Controlling EHCI port from userland
Hi everyone.
I want to be able to do two things from userland:
1) Turn off power to the EHCI port
2) Reset the EHCI USB port PHY chip
After reading through the docs and kernel code, I know it's possible to do
both from the kernel. For those interested: the power can be turned off through
the nEN_USB_PWR signal from the TPS65950 (through the I2C interface), and the
PHY chip can be reset by toggling it's enable pin (connected to GPIO147).
These things are done in arch/arm/mach-omap2/board-omap3beagle.c and
drivers/usb/host/ehci-omap.c.
However, I don't know how to do this from userland. I can't to it through the
sysfs gpio interface because it won't let me export 147 (presumedly because
it's already been requested by some other part of the kernel).
I'm using a 2.6.31 kernel, and it's a RevC3 beagle.
Is this currently possible? Is there a sysfs interface somewhere?
I'd also like to be able to do the same to the OTG port, but let's start with
the EHCI, and yes, I'm using external power ;-).
  Cameron.
I am booting kernel from Nand and i followed steps as mentioned in below link
BeagleBoardNAND - eLinux.org
after booting it from Nand it is stoped, here is the log
40T�H�H�U���ᅁInstruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Loading u-boot.bin from nand
U-Boot 2009.01-dirty (Feb 19 2009 - 12:22:31)
I2C: ready
OMAP3503-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
MUSB: using high speed
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Serial #55ba0002000000000403193412013014
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
## Booting kernel from Legacy Image at 80000000 …
Image Name: Linux-2.6.29-rc3-omap1
Data Size: 1787480 Bytes = 1.7 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux… done, boo
ting the kernel.
Please help me solve this issue
–Sanjeev
Anyone got any ideas where to look?
Docs? Email list posts? Crop circles?
Is this what you are looking for: http://marc.info/?l=linux-usb-users&m=116827193506484&w=2
/Quist
That's seems to be pretty much it. If you're following this, the usbreset
program *does* still work with a 2.6.31 kernel, and the usb suspend stuff is
about right, except that you need to echo "suspend" or "on" to power/level,
instead of 0/2 to power/state.
I'll report back on whether suspending the ehci root hub actually drops turns
off the 5V rail (to save power), and whether the usbreset can bring a crashed
EHCI port back to life.
Cameron.
Forgot to say: "Thanks, Quist"!
Bad news. Once the EHCI chip has crashed, usbreset won't work with it anymore:
root@beagleboard:~# ./usbreset /dev/usbdev2.1
Resetting USB device /dev/usbdev2.1
Error in ioctl: Is a directory
But /dev/usb2.1 is not a directory:
root@beagleboard:~# ls -l /dev/usbdev*
crw-rw---- 1 root root 189, 0 2009-11-10 01:43 /dev/usbdev1.1
crw-rw---- 1 root root 189, 1 2009-11-10 01:43 /dev/usbdev1.2
crw-rw---- 1 root root 189, 128 2009-11-10 01:43 /dev/usbdev2.1
I guess it's back to reading kernel source....
Cameron.
Also, suspending the high speed root hub does *not* disable the 5V power
rail.
Can anyone recommend an introduction to adding sysfs features to a kernel
driver?
Cameron.
Cameron:
You've probably already moved (way) beyond this point, but does
adding "gpio_export(147, 0);" to the init function in board-
omap3beagle.c cause gpio147 to be available by default in the /sys/
class/gpio directory? This worked for me when I could no longer
successfully do "echo 170 > export" in that directory (for the DVI-
Framer).
-Bill Bock
DFT
