I’m testing a new kernel - 3.15.0-rc5-bone0.1 from RCN’s github - for my BBB under Debian. What I’ve found out recently is lack of /sys/devices/bone_capemgr.* directory. Also my atempts to turn off hdmi via uEnv file fizzle out. Is it me doing something wrong or this is how it should be? Is there a way to get back my control over uarts, and ability to turn off hdmi under new kernel?
I have switched to the image you’ve recommended and succeeded only with enabling ttyO1, The other ones are not enabled. I’ve defined them like that in uEnv.txt: cape=ttyO1 cape=ttyO4 cape=ttyO2 cape=ttyO5
Is there a way to disable HDMI? cape_disable=capemgr.disable_
partno=BB-BONELT-HDMI,BB-BONELT-HDMIN in uEnv.txt is not working, but since you said that capemgr had not been ported to new kernel I’m not surprised. If it’s not possible to do in some other way, which is the latest system where capemgr works?
Ok, I managed to switch off hdmi by removing all hdmi-related entries from dts files and recompile the kernel. That’s not the most elegant solution for sure, but it works;) The uarts’ issue still waits for the solution.
