If I plug a Beaglebone into my PC then it appears as a RNDIS device. Can I do the same thing with 2 beaglebones? Eg hook up one beaglebone to another over USB so the appear on a local network? I tried this with Debian and it seemed to be lacking some drivers. Is there something I need to install to get RNDIS host side driver working?
At minimum you would need to power the “client” via barrel jack I’d think.
But there should not be any reason why this wouldn’t work. After all it works on a PC running Debian wheezy, or Lubuntu 14.04. I’ve “tested” both of these personally.
william@eee-pc:~$ uname -a
Linux eee-pc 3.2.0-4-686-pae #1 SMP Debian 3.2.60-1+deb7u3 i686 GNU/Linux
william@eee-pc:~$ lsusb
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 028: ID 0525:a4a2 Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
Bus 001 Device 003: ID 13d3:5071 IMC Networks
Bus 002 Device 002: ID 1cbe:00fd Luminary Micro Inc.
william@eee-pc:~$ lsmod | grep cdc
cdc_acm 17596 0
cdc_subset 12401 0
cdc_ether 12534 0
usbnet 17699 2 cdc_ether,cdc_subset
usbcore 104555 9 ehci_hcd,uhci_hcd,usb_storage,uvcvideo,cdc_acm,usbnet,cdc_ether,cdc_subset
william@eee-pc:~$ ssh william@192.168.7.2
william@192.168.7.2’s password:
Linux arm 3.8.13-bone64.1 #1 SMP Sun Aug 31 13:30:46 MST 2014 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Nov 9 04:05:29 2014 from 192.168.7.1
william@arm:~$ uname -a
Linux arm 3.8.13-bone64.1 #1 SMP Sun Aug 31 13:30:46 MST 2014 armv7l GNU/Linux
william@arm:~$ lsmod
Module Size Used by
g_ether 23544 0
libcomposite 14601 1 g_ether
omap_rng 4066 0
william@arm:~$ uptime
04:09:04 up 52 days, 11:13, 1 user, load average: 0.01, 0.03, 0.05
I tried this and verified:
- both beaglebones work fine on my ubuntu box
- beaglebone connected to another beaglebone doesn’t seem to register the ethernet connection with ifconfig
Any package I need to install on the stock beaglebones in Debian to make this work?
eg:
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr d0:39:72:2b:d6:d8
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
usb0 Link encap:Ethernet HWaddr 52:63:f3:33:13:9f
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::5063:f3ff:fe33:139f/64 Scope:Link
RX packets:3751 errors:0 dropped:0 overruns:0 frame:0
TX packets:1663 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:328097 (320.4 KiB) TX bytes:420111 (410.2 KiB)
root@beaglebone:~# lsusb -v
Bus 001 Device 007: ID 1d6b:0104 Linux Foundation Multifunction Composite Gadget
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0104 Multifunction Composite Gadget
bcdDevice 3.08
iManufacturer 2 Circuitco
iProduct 3 BeagleBoneBlack
iSerial 4 0B-3914BBBK0285
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 164
bNumInterfaces 5
bConfigurationValue 1
iConfiguration 5 Multifunction with RNDIS
bmAttributes 0xc0
Self Powered
MaxPower 2mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 6 Ethernet Networking
bFunctionProtocol 0
iFunction 9 RNDIS
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 255 Vendor Specific (MSFT RNDIS?)
iInterface 7 RNDIS Communications Control
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x00
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0
iInterface 8 RNDIS Ethernet Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 2
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 1 AT-commands (v.25ter)
iFunction 12 CDC Serial
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 10 CDC Abstract Control Model (ACM)
CDC Header:
bcdCDC 1.10
bmCapabilities 0x00
bDataInterface 3
CDC ACM:
bmCapabilities 0x02
line coding and serial state
CDC Union:
bMasterInterface 2
bSlaveInterface 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
iInterface 11 CDC ACM Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 1 Mass Storage
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
