Custom Beagleboneblack Board Kernel Restart Issue
Hi folks,
I want to use Beagleboneblack Image to our custom designed board thats same as BeagleboneBlack.
We just excluded the HDMI, Ethernet and P8-P9 headers . Therefore Our board didn’t havea a TDA19988 ann LAN8710.
I also solder 24LC32A EEPROM from the other BBB to our custom board.
When i try to boot from SD Card, kernel decompression was corrupt and then system start again .
What kind of modifications i need to make for able to use the official relased BBB Images(Latest Software Images - BeagleBoard) with my custom board?
Can i disable Ethernet from uEnv.txt?
I also share with boot message of my custom board and BBB.
Best regards.
debian@BeagleBone:~$ uname -a
Linux BeagleBone 5.10.168-ti-r71 #1bullseye SMP PREEMPT Fri Sep 1 04:05:07 UTC 2023 armv7l GNU/Linux
debian@BeagleBone:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
/boot/uEnv.txt
enable_uboot_overlays=1
disable_uboot_overlay_video=1
Custom Board boot message(boot from SD Card)
U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
Trying to boot from MMC1
U-Boot 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus are properly configured
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldn't find partition 0:2 0x82000000
Can't set block device
Scanning mmc 0:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Scanning disk mmc@481d8000.blk...
Found 3 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1796 bytes read in 9 ms (194.3 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r71 ...
11342336 bytes read in 726 ms (14.9 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb ...
loading /boot/dtbs/5.10.168-ti-r71/am335x-boneblack-uboot.dtb ...
102508 bytes read in 21 ms (4.7 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 14 ms (44.9 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r71/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 14 ms (111.3 KiB/s)
uboot_overlays: uboot loading of [BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_video=1]...
loading /boot/initrd.img-5.10.168-ti-r71 ...
7719588 bytes read in 498 ms (14.8 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:75caa4 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xad1200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f8a3000, end 8ffffaa4 ... OK
   Loading Device Tree to 8f826000, end 8f8a2fff ... OK
Starting kernel ...
[    0.113917] l3-aon-clkctrl:0000:0: failed to disable
[    3.596503] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    3.785959] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
Beagleboneblack boot message(same SD Card)
DRAM:  512 MiB
BeagleBone Black:
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Scanning mmc 0:1...
Found 4 disks
1796 bytes read in 8 ms (218.8 KiB/s)
11342336 bytes read in 720 ms (15 MiB/s)
7719588 bytes read in 499 ms (14.8 MiB/s)
Starting kernel ...
[    0.113899] l3-aon-clkctrl:0000:0: failed to disable
[    3.593519] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    3.781991] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[    3.960940] omap_voltage_late_init: Voltage driver support not added
Debian GNU/Linux 11 BeagleBone ttyS0
BeagleBoard.org Debian Bullseye IoT Image 2023-09-02
Support: https://bbb.io/debian
default username:password is [debian:temppwd]
BeagleBone login:
Boot with an ID as a BeagleBone Green, that’ll save you from always disabling HDMI… ( boot-scripts/device/bone/bbg-eeprom.dump at master · RobertCNelson/boot-scripts · GitHub )
Ethernet is probed over mdio, so missing a phy should silently fail wit no issue…
The random reboot on startup looks like watchdog kicking off…
Please remove “quiet” from your boot args, and let the serial debugger run a little farther…
Starting kernel ...
as another 10 lines or so, it dumps the reason for the reboot…
Reset Source: <something>
Hi, Thank you for reply,
I deleted the quiet flag from bootargs, My custom board message is below. I also share the board power supply output.
DRAM:  512 MiB
BeagleBone Black:
Scanning mmc 0:1...
Found 3 disks
1790 bytes read in 9 ms (193.4 KiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100] ...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-ti-r71 (voodoo@rpi4b4g-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Fri Sep 1 04:05:07 UTC 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 21 pages/cpu s54604 r8192 d23220 u86016
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 436612K/522240K available (15360K kernel code, 1446K rwdata, 4040K rodata, 1024K init, 444K bss, 36476K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000011] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000030] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000396] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001825] Console: colour dummy device 80x30
[    0.001914] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.001944] pid_max: default: 32768 minimum: 301
[    0.002575] LSM: Security Framework initializing
[    0.002695] Yama: becoming mindful.
