I’m trying to cross compile Qt SDK for BBB (with Ubuntu or Debian).
I managed to compile it well with -embedded arm option …
But with this option I have to execute my programs with -qws option… And I have some issues with the mouse pointer, it doesn’t clic where I want and it move my application windows … I guess it’s because I use a touch screen and the calibration needs X11 maybe…??
So I would like to cross compile Qt without the -embedded arm option to support and use X11 … but I need X11 libs for ARM to do this… so I tried a chroot on a minimal arm file system ubuntu on my PC desktop and link to this librairy in the qmake.conf and made this:
./configure -opensource -confirm-license -prefix /usr/local/Qt-4.8.5-arm-X11 -xplatform linux-arm-gnueabi-g++
But it doesn’t work…
I’ve got this error message:
Basic XLib functionality test failed!
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_X11 and QMAKE_LIBDIR_X11 in /home/franck/qt-everywhere-opensource-src-4.8.5/mkspecs/linux-arm-gnueabi-g++.
and here is my qmake.conf:
franck@VB:~/qt-everywhere-opensource-src-4.8.5/mkspecs/linux-arm-gnueabi-g++$ cat qmake.conf
qmake configuration for building with arm-linux-gnueabi-g++
MAKEFILE_GENERATOR = UNIX
TARGET_PLATFORM = unix
TEMPLATE = app
CONFIG += qt warn_on release incremental link_prl gdb_dwarf_index
QT += core gui
QMAKE_INCREMENTAL_STYLE = sublibinclude(…/common/linux.conf)
include(…/common/gcc-base-unix.conf)
include(…/common/g+±unix.conf)QMAKE_INCDIR_X11 +=/home/franck/chroot-armhf/fs/usr/include/X11/
QMAKE_LIBDIR _X11 +=/home/franck/chroot-armhf/fs/usr/lib/arm-linux-gnueabihf/modifications to g++.conf
QMAKE_CC = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-gcc
QMAKE_CXX = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-g++
QMAKE_LINK = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-g++
QMAKE_LINK_SHLIB = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-g++modifications to linux.conf
QMAKE_AR = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ar cqs
QMAKE_OBJCOPY = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-objcopy
QMAKE_STRIP = /home/franck/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-stripload(qt_config)
So I decided to compile Qt SDK directly in the arm file system “chrooted”:
I made
./configure -opensource -confirm-license -prefix /usr/local/Qt-4.8.5-arm-X11 -no-qt3support -nomake demos -nomake examples
Now I’ve got this error message:
make[1]: *** […/…/lib/libQtCore.so.4.8.5] Error 1
make[1]: Leaving directory `/home/ubuntu/qt-everywhere-opensource-src-4.8.5/src/corelib’
make: *** [sub-corelib-make_default-ordered] Error 2
If someone has an idea… ^^
