I needed to build a “newer” version of the Linux kernel for my beagle bone black since the kernel that came with board has this weird USB power issue ( uname : 3.8.13 - bone47).
My development environment is a virtual Box running Debian.(3.16.0-4-amd64)
As part of those instructions, the cross compiler toolchain I installed was Linaro GCC 5.3-2016.02. The build_kernel.sh script actually (re)downloads this exact toolchain and uses it to build the kernel.
Now I have started to write code for my beagle bone application. I require to use Qt. I was able to the build the Qt library statically using the above linaro compiler. But when I try to link my application code against the build Qt library I get missing library link errors for libicuio, libicui18n, libicuuc, libicudata.
How do I get the ICU libraries for the linaro compiler?
I could use the debain multi-arch to apt-get the cross-compiler toolchain and icu stuff…but then I need to get the build_kernel.sh script to point to this compiler. Has anyone done this?
I needed to build a "newer" version of the Linux kernel for my beagle bone
1. How do I get the ICU libraries for the linaro compiler?
"it's" best to use your system compiler for qt libraries..
2. I could use the debain multi-arch to apt-get the cross-compiler toolchain
and icu stuff...but then I need to get the build_kernel.sh script to point
in the system.sh file in the kernel build script, just set CC=...