[    0.002999] AppArmor: AppArmor initialized
[    0.003019] TOMOYO Linux initialized
[    0.003214] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003233] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.005011] CPU: Testing write buffer coherency: ok
[    0.005104] CPU0: Spectre v2: using BPIALL workaround
[    0.028885] Setting up static identity map for 0x80100000 - 0x80100060
[    0.036470] rcu: Hierarchical SRCU implementation.
[    0.045731] EFI services will not be available.
[    0.056481] smp: Bringing up secondary CPUs ...
[    0.056505] smp: Brought up 1 node, 1 CPU
[    0.056518] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.056529] CPU: All CPU(s) started in SVC mode.
[    0.057468] devtmpfs: initialized
[    0.080834] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.081339] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.081388] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.085267] pinctrl core: initialized pinctrl subsystem
[    0.086488] DMI not present or invalid.
[    0.087414] NET: Registered protocol family 16
[    0.091475] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.114011] l3-aon-clkctrl:0000:0: failed to disable
[    0.114714] audit: initializing netlink subsys (disabled)
[    0.116214] thermal_sys: Registered thermal governor 'fair_share'
[    0.116229] thermal_sys: Registered thermal governor 'bang_bang'
[    0.116245] thermal_sys: Registered thermal governor 'step_wise'
[    0.116256] thermal_sys: Registered thermal governor 'user_space'
[    0.116266] thermal_sys: Registered thermal governor 'power_allocator'
[    0.116790] cpuidle: using governor ladder
[    0.116850] cpuidle: using governor menu
[    0.120565] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[    1.325891] hw-breakpoint: debug architecture 0x4 unsupported.
[    1.352961] Kprobes globally optimized
[    1.376882] raid6: skip pq benchmark and using algorithm neonx8
[    1.376916] raid6: using neon recovery algorithm
[    1.380370] iommu: Default domain type: Translated
[    1.383151] SCSI subsystem initialized
[    1.383986] usbcore: registered new interface driver usbfs
[    1.384052] usbcore: registered new interface driver hub
[    1.384115] usbcore: registered new device driver usb
[    1.385091] mc: Linux media interface: v0.10
[    1.385150] videodev: Linux video capture interface: v2.00
[    1.385321] pps_core: LinuxPPS API ver. 1 registered
[    1.385334] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.385361] PTP clock support registered
[    1.387623] NetLabel: Initializing
[    1.387649] NetLabel:  domain hash size = 128
[    1.387659] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.387758] NetLabel:  unlabeled traffic allowed by default
[    1.389052] clocksource: Switched to clocksource dmtimer
[    2.452565] VFS: Disk quotas dquot_6.6.0
[    2.452722] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.453148] FS-Cache: Loaded
[    2.453559] CacheFiles: Loaded
[    2.454576] AppArmor: AppArmor Filesystem Enabled
[    2.467641] NET: Registered protocol family 2
[    2.467945] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    2.469632] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    2.469943] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    2.470015] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    2.470077] TCP: Hash tables configured (established 4096 bind 4096)
[    2.470694] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    2.470802] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.470838] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.471100] NET: Registered protocol family 1
[    2.484609] RPC: Registered named UNIX socket transport module.
[    2.484634] RPC: Registered udp transport module.
[    2.484644] RPC: Registered tcp transport module.
[    2.484653] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.484673] NET: Registered protocol family 44
[    2.485504] Trying to unpack rootfs image as initramfs...
