Hi
I could not find any spec’s on the current drain of the AIN on the BBB. Any help would be appretiated.
yours
magu_
Hi
yours
magu_
Did you look at the processor datasheet?
Hi Gerald
Thank you for your Answer. I did look it up but only found Buffer strength (25 mA) which doesn’t seem to be right, since it would be rather high.
yours magu_
OK. I don’t have an answer for you. As these are high impedance inputs. I would not expect it to be much, especially at the rated voltage of 1.8V…
