 0.193542] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.193996] omap2_mbox_probe: platform not supported
[ 0.197844] VFS: Disk quotas dquot_6.5.2
[ 0.198080] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.199317] NFS: Registering the id_resolver key type
[ 0.199512] Key type id_resolver registered
[ 0.199530] Key type id_legacy registered
[ 0.199594] jffs2: version 2.2. (NAND) (SUMMARY) \xffffffc2\xffffffa9 2001-2006 Red Hat, Inc.
[ 0.200041] msgmni has been set to 997
[ 0.202867] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.202892] io scheduler noop registered
[ 0.202908] io scheduler deadline registered
[ 0.203018] io scheduler cfq registered (default)
[ 0.204656] tps65217-bl tps65217-bl: no platform data provided
[ 0.204698] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.205678] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.208215] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.208503] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.220806] console [ttyO0] enabled
[ 0.221791] [drm] Initialized drm 1.1.0 20060810
[ 0.235609] brd: module loaded
[ 0.242713] loop: module loaded
[ 0.242838] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.242913] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.242995] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243063] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.243132] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.250260] bone-capemgr bone_capemgr.8: Baseboard: ‘A335BNLT,0A5C,3213BBBK0286’
[ 0.250300] bone-capemgr bone_capemgr.8: compatible-baseboard=ti,beaglebone-black
[ 0.281134] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.318242] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.355349] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.392458] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.398716] bone-capemgr bone_capemgr.8: slot #4: specific override
[ 0.398759] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 4
[ 0.398789] bone-capemgr bone_capemgr.8: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 0.398929] bone-capemgr bone_capemgr.8: slot #5: specific override
[ 0.398966] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 5
[ 0.398994] bone-capemgr bone_capemgr.8: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 0.399132] bone-capemgr bone_capemgr.8: slot #6: specific override
[ 0.399169] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 6
[ 0.399197] bone-capemgr bone_capemgr.8: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 0.399708] bone-capemgr bone_capemgr.8: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 0.399737] bone-capemgr bone_capemgr.8: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 0.399871] bone-capemgr bone_capemgr.8: loader: before slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 0.399897] bone-capemgr bone_capemgr.8: loader: check slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 0.399959] bone-capemgr bone_capemgr.8: initialized OK.
[ 0.401933] OneNAND driver initializing
[ 0.402407] bone-capemgr bone_capemgr.8: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 0.402449] bone-capemgr bone_capemgr.8: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 0.402479] bone-capemgr bone_capemgr.8: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 0.402789] bone-capemgr bone_capemgr.8: slot #4: #2 overlays
[ 0.403644] bone-capemgr bone_capemgr.8: slot #4: Applied #2 overlays.
[ 0.403674] bone-capemgr bone_capemgr.8: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 0.403832] bone-capemgr bone_capemgr.8: loader: after slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 0.403872] bone-capemgr bone_capemgr.8: slot #5: Requesting firmware ‘cape-boneblack-hdmi-00A0.dtbo’ for board-name ‘Bone-Black-HDMI’, version ‘00A0’
[ 0.403912] bone-capemgr bone_capemgr.8: slot #5: dtbo ‘cape-boneblack-hdmi-00A0.dtbo’ loaded; converting to live tree
[ 0.405146] bone-capemgr bone_capemgr.8: slot #5: #4 overlays
[ 0.407381] usbcore: registered new interface driver asix
[ 0.407506] usbcore: registered new interface driver cdc_ether
[ 0.407639] usbcore: registered new interface driver smsc95xx
[ 0.407729] usbcore: registered new interface driver net1080
[ 0.407819] usbcore: registered new interface driver cdc_subset
[ 0.407905] usbcore: registered new interface driver zaurus
[ 0.408163] usbcore: registered new interface driver cdc_ncm
[ 0.408773] bone-capemgr bone_capemgr.8: loader: before slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.408801] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.408830] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.410278] platform 4830e000.fb: alias fck already exists
[ 0.411839] bone-capemgr bone_capemgr.8: slot #5: Applied #4 overlays.
