Could not boot from sd card
Hello everyone!
I’m flashing a few BeagleBone Blacks, but I’m having an issue with one of them:
It doesn’t boot from the SD card, and therefore doesn’t flash the eMMC. Without the SD card, it boots normally.
The SD card was created on another BeagleBone, and it works fine with other devices.
Here’s the log:
U-Boot SPL 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500)
Trying to boot from MMC2
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500), Build: jenkins-github_Bootloader-Builder-139
CPU  : AM335X-GP rev 2.1
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
1833 bytes read in 35 ms (50.8 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r72 ...
11358720 bytes read in 765 ms (14.2 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r72/am335x-boneblack-uboot-univ.dtb ...
210757 bytes read in 85 ms (2.4 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
654 bytes read in 806 ms (0 Bytes/s)
uboot_overlays: unable to find [mmc 0:1 BB-UART1-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 BB-UART4-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 BB-W1-P9.12-00A0.dtbo]...
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
1614 bytes read in 1172 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo ...
5330 bytes read in 798 ms (5.9 KiB/s)
loading /boot/initrd.img-5.10.168-ti-r72 ...
6846803 bytes read in 477 ms (13.7 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher] ...
debug: [bootz 0x82000000 0x88080000:687953 88000000] ...
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f978000, end 8ffff953 ... OK
   Loading Device Tree to 8f8e0000, end 8f977fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-ti-r72 (voodoo@rpi4b4g-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Sat Sep 30 03:37:21 UTC 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 21 pages/cpu s54604 r8192 d23220 u86016
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait init=/usr/sbin/init-beagle-flasher
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 436548K/522240K available (15360K kernel code, 1448K rwdata, 4040K rodata, 1024K init, 446K bss, 36540K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000031] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000420] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.002576] Console: colour dummy device 80x30
[    0.002669] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.048476] pid_max: default: 32768 minimum: 301
[    0.049085] LSM: Security Framework initializing
[    0.049209] Yama: becoming mindful.
[    0.049512] AppArmor: AppArmor initialized
[    0.049533] TOMOYO Linux initialized
[    0.049730] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.049749] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.051449] CPU: Testing write buffer coherency: ok
[    0.051538] CPU0: Spectre v2: using BPIALL workaround
[    0.072903] Setting up static identity map for 0x80100000 - 0x80100060
[    0.080495] rcu: Hierarchical SRCU implementation.
[    0.089770] EFI services will not be available.
[    0.100505] smp: Bringing up secondary CPUs ...
[    0.100529] smp: Brought up 1 node, 1 CPU
[    0.100543] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.100554] CPU: All CPU(s) started in SVC mode.
[    0.101486] devtmpfs: initialized
[    0.144836] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.145353] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.145398] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.149270] pinctrl core: initialized pinctrl subsystem
[    0.150453] DMI not present or invalid.
[    0.151418] NET: Registered protocol family 16
[    0.154636] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.195387] l3-aon-clkctrl:0000:0: failed to disable
[    0.196166] audit: initializing netlink subsys (disabled)
[    0.197729] thermal_sys: Registered thermal governor 'fair_share'
[    0.197743] thermal_sys: Registered thermal governor 'bang_bang'
[    0.197760] thermal_sys: Registered thermal governor 'step_wise'
[    0.197771] thermal_sys: Registered thermal governor 'user_space'
[    0.197782] thermal_sys: Registered thermal governor 'power_allocator'
[    0.198705] cpuidle: using governor ladder
[    0.198791] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.198831] cpuidle: using governor menu
[    4.801888] hw-breakpoint: debug architecture 0x4 unsupported.
