console-image freezes at configuring ppp
Finally I managed to build console image following strictly
instructions from here
http://elinux.org/Beag leboardAndOpenEmbeddedGit
It is going through booting almost all the way, but freezes on
'configuring ppp'
Can I assume that it is a problem on my side or is there a problem
with a stable image?
How to fix it?
Jan
OK, don't worry. I managed to solve the problem.
If anyone have/will have a similar issue please check your bootargs.
Jan
What bootargs do you use? I’ve tried all combination from howto sites and still nothing. I suppose I missed something.
2009/5/10 janek <jan.szymanski@eng.uts.edu.au>
That's a problem in .dev branch that I fixed with commit
  ad4e2d75a9d07bce3ff23fffd51f34b39ef97f68
Just pull the changes from git, and this should fix your issue.
As you wrote. Thanks.
2009/5/26 Ihar Hrachyshka <ihar.hrachyshka@gmail.com>
What's the bootargs fix? Still having the same issues even after doing
a git pull..
hah! pulled the latest git changes and it worked