[ 0.411869] bone-capemgr bone_capemgr.8: loader: done slot-5 BB-BONELT-HDMI:00A0 (prio 1)
[ 0.411931] bone-capemgr bone_capemgr.8: loader: check slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.412060] bone-capemgr bone_capemgr.8: loader: after slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.412103] bone-capemgr bone_capemgr.8: slot #6: Requesting firmware ‘cape-boneblack-hdmin-00A0.dtbo’ for board-name ‘Bone-Black-HDMIN’, version ‘00A0’
[ 0.412144] bone-capemgr bone_capemgr.8: slot #6: dtbo ‘cape-boneblack-hdmin-00A0.dtbo’ loaded; converting to live tree
[ 0.412484] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.422106] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 0.428885] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.438763] usbcore: registered new interface driver cdc_acm
[ 0.438781] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.438795] Initializing USB Mass Storage driver…
[ 0.438936] usbcore: registered new interface driver usb-storage
[ 0.438950] USB Mass Storage support registered.
[ 0.439178] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.439635] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 0.439665] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 0.439701] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.439722] musb-hdrc: MHDRC RTL version 2.0
[ 0.439736] musb-hdrc: setup fifo_mode 4
[ 0.439764] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.439909] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 0.439930] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 0.440794] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 0.440823] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 0.440858] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.440877] musb-hdrc: MHDRC RTL version 2.0
[ 0.440891] musb-hdrc: setup fifo_mode 4
[ 0.440914] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.441044] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 0.441065] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 0.441086] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.441587] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 0.441629] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 0.441744] usb usb1: default language 0x0409
[ 0.441804] usb usb1: udev 1, busnum 1, minor = 0
[ 0.441827] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.441850] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.441870] usb usb1: Product: MUSB HDRC host driver
[ 0.441889] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 0.441908] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 0.442672] usb usb1: usb_probe_device
[ 0.442701] usb usb1: configuration #1 chosen from 1 choice
[ 0.442768] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 0.442976] hub 1-0:1.0: usb_probe_interface
[ 0.442998] hub 1-0:1.0: usb_probe_interface - got id
[ 0.443026] hub 1-0:1.0: USB hub found
[ 0.443067] hub 1-0:1.0: 1 port detected
[ 0.443087] hub 1-0:1.0: standalone hub
[ 0.443104] hub 1-0:1.0: individual port power switching
[ 0.443122] hub 1-0:1.0: no over-current protection
[ 0.443139] hub 1-0:1.0: Single TT
[ 0.443160] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 0.443179] hub 1-0:1.0: power on to power good time: 10ms
[ 0.443334] hub 1-0:1.0: local power source is good
[ 0.443469] hub 1-0:1.0: enabling power on all ports
[ 0.444529] mousedev: PS/2 mouse device common for all mice
[ 0.446895] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 0.446961] 44e3e000.rtc: already running
[ 0.447402] i2c /dev entries driver
[ 0.449169] Driver for 1-wire Dallas network protocol.