[    4.850387] Kprobes globally optimized
[    4.872906] raid6: skip pq benchmark and using algorithm neonx8
[    4.872939] raid6: using neon recovery algorithm
[    4.880598] iommu: Default domain type: Translated
[    4.885412] SCSI subsystem initialized
[    4.889033] usbcore: registered new interface driver usbfs
[    4.889133] usbcore: registered new interface driver hub
[    4.889198] usbcore: registered new device driver usb
[    4.890390] mc: Linux media interface: v0.10
[    4.890448] videodev: Linux video capture interface: v2.00
[    4.890672] pps_core: LinuxPPS API ver. 1 registered
[    4.890688] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    4.890737] PTP clock support registered
[    4.893247] NetLabel: Initializing
[    4.893275] NetLabel:  domain hash size = 128
[    4.893285] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    4.893419] NetLabel:  unlabeled traffic allowed by default
[    4.894655] clocksource: Switched to clocksource dmtimer
[    5.956218] VFS: Disk quotas dquot_6.6.0
[    5.956374] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    5.956691] FS-Cache: Loaded
[    5.957101] CacheFiles: Loaded
[    5.958108] AppArmor: AppArmor Filesystem Enabled
[    5.971772] NET: Registered protocol family 2
[    5.972066] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    5.973596] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    5.973905] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    5.973979] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    5.974042] TCP: Hash tables configured (established 4096 bind 4096)
[    5.974757] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    5.974874] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    5.974912] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    5.975186] NET: Registered protocol family 1
[    5.988646] RPC: Registered named UNIX socket transport module.
[    5.988672] RPC: Registered udp transport module.
[    5.988683] RPC: Registered tcp transport module.
[    5.988693] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    5.988711] NET: Registered protocol family 44
[    5.989587] Trying to unpack rootfs image as initramfs...
[    6.354213] Freeing initrd memory: 6688K
[    6.355385] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    6.361189] Initialise system trusted keyrings
[    6.361685] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    6.370074] zbud: loaded
[    6.378230] NFS: Registering the id_resolver key type
[    6.378307] Key type id_resolver registered
[    6.378320] Key type id_legacy registered
[    6.378525] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    6.378543] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    6.378594] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    6.379866] fuse: init (API version 7.32)
[    6.469157] NET: Registered protocol family 38
[    6.469189] xor: automatically using best checksumming function   neon
[    6.469204] Key type asymmetric registered
[    6.469217] Asymmetric key parser 'x509' registered
[    6.469302] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    6.473699] io scheduler mq-deadline registered
[    7.207655] ti-sysc: probe of 44e31000.target-module failed with error -16
[    7.345719] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    7.401790] ti-sysc: probe of 48040000.target-module failed with error -16
[    7.620347] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    7.745163] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    8.285007] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    8.285058] edma 49000000.dma: TI EDMA DMA engine driver
[    8.316140] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    8.317619] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    8.317646] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    8.339341] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    8.344303] printk: console [ttyS0] disabled
[    8.344428] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[    9.199784] printk: console [ttyS0] enabled
[    9.206045] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 27, base_baud = 3000000) is a 8250
[    9.216690] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 28, base_baud = 3000000) is a 8250
[    9.227526] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 43, base_baud = 3000000) is a 8250
[    9.237790] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 44, base_baud = 3000000) is a 8250
[    9.248268] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 45, base_baud = 3000000) is a 8250
[    9.261766] omap_rng 48310000.rng: Random Number Generator ver. 20
[    9.268450] random: crng init done
[    9.386817] loop: module loaded
[    9.390337] at24 2-0054: supply vcc not found, using dummy regulator
[    9.426105] at24 2-0055: supply vcc not found, using dummy regulator
[    9.462105] at24 2-0056: supply vcc not found, using dummy regulator
[    9.498047] at24 2-0057: supply vcc not found, using dummy regulator
[    9.601296] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[    9.610043] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    9.616645] cpsw 4a100000.ethernet: ALE Table size 1024
[    9.622109] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    9.629521] cpsw 4a100000.ethernet: Detected MACID = 18:2c:65:13:a7:be
[    9.639809] usbcore: registered new interface driver smsc95xx
[    9.648397] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[    9.657251] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    9.672349] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[    9.681312] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    9.697035] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    9.703843] ehci-platform: EHCI generic platform driver
[    9.709784] ehci-omap: OMAP-EHCI Host Controller driver
[    9.729328] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    9.735013] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    9.742836] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    9.751173] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.758450] usb usb1: Product: MUSB HDRC host driver
[    9.763456] usb usb1: Manufacturer: Linux 5.10.168-ti-r72 musb-hcd
[    9.769682] usb usb1: SerialNumber: musb-hdrc.1
[    9.775246] hub 1-0:1.0: USB hub found
[    9.779172] hub 1-0:1.0: 1 port detected
[    9.798198] omap_rtc 44e3e000.rtc: registered as rtc0
[    9.804205] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[    9.815205] i2c /dev entries driver
[    9.824681] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    9.832467] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    9.841077] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
[    9.850916] cpuidle: enable-method property 'ti,am3352' found operations
[    9.859812] sdhci: Secure Digital Host Controller Interface driver
[    9.866108] sdhci: Copyright(c) Pierre Ossman
[    9.870506] sdhci-pltfm: SDHCI platform and OF driver helper
[    9.886869] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    9.894752] ledtrig-cpu: registered to indicate activity on CPUs
[    9.903958] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    9.910234] omap-aes 53500000.aes: will run requests pump with realtime priority
[    9.922079] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    9.928575] omap-sham 53100000.sham: will run requests pump with realtime priority
[    9.941151] hid: raw HID events driver (C) Jiri Kosina
