Yiling,
My schematics are similar to beaglebone, which you can see in my first post. So my REFCLK is not connected as its also not connected in beaglebone black. And yes I am getting 25MHz clock. PHYAD0 and PHYAD2 show 0V and PHYAD1 has 1.6V.
Please see my boot log below for my custom image:
U-Boot 2018.03-dirty (Aug 14 2018 - 08:41:54 -0600)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Loading Environment from EXT4…
** Unable to use mmc 0:1 for loading the env **
Failed (-5)
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[000C] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1…
60946 bytes read in 8 ms (7.3 MiB/s)
Checking for: /uEnv.txt …
186 bytes read in 3 ms (60.5 KiB/s)
Loaded environment from /uEnv.txt
Checking if uenvcmd is set …
Running uenvcmd …
5000008 bytes read in 317 ms (15 MiB/s)
loading /am335x-boneblack.dtb …
60946 bytes read in 9 ms (6.5 MiB/s)
bootargs=console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Loading Device Tree to 8ffee000, end 8ffffe11 … OK
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.41 (root@threesixty-VirtualBox) (gcc version 7.
3.0 (Buildroot 2018.02.4) ) #3 SMP Tue Aug 14 07:27:59 MDT 2018
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio
n cache
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] PERCPU: Embedded 14 pages/cpu @df907000 s24936 r8192 d24216 u5734
4
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 r
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 481792K/522240K available (6761K kernel code, 760K rwdata
, 2264K rodata, 452K init, 8263K bss, 24064K reserved, 16384K cma-reserved, 0K h
ighmem)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08d878c (9026 kB)
[ 0.000000] .init : 0xc08d9000 - 0xc094a000 ( 452 kB)
[ 0.000000] .data : 0xc094a000 - 0xc0a08138 ( 761 kB)
[ 0.000000] .bss : 0xc0a0a000 - 0xc121bea0 (8264 kB)
[ 0.000000] Running RCU self tests
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU lockdep checking is enabled.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup
ts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478
484971ns
[ 0.000040] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max
_idle_ns: 79635851949 ns
[ 0.000086] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000710] clocksource_probe: no matching clocksources found
[ 0.001559] Console: colour dummy device 80x30
[ 0.001615] Lock dependency validator: Copyright © 2006 Red Hat, Inc., Ingo
Molnar
[ 0.001625] … MAX_LOCKDEP_SUBCLASSES: 8
[ 0.001632] … MAX_LOCK_DEPTH: 48
[ 0.001640] … MAX_LOCKDEP_KEYS: 8191
[ 0.001647] … CLASSHASH_SIZE: 4096
[ 0.001654] … MAX_LOCKDEP_ENTRIES: 32768
[ 0.001661] … MAX_LOCKDEP_CHAINS: 65536
[ 0.001668] … CHAINHASH_SIZE: 32768
[ 0.001676] memory used by lock dependency info: 5167 kB
[ 0.001683] per task-struct memory footprint: 1536 bytes
[ 0.001708] Calibrating delay loop… 996.14 BogoMIPS (lpj=4980736)
[ 0.078600] pid_max: default: 32768 minimum: 301
[ 0.078983] Security Framework initialized
[ 0.079093] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.079107] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.081925] Initializing cgroup subsys io
[ 0.082027] Initializing cgroup subsys memory
[ 0.082119] Initializing cgroup subsys devices
[ 0.082238] Initializing cgroup subsys freezer
[ 0.082313] Initializing cgroup subsys perf_event
[ 0.082379] CPU: Testing write buffer coherency: ok
[ 0.083809] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.083935] Setting up static identity map for 0x80008280 - 0x800082f8
[ 0.087514] Brought up 1 CPUs
[ 0.087536] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.087547] CPU: All CPU(s) started in SVC mode.
[ 0.091526] devtmpfs: initialized
[ 0.140220] VFP support v0.3: implementor 41 architecture 3 part 30 variant c
rev 3
[ 0.230575] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 19112604462750000 ns
[ 0.232991] pinctrl core: initialized pinctrl subsystem
[ 0.237994] NET: Registered protocol family 16
[ 0.243663] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.245655] cpuidle: using governor ladder
[ 0.245685] cpuidle: using governor menu
[ 0.257928] OMAP GPIO hardware version 0.1
[ 0.283077] No ATAGs?
[ 0.283113] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.283758] omap4_sram_init:Unable to allocate sram needed to handle errata I
688
[ 0.283776] omap4_sram_init:Unable to get sram pool needed to handle errata I
688
[ 0.325337] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.329819] SCSI subsystem initialized
[ 0.331479] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wk
up@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.334656] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.335103] pps_core: LinuxPPS API ver. 1 registered
[ 0.335116] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti giometti@linux.it
[ 0.335169] PTP clock support registered
[ 0.339196] clocksource: Switched to clocksource timer1
[ 0.475785] NET: Registered protocol family 2
[ 0.477741] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.477839] TCP bind hash table entries: 4096 (order: 5, 147456 bytes)
[ 0.479175] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.479426] UDP hash table entries: 256 (order: 2, 20480 bytes)
[ 0.479601] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[ 0.480490] NET: Registered protocol family 1
[ 0.482188] RPC: Registered named UNIX socket transport module.