[ 0.450645] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.451069] cpuidle: using governor ladder
[ 0.451091] cpuidle: using governor menu
[ 0.451503] of_get_named_gpio_flags: can’t parse gpios property
[ 0.451522] of_get_named_gpio_flags: can’t parse gpios property
[ 0.451538] of_get_named_gpio_flags: can’t parse gpios property
[ 0.451574] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.458838] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 0.458897] omap_hsmmc mmc.4: unable to select pin group
[ 0.459179] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 0.459263] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 0.459500] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 0.459634] omap_hsmmc mmc.4: pins are not configured from the driver
[ 0.486458] of_get_named_gpio_flags: can’t parse gpios property
[ 0.486481] of_get_named_gpio_flags: can’t parse gpios property
[ 0.486497] of_get_named_gpio_flags: can’t parse gpios property
[ 0.486550] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[ 0.486641] omap_hsmmc mmc.10: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 0.486664] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[ 0.486966] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 0.487045] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 0.487569] mmc.10 supply vmmc_aux not found, using dummy regulator
[ 0.487791] omap_hsmmc mmc.10: pins are not configured from the driver
[ 0.515925] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 0.527636] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 0.534949] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 0.543931] leds-gpio gpio-leds.7: pins are not configured from the driver
[ 0.543968] of_get_named_gpio_flags exited with status 53
[ 0.543991] of_get_named_gpio_flags exited with status 54
[ 0.544013] of_get_named_gpio_flags exited with status 55
[ 0.544033] of_get_named_gpio_flags exited with status 56
[ 0.544058] of_get_named_gpio_flags exited with status 53
[ 0.544310] of_get_named_gpio_flags exited with status 54
[ 0.544520] of_get_named_gpio_flags exited with status 55
[ 0.544721] of_get_named_gpio_flags exited with status 56
[ 0.544913] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 0.544985] hub 1-0:1.0: hub_suspend
[ 0.545025] usb usb1: bus auto-suspend, wakeup 1
[ 0.545541] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.545988] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 0.546069] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 0.548274] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 0.548403] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 0.548484] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 0.549822] usbcore: registered new interface driver usbhid
[ 0.549842] usbhid: USB HID core driver
[ 0.552871] of_get_named_gpio_flags exited with status 59
[ 0.554208] davinci_evm sound.13: nxp-hdmi-hifi <-> 48038000.mcasp mapping ok
[ 0.556427] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 0.558164] TCP: cubic registered
[ 0.558184] Initializing XFRM netlink socket
[ 0.558226] NET: Registered protocol family 17
[ 0.558329] NET: Registered protocol family 15
[ 0.558554] mmc0: new high speed SDHC card at address b368
[ 0.559467] Key type dns_resolver registered
[ 0.559796] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.559835] ThumbEE CPU extension supported.
[ 0.559878] Registering SWP/SWPB emulation handler
[ 0.560929] registered taskstats version 1
[ 0.562287] slave hdmi.12: modes-blacklisted #0 → 1920x1080@25
[ 0.562316] slave hdmi.12: modes-blacklisted #1 → 832x624@75
[ 0.562517] mmcblk0: mmc0:b368 29.8 GiB
[ 0.565091] mmcblk0: p1 p2
[ 0.567054] of_get_named_gpio_flags: can’t parse gpios property
[ 0.567084] tilcdc 4830e000.fb: No power control GPIO
[ 0.618646] mmc1: BKOPS_EN bit is not set
[ 0.621410] mmc1: new high speed MMC card at address 0001
[ 0.622195] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[ 0.622550] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 0.622951] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 0.625068] mmcblk1: p1 p2
[ 0.627879] mmcblk1boot1: unknown partition table
[ 0.629833] mmcblk1boot0: unknown partition table
[ 0.676789] tilcdc 4830e000.fb: found TDA19988
[ 0.677647] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 0.677664] [drm] No driver support for vblank timestamp query.
[ 0.678076] tilcdc 4830e000.fb: No connectors reported connected with modes
[ 0.678105] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.695425] Console: switching to colour frame buffer device 128x48
[ 0.710083] tilcdc 4830e000.fb: fb0: frame buffer device
[ 0.710103] tilcdc 4830e000.fb: registered panic notifier