[    9.946850] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    9.956626] usbcore: registered new interface driver usbhid
[    9.962760] usbhid: USB HID core driver
[    9.967274] remoteproc remoteproc0: wkup_m3 is available
[    9.982756] NET: Registered protocol family 10
[   10.023290] mmc1: new high speed MMC card at address 0001
[   10.040188] mmcblk1: mmc1:0001 MK2704 3.53 GiB
[   10.051596] mmcblk1boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[   10.063565] mmcblk1boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[   10.073030] mmcblk1rpmb: mmc1:0001 MK2704 partition 3 512 KiB, chardev (240:0)
[   10.094168]  mmcblk1: p1
[   10.104030] Segment Routing with IPv6
[   10.108174] mip6: Mobile IPv6
[   10.113794] NET: Registered protocol family 17
[   10.124377] Key type dns_resolver registered
[   10.129607] mpls_gso: MPLS GSO support
[   10.133756] ThumbEE CPU extension supported.
[   10.138158] Registering SWP/SWPB emulation handler
[   10.143381] omap_voltage_late_init: Voltage driver support not added
[   10.150820] registered taskstats version 1
[   10.154997] Loading compiled-in X.509 certificates
[   10.160000] zswap: loaded using pool lzo/zbud
[   10.169284] Key type .fscrypt registered
[   10.173346] Key type fscrypt-provisioning registered
[   10.185620] Btrfs loaded, crc32c=crc32c-generic
[   10.190416] AppArmor: AppArmor sha1 policy hashing enabled
[   10.216994] OMAP GPIO hardware version 0.1
[   10.251486] tps65217-pmic: Failed to locate of_node [id: -1]
[   10.268333] tps65217-bl: Failed to locate of_node [id: -1]
[   10.277047] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[   10.284444] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[   10.303051] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[   10.310110] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[   10.317343] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[   10.331012] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[   10.338680] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[   10.346252] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[   10.353815] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[   10.361625] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[   10.369261] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[   10.376833] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[   10.384375] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[   10.391930] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[   10.399494] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[   10.407114] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[   10.414803] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[   10.422438] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[   10.430079] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[   10.437720] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[   10.445347] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[   10.453011] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[   10.460641] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[   10.468291] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[   10.475926] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[   10.483541] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[   10.491208] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[   10.498841] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[   10.506484] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[   10.514253] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[   10.521893] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[   10.529537] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[   10.537193] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[   10.544820] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[   10.552451] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[   10.560091] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[   10.567727] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[   10.575365] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[   10.582988] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[   10.590643] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[   10.598252] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[   10.605904] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[   10.613543] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[   10.621172] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[   10.628796] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[   10.636417] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[   10.644051] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[   10.651686] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[   10.659319] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[   10.666973] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[   10.674658] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[   10.682293] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[   10.689921] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[   10.697541] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[   10.705173] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[   10.712807] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[   10.720430] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[   10.728078] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[   10.735729] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[   10.743373] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[   10.751000] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[   10.758642] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[   10.766268] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[   10.774201] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[   10.781906] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[   10.789559] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[   10.797186] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[   10.804828] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[   10.812459] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[   10.820100] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[   10.827734] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[   10.835358] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[   10.842991] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[   10.850611] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[   10.858090] gpio-of-helper ocp:cape-universal: ready
[   10.902697] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[   10.927743] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[   10.946439] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[   10.956821] sdhci-omap 48060000.mmc: Got CD GPIO
[   10.961941] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[   11.001729] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[   11.081514] tda998x 0-0070: found TDA19988
[   11.089941] tilcdc 4830e000.lcdc: bound 0-0070 (ops 0xc10ac1fc)
[   11.097376] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[   11.105302] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[   11.113617] of_cfs_init
[   11.116688] tilcdc 4830e000.lcdc: [drm] Cannot find any crtc or sizes
[   11.123294] of_cfs_init: OK
[   11.130136] Freeing unused kernel memory: 1024K
[   11.135605] Run /init as init process
Loading, please wait...
