I hope someone please can help me with my problem. I’m trying to build the uImage for a Beagleboard-xM Rev C, but I have a problem when I compile the kernel, I followed this guide “http://www.ibm.com/developerworks/library/l-arm-toolchain/” to install the toolchain and when I execute this command “#make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- distclean” I got this mesage:
make: arm-angstrom-linux-gnueabi-gcc: No se encontró el programa
make[2]: arm-angstrom-linux-gnueabi-gcc: No se encontró el programa
I checked out the route to this command and it’s ok, I run: “#which arm-angstrom-linux-gnueabi-gcc” and the answer was: “/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc”, also my path (echo $PATH) was like this: “/usr/local/angstrom/arm/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games” so everything is ok, but I don’t understand why this arm-angstrom-linux-gnueabi-gcc error.
Please someone give me a hand with this, I don’t have much experience with the beagleboard.
Thanks.
I hope someone please can help me with my problem. I'm trying to
when I compile the kernel, I followed this guide "
IBM Developer; to
That link talks about installing Code Sourcery's (quite old) toolchain.
You're then talking about Angstrom's toolchain. I'm a bit confused.
Which one would you like to use?
install the toolchain and when I execute this command "#make ARCH=arm
CROSS_COMPILE=arm-angstrom-linux-gnueabi- distclean" I got this
mesage:
Is that '#' the root prompt? Or just an example?
If so, please don't build kernels as root. It's not needed.
*make: arm-angstrom-linux-gnueabi-gcc: No se encontró el programa*
*make[2]: arm-angstrom-linux-gnueabi-gcc: No se encontró el programa*
I checked out the route to this command and it's ok, I run: "#which
arm-angstrom-linux-gnueabi-gcc" and the answer was: "
/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc", also my
path (echo $PATH) was like this: "*/usr/local/angstrom/arm/bin*
:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"
so everything is ok, but I don't understand why this
What happens if you pass the full path to your cross compiler angstrom
toolchain binaries like:
CROSS_COMPILE=/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-
when you 'make'?
-Andrew
Hi Andrew, thanks for answering so fast.
In that guide I just follow the steps, I don’t use those files, the toolchain I’m using is “angstrom-2011.03-i686-linux-armv7a-linux-gnueabi-toolchain.tar.bz2”.
The # is the root prompt, I thought it didn’t matter. I’ve just made all the process as user, as you suggest, (as $, not #) and the result is the same.
When I use the complete address: “CROSS_COMPILE=/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-” as you said I got this:
make: /usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc: No se encontró el programa
make[2]: /usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc: No se encontró el programa
There’s no change and I did it as root and user, I don’t know what else I can do, please help.
2012/12/27 Andrew Bradford <andrew@bradfordembedded.com>
In that guide I just follow the steps, I don't use those files, the
toolchain I'm using is "
angstrom-2011.03-i686-linux-armv7a-linux-gnueabi-toolchain.tar.bz2".
The # is the root prompt, I thought it didn't matter. I've just made
is the same.
When I use the complete address: "
CROSS_COMPILE=/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-"
*make: /usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc: No
*make[2]: /usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc:
Are you sure you have untarred the tarball correctly as per the
instructions on the angstrom site?
When I download and extract to my home dir, it works fine for me.
I made a gist [1]. If you don't extract the tarball like the
instructions say, gcc may get confused later in the kernel build
process (I stopped it short) but you should get past doing a 'make
distclean' without issue.
[1]: https://gist.github.com/4397281
I'm sorry, I'm not sure how much more I can help you.
There's no change and I did it as root and user, I don't know what
Being root or not shouldn't impact this, it's just not safe nor required
to be root in order to build a kernel.
-Andrew
In the instructions say:
$ **bunzip2** angstrom-2011.03-i686-linux-armv7a-linux-gnueabi-toolchain.tar.bz2
$ **tar -xvf** angstrom-2011.03-i686-linux-armv7a-linux-gnueabi-toolchain.tar
and that’s what I did, then I apply a enviroment-setup file wich modified the PATH. I did this at work and everything worked fine but when I tried it in my home PC I got this problems and both PCs have the same OS Ubuntu 11.04.
Thanks anyway for your help Andrew, I’ll keep trying to resolve this.
2012/12/28 Andrew Bradford <andrew@bradfordembedded.com>