[ 0.710144] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 0.759669] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 0.759699] davinci_mdio 4a101000.mdio: detected phy mask fffffffb
[ 0.760703] libphy: 4a101000.mdio: probed
[ 0.760734] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver SMSC LAN8710/LAN8720
[ 0.760966] Detected MACID = 90:59:af:51:3c:e5
[ 0.761075] cpsw 4a100000.ethernet: NAPI disabled
[ 0.762643] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:30:23 UTC (946686623)
[ 0.769907] ALSA device list:
[ 0.769931] #0: TI BeagleBone Black
[ 0.774873] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 0.774890] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 7.115106] usb usb1: usb wakeup-resume
[ 7.115149] usb usb1: usb auto-resume
[ 7.115170] hub 1-0:1.0: hub_resume
[ 7.115209] hub 1-0:1.0: port 1: status 0101 change 0001
[ 7.218652] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 7.218688] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[ 7.324091] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 7.443482] usb 1-1: skipped 1 descriptor after configuration
[ 7.443500] usb 1-1: skipped 4 descriptors after interface
[ 7.443517] usb 1-1: skipped 1 descriptor after endpoint
[ 7.443528] usb 1-1: skipped 4 descriptors after interface
[ 7.443589] usb 1-1: default language 0x0409
[ 7.443765] usb 1-1: udev 2, busnum 1, minor = 1
[ 7.443780] usb 1-1: New USB device found, idVendor=1d6b, idProduct=0104
[ 7.443793] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 7.443804] usb 1-1: Product: BeagleBoneBlack
[ 7.443815] usb 1-1: Manufacturer: Circuitco
[ 7.443826] usb 1-1: SerialNumber: 5C-2913BBBK0762
[ 7.444275] usb 1-1: usb_probe_device
[ 7.444292] usb 1-1: configuration #1 chosen from 1 choice
[ 7.444792] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 7.445218] usb 1-1: adding 1-1:1.1 (config #1, interface 1)
[ 7.445619] usb 1-1: adding 1-1:1.2 (config #1, interface 2)
[ 7.445848] cdc_acm 1-1:1.2: usb_probe_interface
[ 7.445866] cdc_acm 1-1:1.2: usb_probe_interface - got id
[ 7.445886] cdc_acm 1-1:1.2: This device cannot do calls on its own. It is not a modem.
[ 7.454385] cdc_acm 1-1:1.2: ttyACM0: USB ACM device
[ 7.454995] usb 1-1: adding 1-1:1.3 (config #1, interface 3)
[ 7.455429] usb 1-1: adding 1-1:1.4 (config #1, interface 4)
[ 7.455672] usb-storage 1-1:1.4: usb_probe_interface
[ 7.455698] usb-storage 1-1:1.4: usb_probe_interface - got id
[ 7.455942] scsi0 : usb-storage 1-1:1.4
[ 7.456516] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 7.456548] hub 1-0:1.0: port 1 enable change, status 00000503
[ 8.067760] EXT4-fs (mmcblk0p2): recovery complete
[ 8.457544] scsi 0:0:0:0: Direct-Access Linux File-CD Gadget 0308 PQ: 0 ANSI: 2
[ 8.460552] sd 0:0:0:0: [sda] 144522 512-byte logical blocks: (73.9 MB/70.5 MiB)
[ 8.460753] sd 0:0:0:0: [sda] Write Protect is off
[ 8.460805] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[ 8.460981] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 8.467259] sda:
[ 8.468674] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 9.086405] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.086473] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 9.088142] devtmpfs: mounted
[ 9.088414] Freeing init memory: 260K
[ 9.878645] systemd[1]: systemd 196 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX +IMA +SYSVINIT -LIBCRYPTSETUP +GCRYPT +ACL +XZ; angstrom)
[ 9.993406] systemd[1]: Inserted module ‘autofs4’
[ 9.995753] systemd[1]: Set hostname to <beaglebone_itelco>.
[ 10.000832] systemd[1]: Initializing machine ID from random generator.
[ 10.001130] systemd[1]: Installed transient /etc/machine-id file.
[ 10.313922] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. See system logs and ‘systemctl status display-manager.service’ for details.
[ 10.315017] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 10.315476] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.315582] systemd[1]: Expecting device dev-ttyGS0.device…
[ 10.315674] systemd[1]: Expecting device dev-ttyO0.device…
[ 10.315750] systemd[1]: Starting Remote File Systems.
[ 10.315817] systemd[1]: Reached target Remote File Systems.
[ 10.315891] systemd[1]: Starting Delayed Shutdown Socket.
[ 10.316082] systemd[1]: Listening on Delayed Shutdown Socket.
[ 10.316149] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 10.316441] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 10.316545] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 10.316812] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 10.317068] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 10.317748] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.318405] systemd[1]: Starting udev Kernel Socket.
[ 10.318650] systemd[1]: Listening on udev Kernel Socket.
[ 10.319041] systemd[1]: Starting udev Control Socket.