Starting version 247.3-7+deb11u4
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  /dev/mmcblk0p1 does not exist.  Dropping to a shell!
(initramfs)
might be a compatibility between u-boot in emmc and the OS on the sdcard
try holding the ‘user’ button during boot with the sdcard.
unfortunately no success. I´m able to connect via putty and USB IP 192.168.7.2
I upgrade the OS on the emmc, clear many logs (df show zero space available)
But still boot from emmc(?):
with pressed boot button:
U-Boot SPL 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
Trying to boot from MMC1
U-Boot 2022.04-gbaca7b46 (Jan 15 2024 - 19:59:28 +0000)
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
Loading Environment from EXT4... Board: BeagleBone Black
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Scanning mmc 1:1...
Scanning disk mmc@48060000.blk...
Disk mmc@48060000.blk not ready
Scanning disk mmc@481d8000.blk...
Found 2 disks
No EFI system partition
WARNING: could not set serial-number FDT_ERR_BADSTRUCTURE.
ERROR: root node setup failed
 - must RESET the board to recover.
ERROR: failed to process device tree
2005 bytes read in 3 ms (652.3 KiB/s)
loading /boot/vmlinuz-4.19.94-ti-r42 ...
10095592 bytes read in 637 ms (15.1 MiB/s)
loading /boot/dtbs/4.19.94-ti-r42/am335x-boneblack-uboot-univ.dtb ...
162266 bytes read in 14 ms (11.1 MiB/s)
Found 0 extension board(s).
654 bytes read in 5 ms (127 KiB/s)
1614 bytes read in 29 ms (53.7 KiB/s)
5330 bytes read in 4 ms (1.3 MiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo ...
3653 bytes read in 7 ms (508.8 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r42 ...
7049850 bytes read in 451 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:6b927a 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x9a0be8 ]
   Loading Ramdisk to 8f946000, end 8ffff27a ... OK
   Loading Device Tree to 8f8ba000, end 8f945fff ... OK
Starting kernel ...
[    0.002151] timer_probe: no matching timers found
[    0.192208] l4_wkup_cm:clk:0010:0: failed to disable
[    1.439256] omap_voltage_late_init: Voltage driver support not added
[    1.471101] pinctrl-single 44e10800.pinmux: pin PIN108 already requested by ocp:A15_pinmux; cannot claim for 0-0070
[    1.481739] pinctrl-single 44e10800.pinmux: pin-108 (0-0070) status -22
[    1.488415] pinctrl-single 44e10800.pinmux: could not request pin 108 (PIN108) from group nxp_hdmi_bonelt_pins  on device pinctrl-single
[    1.500754] tda998x 0-0070: Error applying setting, reverse things back
rootfs: recovering journal
rootfs: clean, 86960/231536 files, 558917/924672 blocks
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster IoT Image 2020-04-06
Support: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
is there maybe another way to flash the eMMC? From USB or maybe live?
from your first boot log
from your second boot log
correct me if i’m wrong, the first boot log is from the sdcard boot (on a working BBB) and the second boot log is from the emmc ??
maybe @RobertCNelson can provide soom input
i still think the emmc u-boot is to old to work with 5.10 linux kernel
at risk of bricking the BBB if the sdcard does not work, you could boot from emmc and then dd zero’s to the emmc. then it should boot from the sdcard
another question: is there other hardware attached to the BBB ??
Hello!
i didn´t notice the different line at the beginning. He always boot from eMMC, because the os on sd card is complete different.
When I start without press boot button, I get U-Boot 2019
When I start with pressing boot button, I get U-Boot 2022
Attached again with holding the boot button:
DRAM:  512 MiB
BeagleBone Black:
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Found 2 disks
BootOrder not defined
EFI boot manager: Cannot load any image
162266 bytes read in 15 ms (10.3 MiB/s)
7049850 bytes read in 450 ms (14.9 MiB/s)
Starting kernel ...