[ 0.482211] RPC: Registered udp transport module.
[ 0.482221] RPC: Registered tcp transport module.
[ 0.482230] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.484314] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter
s available
[ 0.488630] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.488850] audit: initializing netlink subsys (disabled)
[ 0.489350] audit: type=2000 audit(0.490:1): initialized
[ 0.493827] VFS: Disk quotas dquot_6.6.0
[ 0.494014] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.496383] NFS: Registering the id_resolver key type
[ 0.496740] Key type id_resolver registered
[ 0.496756] Key type id_legacy registered
[ 0.496942] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.502394] io scheduler noop registered
[ 0.502427] io scheduler deadline registered
[ 0.502481] io scheduler cfq registered (default)
[ 0.504188] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.507150] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.513289] omap_uart 44e09000.serial: no wakeirq for uart0
[ 0.513806] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 158, base_baud =
3000000) is a OMAP UART0
[ 1.226413] console [ttyO0] enabled
[ 1.266572] brd: module loaded
[ 1.292036] loop: module loaded
[ 1.297891] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.369139] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.375548] libphy: 4a101000.mdio: probed
[ 1.379795] mdio_bus 4a101000.mdio: /ocp/ethernet@4a100000/mdio@4a101000/@cps
w_emac0 has invalid PHY address
[ 1.390092] mdio_bus 4a101000.mdio: scan phy at address 0
[ 1.396090] mdio_bus 4a101000.mdio: scan phy at address 1
[ 1.402001] mdio_bus 4a101000.mdio: scan phy at address 2
[ 1.407848] mdio_bus 4a101000.mdio: scan phy at address 3
[ 1.413699] mdio_bus 4a101000.mdio: scan phy at address 4
[ 1.419549] mdio_bus 4a101000.mdio: scan phy at address 5
[ 1.425398] mdio_bus 4a101000.mdio: scan phy at address 6
[ 1.431249] mdio_bus 4a101000.mdio: scan phy at address 7
[ 1.437098] mdio_bus 4a101000.mdio: scan phy at address 8
[ 1.442949] mdio_bus 4a101000.mdio: scan phy at address 9
[ 1.448798] mdio_bus 4a101000.mdio: scan phy at address 10
[ 1.454714] mdio_bus 4a101000.mdio: scan phy at address 11
[ 1.460694] mdio_bus 4a101000.mdio: scan phy at address 12
[ 1.466608] mdio_bus 4a101000.mdio: scan phy at address 13
[ 1.472589] mdio_bus 4a101000.mdio: scan phy at address 14
[ 1.478503] mdio_bus 4a101000.mdio: scan phy at address 15
[ 1.484484] mdio_bus 4a101000.mdio: scan phy at address 16
[ 1.490464] mdio_bus 4a101000.mdio: scan phy at address 17
[ 1.496378] mdio_bus 4a101000.mdio: scan phy at address 18
[ 1.502294] mdio_bus 4a101000.mdio: scan phy at address 19
[ 1.508208] mdio_bus 4a101000.mdio: scan phy at address 20
[ 1.514124] mdio_bus 4a101000.mdio: scan phy at address 21
[ 1.520104] mdio_bus 4a101000.mdio: scan phy at address 22
[ 1.526018] mdio_bus 4a101000.mdio: scan phy at address 23
[ 1.531999] mdio_bus 4a101000.mdio: scan phy at address 24
[ 1.537913] mdio_bus 4a101000.mdio: scan phy at address 25
[ 1.543894] mdio_bus 4a101000.mdio: scan phy at address 26
[ 1.549874] mdio_bus 4a101000.mdio: scan phy at address 27
[ 1.555788] mdio_bus 4a101000.mdio: scan phy at address 28
[ 1.561769] mdio_bus 4a101000.mdio: scan phy at address 29
[ 1.567683] mdio_bus 4a101000.mdio: scan phy at address 30
[ 1.573599] mdio_bus 4a101000.mdio: scan phy at address 31
[ 1.580913] cpsw 4a100000.ethernet: Detected MACID = 98:84:e3:ae:08:53
[ 1.588169] cpsw 4a100000.ethernet: cpts: overflow check period 850
[ 1.598865] mousedev: PS/2 mouse device common for all mice
[ 1.604853] i2c /dev entries driver
[ 1.611619] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.689521] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.697065] oprofile: using arm/armv7
[ 1.701820] Initializing XFRM netlink socket
[ 1.706640] NET: Registered protocol family 10
[ 1.714822] sit: IPv6 over IPv4 tunneling driver
[ 1.721994] NET: Registered protocol family 17
[ 1.726728] NET: Registered protocol family 15
[ 1.731824] Key type dns_resolver registered
[ 1.736473] omap_voltage_late_init: Voltage driver support not added
[ 1.743194] sr_dev_init: No voltage domain specified for smartreflex0. Cannot
initialize
[ 1.751680] sr_dev_init: No voltage domain specified for smartreflex1. Cannot
initialize
[ 1.761514] ThumbEE CPU extension supported.