[ 10.319287] systemd[1]: Listening on udev Control Socket.
[ 10.319358] systemd[1]: Starting Swap.
[ 10.319430] systemd[1]: Reached target Swap.
[ 10.319523] systemd[1]: Starting Journal Socket.
[ 10.319856] systemd[1]: Listening on Journal Socket.
[ 10.320010] systemd[1]: Starting File System Check on Root Device…
[ 10.325627] systemd[1]: Starting udev Coldplug all Devices…
[ 10.329780] systemd[1]: Mounting Debug File System…
[ 10.399600] systemd[1]: Started Set Up Additional Binary Formats.
[ 10.439016] systemd[1]: Starting Apply Kernel Variables…
[ 10.451333] systemd[1]: Starting Load Kernel Modules…
[ 10.454516] systemd[1]: Mounted Huge Pages File System.
[ 10.454649] systemd[1]: Started Machine ID first boot configure.
[ 10.454787] systemd[1]: Mounting POSIX Message Queue File System…
[ 10.461824] systemd[1]: Starting udev Kernel Device Manager…
[ 10.469164] systemd[1]: Starting Journal Service…
[ 10.477004] systemd[1]: Started Journal Service.
[ 10.613256] systemd-udevd[97]: starting version 196
[ 10.672718] Bluetooth: Core ver 2.16
[ 10.672810] NET: Registered protocol family 31
[ 10.672820] Bluetooth: HCI device and connection manager initialized
[ 10.672857] Bluetooth: HCI socket layer initialized
[ 10.672874] Bluetooth: L2CAP socket layer initialized
[ 10.672912] Bluetooth: SCO socket layer initialized
[ 10.872210] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 10.872260] Bluetooth: HIDP socket layer initialized
[ 10.989808] NET: Registered protocol family 10
[ 11.040392] NET: Registered protocol family 23
[ 11.054167] IrCOMM protocol (Dag Brattli)
[ 11.113338] Bluetooth: RFCOMM TTY layer initialized
[ 11.113413] Bluetooth: RFCOMM socket layer initialized
[ 11.113424] Bluetooth: RFCOMM ver 1.11
[ 11.593888] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 11.758377] systemd-journald[98]: Received SIGUSR1
[ 15.240923] udc musb-hdrc.0.auto: registering UDC driver [g_multi]
[ 15.241029] gadget: using random self ethernet address
[ 15.241834] usb0: MAC d2:61:a7:cf:25:6e
[ 15.241846] usb0: HOST MAC 90:59:af:51:3c:e7
[ 15.246388] gserial_setup: registered 1 ttyGS device
[ 15.246560] lun0: open backing file: /dev/mmcblk0p1
[ 15.249448] gadget: Mass Storage Function, version: 2009/09/11
[ 15.249468] gadget: Number of LUNs=1
[ 15.249488] lun0: LUN: removable file: /dev/mmcblk0p1
[ 15.249500] gadget: I/O thread pid: 279
[ 15.249520] gadget: adding config #1 ‘Multifunction with RNDIS’/bf8ee59c
[ 15.249578] gadget: adding ‘rndis’/dd1d8c80 to config ‘Multifunction with RNDIS’/bf8ee59c
[ 15.249604] rndis_register: configNr = 0
[ 15.249613] rndis_set_param_medium: 0 0
[ 15.249624] gadget: RNDIS: dual speed IN/ep1in OUT/ep1out NOTIFY/ep2in
[ 15.249638] gadget: adding ‘acm’/dd510980 to config ‘Multifunction with RNDIS’/bf8ee59c
[ 15.249659] gadget: acm ttyGS0: dual speed IN/ep3in OUT/ep2out NOTIFY/ep4in
[ 15.249681] gadget: adding ‘Mass Storage Function’/df7cef40 to config ‘Multifunction with RNDIS’/bf8ee59c
[ 15.249700] gadget: cfg 1/bf8ee59c speeds: high full
[ 15.249710] gadget: interface 0 = rndis/dd1d8c80
[ 15.249719] gadget: interface 1 = rndis/dd1d8c80
[ 15.249729] gadget: interface 2 = acm/dd510980
[ 15.249738] gadget: interface 3 = acm/dd510980
[ 15.249748] gadget: interface 4 = Mass Storage Function/df7cef40
[ 15.249762] gadget: Multifunction Composite Gadget
[ 15.249788] gadget: g_multi ready