[    2.917339] Freeing initrd memory: 7540K
[    2.918132] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    2.923737] Initialise system trusted keyrings
[    2.924229] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    2.932422] zbud: loaded
[    2.940544] NFS: Registering the id_resolver key type
[    2.940623] Key type id_resolver registered
[    2.940635] Key type id_legacy registered
[    2.940856] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.940873] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.940924] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    2.942172] fuse: init (API version 7.32)
[    3.031734] xor: automatically using best checksumming function   neon
[    3.031769] Key type asymmetric registered
[    3.031782] Asymmetric key parser 'x509' registered
[    3.031869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    3.036272] io scheduler mq-deadline registered
[    3.345000] ti-sysc: probe of 44e31000.target-module failed with error -16
[    3.375601] ti-sysc: probe of 48040000.target-module failed with error -16
[    3.486791] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    3.597162] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    3.597214] edma 49000000.dma: TI EDMA DMA engine driver
[    3.626441] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    3.641890] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    3.646265] printk: console [ttyS0] disabled
[    3.646386] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[    4.473140] printk: console [ttyS0] enabled
[    4.481692] omap_rng 48310000.rng: Random Number Generator ver. 20
[    4.488274] random: crng init done
[    4.601235] loop: module loaded
[    4.617353] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[    4.625929] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    4.632469] cpsw 4a100000.ethernet: ALE Table size 1024
[    4.637905] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    4.645298] cpsw 4a100000.ethernet: Detected MACID = 64:8c:bb:90:1f:59
[    4.655060] usbcore: registered new interface driver smsc95xx
[    4.662728] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[    4.671541] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    4.686123] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[    4.694955] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    4.710695] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.717545] ehci-platform: EHCI generic platform driver
[    4.723348] ehci-omap: OMAP-EHCI Host Controller driver
[    4.739773] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    4.745383] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    4.753275] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    4.761613] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.768897] usb usb1: Product: MUSB HDRC host driver
[    4.773904] usb usb1: Manufacturer: Linux 5.10.168-ti-r71 musb-hcd
[    4.780130] usb usb1: SerialNumber: musb-hdrc.1
[    4.785667] hub 1-0:1.0: USB hub found
[    4.789606] hub 1-0:1.0: 1 port detected
[    4.806486] omap_rtc 44e3e000.rtc: registered as rtc0
[    4.811983] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[    4.822126] i2c /dev entries driver
[    4.829320] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    4.836950] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    4.845547] sof
DRAM:  512 MiB
BeagleBone Black:
Scanning mmc 0:1...
Found 3 disks
1790 bytes read in 8 ms (217.8 KiB/s)
645 bytes read in 13 ms (47.9 KiB/s)
Starting kernel ...
[    0.000395] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001828] Console: colour dummy device 80x30
[    0.001915] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.001943] pid_max: default: 32768 minimum: 301
[    0.002574] LSM: Security Framework initializing
[    0.002697] Yama: becoming mindful.
[    0.003000] AppArmor: AppArmor initialized
[    0.003020] TOMOYO Linux initialized
[    0.003218] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003235] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.005010] CPU: Testing write buffer coherency: ok
[    0.005103] CPU0: Spectre v2: using BPIALL workaround
[    0.028878] Setting up static identity map for 0x80100000 - 0x80100060
[    0.036471] rcu: Hierarchical SRCU implementation.
[    0.045735] EFI services will not be available.
[    0.056517] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.057463] devtmpfs: initialized
[    0.081341] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.085219] pinctrl core: initialized pinctrl subsystem
[    0.086434] DMI not present or invalid.
[    0.087364] NET: Registered protocol family 16
[    0.091407] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.113956] l3-aon-clkctrl:0000:0: failed to disable
[    0.114658] audit: initializing netlink subsys (disabled)
[    0.116144] thermal_sys: Registered thermal governor 'fair_share'
[    0.116159] thermal_sys: Registered thermal governor 'bang_bang'
[    0.116177] thermal_sys: Registered thermal governor 'step_wise'
[    0.116187] thermal_sys: Registered thermal governor 'user_space'
[    0.116196] thermal_sys: Registered thermal governor 'power_allocator'
[    0.116723] cpuidle: using governor ladder
[    0.116779] cpuidle: using governor menu
[    0.120561] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[    1.325381] hw-breakpoint: debug architecture 0x4 unsupported.
[    1.352247] Kprobes globally optimized
[    1.376881] raid6: skip pq benchmark and using algorithm neonx8
[    1.376915] raid6: using neon recovery algorithm
[    1.380402] iommu: Default domain type: Translated
[    1.383181] SCSI subsystem initialized
[    1.384012] usbcore: registered new interface driver usbfs
[    1.384078] usbcore: registered new interface driver hub
[    1.384140] usbcore: registered new device driver usb
[    1.385130] mc: Linux media interface: v0.10
[    1.385184] videodev: Linux video capture interface: v2.00
[    1.385358] pps_core: LinuxPPS API ver. 1 registered
[    1.385372] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.385399] PTP clock support registered
[    1.387667] NetLabel: Initializing
[    1.387693] NetLabel:  domain hash size = 128
[    1.387703] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.387801] NetLabel:  unlabeled traffic allowed by default
[    1.389092] clocksource: Switched to clocksource dmtimer
[    2.451309] VFS: Disk quotas dquot_6.6.0
[    2.451464] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.451803] FS-Cache: Loaded
[    2.452216] CacheFiles: Loaded
[    2.453341] AppArmor: AppArmor Filesystem Enabled
[    2.466320] NET: Registered protocol family 2
[    2.466625] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    2.468244] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    2.468558] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    2.468631] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    2.468693] TCP: Hash tables configured (established 4096 bind 4096)
[    2.469391] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    2.469505] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.469542] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.469816] NET: Registered protocol family 1
[    2.483320] RPC: Registered named UNIX socket transport module.
