Custom Board doesnt run with Angström Image
Hello community,
I use the Angström Image v2012.12 - Kernel 3.8.13 with U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14) and I can login on my BBB.
I also try to run a custom board similar to the BBB. I only removed the HDMI part and use a MT41K256M16TW-107 ITP DDR3. When I try to boot, it stops while running the kernel:
Code hier eingeben…
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
33 bytes read in 3 ms (10.7 KiB/s)
4270840 bytes read in 770 ms (5.3 MiB/s)
24129 bytes read in 49 ms (480.5 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88e40
Starting kernel …
[ 0.194444] omap2_mbox_probe: platform not supported
[ 0.204990] tps65217-bl tps65217-bl: no platform data provided
[ 0.281512] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.318618] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.355726] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.392836] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.412862] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8 .45 (#5:BB-BONELT-HDMI)
[ 0.422487] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 0.429266] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BON ELT-HDMIN:00A0 (prio 2)
[ 0.451930] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.516301] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 0.528016] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 0.535334] pinctrl-single 44e10800.pinmux: could not request pin 21 on devic e pinctrl-single
[ 0.568496] dummy 0-0034: Error -121 writing to cec:0xff
[ 0.574309] tda998x 0-0070: Error -121 reading from 0xa
[ 0.580038] tda998x 0-0070: Error -121 writing to 0xa
[ 0.637061] tda998x 0-0070: Error -121 reading from 0xa
[ 0.642639] tda998x 0-0070: Error -121 writing to 0xa
[ 0.699595] tda998x 0-0070: Error -121 reading from 0x1
[ 0.705172] tda998x 0-0070: Error -121 writing to 0x1
[ 0.710564] tda998x 0-0070: Error -121 reading from 0x1
[ 0.716136] tda998x 0-0070: Error -121 writing to 0x1
[ 0.721524] tda998x 0-0070: Error -121 writing to REG_CURPAGE
[ 0.727640] tda998x 0-0070: Error -121 writing to 0x200
[ 0.733211] tda998x 0-0070: Error -121 writing to 0x201
[ 0.738781] tda998x 0-0070: Error -121 writing to 0x202
[ 0.744377] tda998x 0-0070: Error -121 writing to 0x203
[ 0.749949] tda998x 0-0070: Error -121 writing to 0x204
[ 0.755520] tda998x 0-0070: Error -121 writing to 0x205
[ 0.761090] tda998x 0-0070: Error -121 writing to 0x20e
[ 0.766661] tda998x 0-0070: Error -121 writing to 0x211
[ 0.772233] tda998x 0-0070: Error -121 writing to 0x207
[ 0.777803] tda998x 0-0070: Error -121 writing to 0x208
[ 0.783372] tda998x 0-0070: Error -121 writing to 0x209
[ 0.788942] tda998x 0-0070: Error -121 writing to 0x20a
[ 0.794514] tda998x 0-0070: Error -121 writing to 0x206
[ 0.800084] tda998x 0-0070: Error -121 writing to REG_CURPAGE
[ 0.806199] tda998x 0-0070: Error -121 reading from 0x0
[ 0.811770] tda998x 0-0070: Error -121 reading from 0x2
[ 0.817608] tilcdc 4830e000.fb: no encoders/connectors found
[ 0.823568] tilcdc 4830e000.fb: failed to initialize mode setting
Could the different RAM be the reason for this? Could anybody give an advice to get it run?
Thank you very much.
Best regards
Eric
I just did a 10 second google and it appears like tda998x is related to HDMI which you pulled from your board.
Just a couple of basic questions:
  1. Did you remove the HDMI from either/both the u-boot pinmux and/or the cape manager?
  2. If you start with a console image, does this yield the same result?
I’m assuming that the console image doesn’t access the HDMI port, but I DID see what appeared to be plain text appear on the HDMI port before X-windows started up on an LXQT image, so I could be mistaken…
Thank you for your fast reply.
I didnt remove anything. I only download this image: https://s3.amazonaws.com/angstrom/demo/beaglebone/Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.12-beaglebone-2013.06.20.img.xz from BeagleBoard.org and put it on my sd-card.
I’m new to this topic and tried to build an own uboot and linux kernel with the BBB configuration. But they stopped after the RAM-check. Then I noticed, that my NAND is not properly connected because of a hardware issue. I assume that it check for the NAND and stops, because it cant find it. Then I tried the angström image from beagleboard.org. But I cant edit it. Is there a way to edit it with the uEnv.txt or do you now where I can disable the NAND-check in a current uboot?
Thank you
Do yourself a favor dont use Angstrom It has no support
development has stopped
Use debian. We have Excellent support here when using a modern OS
"I also try to run a custom board similar to the BBB. I only removed
boot, it stops while running the kernel:"
YOU removed the HDMI..
I'm new to this topic and tried to build an own uboot and linux kernel with
What Nand?
Anywho, it's 2018, that 2012 image is EOL...
I use a custom board similar similar to the BBB but without the HDMI part, and a different RAM. with NAND I mean the eMMC on MMC1.
I tried the Debian Image9.3, but it stops after the RAM:
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
U-Boot SPL 2018.01-00002-g9aa111a004 (Jan 20 2018 - 12:45:29)
Trying to boot from MMC1
U-Boot 2018.01-00002-g9aa111a004 (Jan 20 2018 - 12:45:29 -0600), Build: jenkins-github_Bootloader-Builder-32
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
I programmed the EEPROM like the one from the BBB. Is ist stop because of the missing eMMC on MMC1?
Thank you all for your advices.
I tried to build my own MLO and uboot.img with this commands:
  • make CROSS_COMPILE=arm-linux-gnueabihf- distclean
  • make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- am335x_boneblack_defconfig
  • make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j4
I suppose that I have to build a custom MLO and uboot.img and put it on the boot partition. But after flashing the Debian Image9.3 I cant find a boot partition. And the only MLO and uboot.img I could find was under /opt/backup/uboot/
Could someone give an advise how I could boot the uboot?
Well they are stored in the MBR..
See:
https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-Bootloader:U-Boot
Well they are stored in the MBR…
See:
Thank you for the link.
I guess thats there is a check for the emmc in the uboot when I use:
Is that right? Do you know in which file I could disable it?
Thank you for your help
Do the current images load capes DTBO files automatically when a proper
eeprom is detected?
uname -r
4.14.20-ti-r36
OR do we have to just load them in /boot/Uenv.txt
Be nice to take some of the configuration and automate things.
It does as long as your version of u-boot in the eMMC isn't ancient..
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
Oh sorry, i forgot our previous conversation:
https://groups.google.com/d/msg/beagleboard/kpKoeZf_yJ4/tuD9lFw-DgAJ
you don't want to update the eMMC..
So my solution doesn't work for you.