[ 15.249911] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 15.250272] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 2
[ 15.250301] musb-hdrc musb-hdrc.0.auto: supports USB remote wakeup
[ 15.250374] usb usb2: default language 0x0409
[ 15.253956] usb usb2: udev 1, busnum 2, minor = 128
[ 15.253980] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 15.253994] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 15.254055] usb usb2: Product: MUSB HDRC host driver
[ 15.254067] usb usb2: Manufacturer: Linux 3.8.13 musb-hcd
[ 15.254078] usb usb2: SerialNumber: musb-hdrc.0.auto
[ 15.254789] usb usb2: usb_probe_device
[ 15.254807] usb usb2: configuration #1 chosen from 1 choice
[ 15.254858] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 15.255002] hub 2-0:1.0: usb_probe_interface
[ 15.255017] hub 2-0:1.0: usb_probe_interface - got id
[ 15.255037] hub 2-0:1.0: USB hub found
[ 15.255063] hub 2-0:1.0: 1 port detected
[ 15.255074] hub 2-0:1.0: standalone hub
[ 15.255084] hub 2-0:1.0: individual port power switching
[ 15.255094] hub 2-0:1.0: no over-current protection
[ 15.255104] hub 2-0:1.0: Single TT
[ 15.255116] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 15.255128] hub 2-0:1.0: power on to power good time: 10ms
[ 15.255152] hub 2-0:1.0: local power source is good
[ 15.255216] hub 2-0:1.0: enabling power on all ports
[ 15.355682] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 15.355917] hub 2-0:1.0: hub_suspend
[ 15.355946] usb usb2: bus auto-suspend, wakeup 1
[ 15.600873] ip_tables: © 2000-2006 Netfilter Core Team
[ 15.785962] net eth0: initializing cpsw version 1.12 (0)
[ 15.787696] libphy: PHY 4a101000.mdio:00 not found
[ 15.792724] net eth0: phy 4a101000.mdio:00 not found on slave 0
[ 15.798918] libphy: PHY 4a101000.mdio:01 not found
[ 15.803933] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 15.824926] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.399174] usb0: eth_open
[ 16.399416] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 17.092228] cfg80211: Calling CRDA to update world regulatory domain
[ 17.092321] cfg80211: World regulatory domain updated:
[ 17.092332] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 17.092344] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.092354] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.092364] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 17.092374] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.092384] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.131616] rndis_host 1-1:1.0: usb_probe_interface
[ 17.131641] rndis_host 1-1:1.0: usb_probe_interface - got id
[ 17.191730] gs_open: ttyGS0 (dd68c800,df68f2c0)
[ 17.191873] gs_close: ttyGS0 (dd68c800,df68f2c0) …
[ 17.191889] gs_close: ttyGS0 (dd68c800,df68f2c0) done!
[ 17.192121] gs_open: ttyGS0 (dd68c800,dd4c18c0)
[ 17.192207] gs_close: ttyGS0 (dd68c800,dd4c18c0) …
[ 17.192220] gs_close: ttyGS0 (dd68c800,dd4c18c0) done!
[ 17.211506] rndis_host 1-1:1.0 eth1: register ‘rndis_host’ at usb-musb-hdrc.1.auto-1, RNDIS device, 90:59:af:5b:ec:ed
[ 17.219255] usbcore: registered new interface driver rndis_host
[ 17.288773] usbcore: registered new interface driver rndis_wlan
[ 17.341579] gs_open: ttyGS0 (dd6c9800,dd684cc0)
[ 17.343829] gs_close: ttyGS0 (dd6c9800,dd684cc0) …
[ 17.343850] gs_close: ttyGS0 (dd6c9800,dd684cc0) done!
[ 17.346234] gs_open: ttyGS0 (dd6c9800,dd4c1740)