[    2.483344] RPC: Registered udp transport module.
[    2.483354] RPC: Registered tcp transport module.
[    2.483364] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.483381] NET: Registered protocol family 44
[    2.484135] Trying to unpack rootfs image as initramfs...
[    2.915939] Freeing initrd memory: 7540K
[    2.916751] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    2.922355] Initialise system trusted keyrings
[    2.922895] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    2.931101] zbud: loaded
[    2.939179] NFS: Registering the id_resolver key type
[    2.939266] Key type id_resolver registered
[    2.939279] Key type id_legacy registered
[    2.939498] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.939515] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.939568] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, Inc.
[    2.940667] fuse: init (API version 7.32)
[    3.030209] xor: automatically using best checksumming function   neon
[    3.030241] Key type asymmetric registered
[    3.030253] Asymmetric key parser 'x509' registered
[    3.030338] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    3.034735] io scheduler mq-deadline registered
[    3.342260] ti-sysc: probe of 44e31000.target-module failed with error -16
[    3.372612] ti-sysc: probe of 48040000.target-module failed with error -16
[    3.483202] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    3.593687] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    3.593740] edma 49000000.dma: TI EDMA DMA engine driver
[    3.622611] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    3.638072] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    3.642447] printk: console [ttyS0] disabled
[    3.642567] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[    4.469329] printk: console [ttyS0] enabled
[    4.477885] omap_rng 48310000.rng: Random Number Generator ver. 20
[    4.484477] random: crng init done
[    4.597280] loop: module loaded
[    4.613390] mdio_bus 4a101000.mdio: mii_bus 4a101000.mdio couldn't get reset GPIO
[    4.621972] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    4.628512] cpsw 4a100000.ethernet: ALE Table size 1024
[    4.633954] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[    4.641344] cpsw 4a100000.ethernet: Detected MACID = 64:8c:bb:90:1f:59
[    4.651099] usbcore: registered new interface driver smsc95xx
[    4.658778] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[    4.667589] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    4.682155] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[    4.691000] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    4.706724] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.713575] ehci-platform: EHCI generic platform driver
[    4.719380] ehci-omap: OMAP-EHCI Host Controller driver
[    4.735825] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    4.741434] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    4.749320] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    4.757657] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.764941] usb usb1: Product: MUSB HDRC host driver
[    4.769947] usb usb1: Manufacturer: Linux 5.10.168-ti-r71 musb-hcd
[    4.776174] usb usb1: SerialNumber: musb-hdrc.1
[    4.781686] hub 1-0:1.0: USB hub found
[    4.785614] hub 1-0:1.0: 1 port detected
[    4.802528] omap_rtc 44e3e000.rtc: registered as rtc0
[    4.808031] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[    4.818168] i2c /dev entries driver
[    4.825370] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    4.832996] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    4.841593] soft
(same boot message sequences follow repeatedly as i said previously)
Board resetted approximately 10 second while WDT Timeout value is 60.
I don’t know what kind of mechanism make a watchdog refresh and what causes the WDT reset without expiring
Is it related to lack of TDA19988 and LAN8710 ICs?
Best regards.
There you go, ‘something’ is triggering a power on reset…
Hi Robert,
But we also saw your “quoted boot message line” when original Beaglebone Black is booting and also it logins successfully.
How can i find root cause of this problem?
Best regards.
Honestly, it’s probably a pcb/board issue… I’d start probing everything related to clock, etc and compare with the working BeagleBone Black…
Sadly, pcb layout isn’t my expertise… But when we have a working board, vs a non-working board with the same software. It’s probally something simple, a missed solder joint, maybe shorted etc…
