I downloaded & wrote the bone-debian-8.5-lxqt-2gb-armhf-2016-06-19-2gb.img image to a card.
It doesn’t seem to start up the ethernet connection on boot - I have to run sudo systemctl start connman.service from the serial terminal. Here’s the full output.
I tried the 4gb lxqt as well but it seems to be the same.
What am I doing wrong?
James
If you’re talking about the physical ethernet interface, and not g_ether USB ethernet. Then I believe you can setup eth0 in /etc/network/interfaces. From what I’ve read, connman only bothers with wifi, and additional ethernet connections.