[    0.002160] timer_probe: no matching timers found
[    0.196234] l4_wkup_cm:clk:0010:0: failed to disable
[    1.439367] omap_voltage_late_init: Voltage driver support not added
[    1.471190] pinctrl-single 44e10800.pinmux: pin PIN108 already requested by ocp:A15_pinmux; cannot claim for 0-0070
[    1.481830] pinctrl-single 44e10800.pinmux: pin-108 (0-0070) status -22
[    1.488511] pinctrl-single 44e10800.pinmux: could not request pin 108 (PIN108) from group nxp_hdmi_bonelt_pins  on device pinctrl-single
[    1.500851] tda998x 0-0070: Error applying setting, reverse things back
rootfs: clean, 86962/231536 files, 559126/924672 blocks
beaglebone login:
Hello!
maybe you have a complete dd command for me?
no, there is no other hardware connected. I boot with USB Power up
first do a lsblk, this will show the mmcblkx devices available
example of my BBB
mmcblk1 179:0 0 3.6G 0 disk
mmcblk1boot0 179:256 0 4M 1 disk
mmcblk1boot1 179:512 0 4M 1 disk
mmcblk0 179:768 0 14.5G 0 disk
└─mmcblk0p1 179:769 0 14.5G 0 part /
mmcblk0 is sdcard (notice the ‘/’ that is the rootfs mount)
mmcblk1 is emmc
to delete the u-boot in emmc (i.e. the partition table)
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=2
so holding the S2 button during boot, did have it boot from sdcard, based on the logs you have posted.
i also noticed in the
log,
you have
not sure why
i haven’t used a flasher image lately, but i thought it was another line in the uEnv.txt file that ya uncomment.
take a look at the uEnv.txt file on the sdcard, there should be a line you uncomment to get it to flash the emmc.
Thank you, now he did not booting in debian OS from sd card anymore.
Without sd-card just see CCCCCC writing in console
With sd-card (no matter if button pressed or not) I get this log now:
DRAM:  512 MiB
Reset Source: Global external warm reset has occurred.
BeagleBone Black:
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
Couldn't find partition mmc 1:2
Couldn't find partition mmc 1:3
Couldn't find partition mmc 1:4
Couldn't find partition mmc 1:5
Couldn't find partition mmc 1:6
Couldn't find partition mmc 1:7
starting USB...
Bus usb@47401800: Port not available.
USB is stopped. Please issue 'usb start' first.
starting USB...
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.0.47 (147 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-18-2c-65-13-a7-be
Retrieving file: pxelinux.cfg/C0A8002F
Retrieving file: pxelinux.cfg/default-arm-am33xx-am335x
Config file not found
starting USB...
BOOTP broadcast 1
DHCP client bound to address 192.168.0.47 (139 ms)
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.0.47 (784 ms)
some progress, next
i’ve seen this type of failure log recently on this forum, not sure what the resolution was.
are you using a downloaded image from beagleboard site??
how are you writing this image to the sdcard??
if not using balenaEthcher for writing image to sdcard, can you try to use it, they have downloads for both windows and linux
I usually just break uboot. Need to connect to debug port and stop uboot and just erase some of emmc. Then boot with the IoT image that installs its self, it will laydown a uboot that is configured for the IoT image.
he already wiped the emmc,
my thinking is that how he’s installing the image on the sdcard is the issue.
I know that IoT image works, seems like it has a newer version uboot. It would help of OP would post the link to the exact image they are using.
Hello!
Many thanks to your help.
I flash month ago a beaglebone (Can´t remember the used images file). Configure the BBB and then copy the eMMC to the sd-card.
Then I write the sd-card with win32DiskImager to a file and write back to 4 other sd-card`s
I flashed 30 BBB without problems (with the 5 sd-card`s at same time).
Only this one has the problem.
Maybe the installed OS is different to all other 29 BBB.
Right now I can only boot from the sd-card (no matter from which of the 5 pieces. All are same)
In the console I can read the version:
=> version
arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110
Should I flash a new sd-card? Which image you suggest?
EDIT: I download now this image to sd-card:
BBB-blank-debian-9.5-iot-armhf-2018-10-07-4gb.img
With this is now flashing.
I wait until finished, but what then? :slight_smile:
Should I try again to flash my own sd-card or need I prepare the eMMC for a correct version?
