Could I get CDC NCM driver for windows 10 (BeagleBone AI)
My device manager of windows 10 cannot load CDC NCM driver when connect usb with BeagleBone Black.
When I connect WIndos10 by USB cable with BeagleBone AI, But i cannot send ping 8.8.8.8 byte.
I cannot use network of beagleBone AI, Just I wanna to use USB Network with CDC NCM (USB Network Driver) .
But My windows10(PC) cannot load CDC NCM driver on Device Manger.
Could i provide CDC NCM driver for windows10.
Regards
Jisu
  To my knowledge, Windows uses RNDIS, not CDC (note: my system, with
both a BBB and a BBAI connected, shows two "CDC ECM" failure to load, and
under network adapters shows "Linux USB Ethernet/RNDIS Gadget" [the BBB]
and "Remote NDIS Compatible Device #2")
ping 8.8.8.8 byte.
  You are unclear... WHICH device are you entering that command on.
  So far as I know, CDC drivers are not available for Windows.
  If, from the Windows computer, you can get a result from pinging the BB
you have a working Windows<>BB connection.
  However -- by default -- Windows does NOT gateway traffic from client
devices to ITS network connection. You have to enable/configure "Internet
Connection Sharing" to route from the beagle network adapter to the host
computer Internet adapter. I can't help with that -- I connect Beagles to
my router using Ethernet cables...