[ 1.766014] Registering SWP/SWPB emulation handler
[ 1.771106] SmartReflex Class3 initialized
[ 1.793342] mmc0: host does not support reading read-only switch, assuming wr
ite-enable
[ 1.808250] mmc0: new high speed SDHC card at address aaaa
[ 1.817960] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 1.832680] mmcblk0: p1 p2
[ 1.848156] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.854704] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.862519] hctosys: unable to open rtc device (rtc0)
[ 1.867815] sr_init: No PMIC hook to init smartreflex
[ 1.873455] sr_init: platform driver register failed for SR
[ 1.932483] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O
pts: (null)
[ 1.941248] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.962031] devtmpfs: mounted
[ 1.965948] Freeing unused kernel memory: 452K (c08d9000 - c094a000)
[ 1.972703] This architecture does not have kernel memory protection.
[ 2.000084] mmc1: MAN_BKOPS_EN bit is not set
[ 2.015708] mmc1: new high speed MMC card at address 0001
[ 2.025210] mmcblk1: mmc1:0001 DG4008 7.28 GiB
[ 2.035117] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
[ 2.045609] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
[ 2.209963] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 2.249607] devpts: called with bogus options
Starting logging: OK
Populating /dev using udev: /sbin/udevd: /lib/libc.so.6: version GLIBC_2.25' no t found (required by /lib/libblkid.so.1) /sbin/udevd: /lib/libc.so.6: version GLIBC_2.25’ not found (required by /lib/li
buuid.so.1)
FAIL
Initializing random number generator… [ 2.607346] random: dd: uninitialized
urandom read (512 bytes read, 13 bits of entropy available)
done.
Starting network: [ 2.813934] net eth0: initializing cpsw version 1.12 (0)
[ 2.819602] net eth0: initialized cpsw ale version 1.4
[ 2.824970] net eth0: ALE Table size 1024
[ 2.830822] libphy: PHY 4a101000.mdio:00 not found
[ 2.835830] net eth0: phy “4a101000.mdio:00” not found on slave 0, err -19
[ 2.853248] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: no lease, failing
FAIL
/usr/bin/ssh-keygen: /lib/libc.so.6: version GLIBC_2.25' not found (required by /usr/bin/ssh-keygen) /usr/bin/ssh-keygen: /lib/libc.so.6: version GLIBC_2.26’ not found (required by
Starting sshd: /usr/sbin/sshd: /lib/libc.so.6: version GLIBC_2.25' not found (r equired by /usr/sbin/sshd) /usr/sbin/sshd: /lib/libc.so.6: version GLIBC_2.26’ not found (required by /usr
/sbin/sshd)
OK
ti-gfx: starting pvr driver
fbset: can’t open ‘/dev/fb0’: No such file or directory
modprobe: module pvrsrvkm not found in modules.dep
modprobe: module omaplfb not found in modules.dep
modprobe: module bufferclass_ti not found in modules.dep
BusyBox v1.27.2 (2018-08-02 15:59:40 MDT) multi-call binary.
Usage: mknod [-m MODE] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
-m MODE Creation mode (default a=rw)
TYPE:
b Block device
c or u Character device
p Named pipe (MAJOR and MINOR are ignored)
chmod: /dev/pvrsrvkm: No such file or directory
PVR:(Error): OpenServices: Cannot open device driver /dev/omapdrm_pvr. [140, /pv
r_bridge_u.c]
PVR:(Error): PVRSRVInitSrvConnect: PVRSRVConnect failed [2572, /bridged_pvr_glue
.c]
PVR:(Error): SrvInit: PVRSRVInitSrvConnect failed (4) [37, /srvinit.c]
/usr/bin/pvrsrvctl: SrvInit failed (already initialized?) (err=4)
ti-gfx: unable to start server
Initializing SGX graphics driver PVR:(Error): OpenServices: Cannot open device d
river /dev/omapdrm_pvr. [140, /pvr_bridge_u.c]
.c]
PVR:(Error): main: SrvInit failed (4) [49, /pvrsrvinit.c]
FAIL
Welcome to Threesixty
threesixty-buildroot login:
Thank you,
