BBB’s J1 connects to UART0, and this is used for the serial console.
Is it possible to run the console on a different UART, and/or run another instance of the console on a different UART while concurrently running a console on UART0 ?
If this is possible, the procedure to do it on Debian would be appreciated.
Thanks!
On the bottom of this page will give you a clue:
http://beagleboard.org/support/faq
Why are no boot messages visible on a custom kernel?
- Passing the wrong bootargs to the kernel is a possible cause. Linux kernels >= 2.6.36 are using ttyOn instead ttySn for the serials on OMAP, so set console=ttyO2,115200n8 in U-boot.
John
Yes, you can use different UART and Run
check console ls -l /dev/ttyO*
Result
crw–w---- 1 root tty 248, 0 Jan 1 2000 /dev/ttyO0
crw-rw---- 1 root dialout 248, 1 Nov 10 13:23 /dev/ttyO1
crw-rw---- 1 root dialout 248, 4 Nov 10 14:37 /dev/ttyO4
than which want to open UART port
root@beaglebone:~# minicom -D /dev/ttyO4 -b 9600 for example
31 Ekim 2015 Cumartesi 23:08:01 UTC+2 tarihinde dlchambers yazdı:
BBB's J1 connects to UART0, and this is used for the serial console.
Yes.
No; however, it would not be difficult to add this support.
What is your use-case?
Peter Hurley
when check UART on BBB you will see only UART0 If you want to use other. You must defined others. There is tutorial maybe you can check this
http://tenderlovemaking.com/2014/01/19/enabling-ttyo1-on-beaglebone.html
