Connecting to WPA(2) using wpa_supplicant and atheros chipset -- ubuntu
Been hacking at this all day, it’s also the 3rd card so I got a few more already invested but not giving up this time
I have a TP LINK TL-WN722N with atheros chipset AR9271
I have a beaglebone black running ubuntu 13.04 arm
I’ve followed upwards of a dozen different tutorials with a number of links below to different references
I can connect to a wireless router with security disabled using iwconfig
I cannot connect to anything with WPA 1 or 2
wpa_supplicant.conf looks like
network={
proto=WPA2
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
ssid=“MYSSID”
#psk=“supersecretpassword”
psk=f2b34bb6b0e3ec1747325fac94ce0476a30911e08cf582df472d5df76e51dcad
so when I run
wpa_supplicant -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -Dwext -c /etc/wpa_supplicant/wpa_supplicant.conf
I get
ioctl[SIOCSIWENCODEEXT]: Invalid argument
ioctl[SIOCSIWSCAN]: Device or resource busy
wlan0: Failed to initiate AP scan
wlan0: Trying to associate with 00:00:00:00:00:00 (SSID=‘MYSSID’ freq=2437 MHz)
ioctl[SIOCSIWFREQ]: Device or resource busy
ioctl[SIOCSIWESSID]: Device or resource busy
wlan0: Association request to the driver failed
wlan0: Associated with 00:00:00:00:00:00
wlan0: WPA: Invalid EAPOL-Key MIC when using TPTK - ignoring TPTK
wlan0: WPA: Could not verify EAPOL-Key MIC - dropping packet
wlan0: Authentication with 00:00:00:00:00:00 timed out.
any ideas?
tried a number of variations of the above, can copy & paste from history if it will be useful
hi Alvin,
on my /etc/network/interfaces i have
auto wlan0
iface wlan0 inet dhcp
wpa-driver wext
wpa-conf /etc/wpa_supplicant.conf
on my wpa_supplicant.conf i have
network={
ssid=“your ssid”
psk=“your pass”
priority=10 # only use if you need to have one or more wifi
restart or
ifdown wlan0
ifup wlan0
if is working.
please let me know if works for you. i did some other thinks but i dont know if it was necessary
Hi Alvin,
this was working
http://askubuntu.com/questions/138472/how-do-i-connect-to-a-wpa-wifi-network-using-the-command-line
but if you would like to use wlan as start your interface and wpa_supplicant.conf must be ok.
