Custom cape - issues with UART1, UART2
I’m building a custom cape atm (physical pcb) which utilizes a number of on chip peripherals including uart1, uart2, uart4, uart5, i2c1, spi1, adc, and a bunch of gpio.
I’ve updated the debian build on my Element14 Beaglebone Black Industrial to the one released on the 19th March 2017 (Debian 8.7).
The guts of my cape .dts file :
exclusive-use =
/* the pin header uses /
“P8.7”, /
gpio2_2 GPIO1 /
“P8.8”, /
gpio2_3 5V_LOAD1_EN /
“P8.9”, /
gpio2_5 GPIO2 /
“P8.10”, /
gpio2_4 12V_LOAD4_EN /
“P8.11”, /
gpio1_13 GPIO3 /
“P8.12”, /
gpio1_12 12V_LOAD3_EN /
“P8.13”, /
gpio0_23 GPIO4 /
“P8.14”, /
gpio0_26 12V_LOAD2_EN /
“P8.15”, /
gpio1_15 GPIO5 /
“P8.16”, /
gpio1_14 12V_LOAD1_EN /
“P8.17”, /
gpio0_27 GPIO6 /
“P8.26”, /
gpio1_29 ONE-WIRE /
“P8.37”, /
uart5_txd /
“P8.38”, /
uart5_rxd /
“P9.11”, /
uart4_rxd_mux2 /
“P9.12”, /
gpio1_28 LCD_DC /
“P9.13”, /
uart4_txd_mux2 /
“P9.14”, /
gpio1_18 LCD_BKLT_EN /
“P9.16”, /
gpio1_19 LCD_RESET /
“P8.17”, /
i2c1_scl /
“P8.18”, /
i2c1_sda /
“P9.19”, /
i2c2_scl /
“P9.20”, /
i2c2_sda /
“P9.21”, /
uart2_txd /
“P9.22”, /
uart2_rxd /
“P9.24”, /
uart1_txd /
“P9.26”, /
uart1_rxd /
“P9.27”, /
gpio3_19 SOLAR_ENABLE /
“P9.28”, /
spi1_cs0 /
“P9.29”, /
spi1_d0 /
“P9.30”, /
spi1_d1 /
“P9.31”, /
spi1_sclk */
“P9.33”, /* AIN4 SOLAR_VOLTAGE /
“P9.35”, /
AIN6 SOLAR_CURRENT /
“P9.36”, /
AIN5 AIN5 /
“P9.37”, /
AIN2 SUPPLY_CURRENT /
“P9.38”, /
AIN3 AIN3 /
“P9.39”, /
AIN0 SUPPLY_VOLTAGE /
“P9.40”, /
AIN1 AIN1 */
/* the hardware ip uses */
“gpio2_2”,
“gpio2_3”,
“gpio2_5”,
“gpio2_4”,
“gpio1_13”,
“gpio1_12”,
“gpio0_23”,
“gpio0_26”,
“gpio1_15”,
“gpio1_14”,
“gpio0_27”,
“gpio1_29”,
“uart5”,
“uart4”,
“gpio1_28”,
“gpio1_18”,
“gpio1_19”,
“i2c1”,
“i2c2”,
“uart2”,
“uart1”,
“gpio3_19”,
“spi1”,
“tscadc”;
fragment@0 {
target = <&am33xx_pinmux>;
overlay {
bb_spi1_pins: pinmux_bb_spi1_pins {
pinctrl-single,pins = <
0x190 0x33 /* mcasp0_aclkx.spi1_sclk, INPUT_PULLUP | MODE3 /
0x194 0x33 /
mcasp0_fsx.spi1_d0, INPUT_PULLUP | MODE3 /
0x198 0x13 /
mcasp0_axr0.spi1_d1, OUTPUT_PULLUP | MODE3 /
0x19c 0x13 /
mcasp0_ahclkr.spi1_cs0, OUTPUT_PULLUP | MODE3 /
0x164 0x12 /
eCAP0_in_PWM0_out.spi1_cs1 OUTPUT_PULLUP | MODE2 */
bb_i2c1_pins: pinmux_bb_i2c1_pins {
0x15c 0x72 /* spi0_cs0.i2c1_scl, SLEWCTRL_SLOW | INPUT_PULLUP | MODE2 /
0x158 0x72 /
spi0_d1.i2c1_sda, SLEWCTRL_SLOW | INPUT_PULLUP | MODE2 /
bb_i2c2_pins: pinmux_bb_i2c2_pins {
0x17c 0x73 /
uart1_rtsn.i2c2_scl, SLEWCTRL_SLOW | INPUT_PULLUP | MODE3 /
0x178 0x73 /
uart1_ctsn.i2c2_sda, SLEWCTRL_SLOW | INPUT_PULLUP | MODE3 /
bb_uart1_pins: pinmux_bb_uart1_pins {
0x184 0x00 /
P9.24 uart1_txd.uart1_txd | MODE0 OUTPUT /
0x180 0x20 /
P9.26 uart1_rxd.uart1_rxd | MODE0 INPUT /
bb_uart2_pins: pinmux_bb_uart2_pins {
0x150 0x21 /
P9.22 spi0_sclk.uart2_rxd | MODE1 INPUT /
0x154 0x01 /
P9.21 spi0_d0.uart2_txd | MODE1 OUTPUT /
bb_uart4_pins: pinmux_bb_uart4_pins {
0x070 0x26 /
P9.11 gpmc_wait0.uart4_rxd | MODE6 INPUT /
0x074 0x06 /
P9.13 gpmc_wpn.uart4_txd | MODE6 OUTPUT /
bb_uart5_pins: pinmux_bb_uart5_pins {
0x0c4 0x24 /
P8.38 lcd_data8.uart5_rxd | MODE4 INPUT /
0x0c0 0x04 /
P8.37 lcd_data9.uart5_txd | MODE4 OUTPUT */
bb_gpio_pins: pinmux_bb_gpio_pins {
0x090 0x27 /* P8.7 gpmc_advn_ale.gpio2_2 RX_ENABLE | MODE7 /
0x094 0x07 /
P8.8 gpmc_oen_ren.gpio2_3 MODE7 /
0x09c 0x27 /
P8.9 gpmc_ben0_cle.gpio2_5 RX_ENABLE | MODE7 /
0x098 0x07 /
P8.10 gpmc_wen.gpio2_4 MODE7 /
0x034 0x27 /
P8.11 gpmc_ad13.gpio1_13 RX_ENABLE | MODE7 /
0x030 0x07 /
P8.12 gpmc_ad12.gpio1_12 MODE7 /
0x024 0x27 /
P8.13 gpmc_ad9.gpio0_23 RX_ENABLE | MODE7 /
0x028 0x07 /
P8.14 gpmc_ad10.gpio0_26 MODE7 /
0x03c 0x27 /
P8.15 gpmc_ad15.gpio1_15 RX_ENABLE | MODE7 /
0x038 0x07 /
P8.16 gpmc_ad14.gpio1_14 MODE7 /
0x02c 0x27 /
P8.17 gpmc_ad11.gpio0_27 RX_ENABLE | MODE7 /
0x07c 0x37 /
P8.26 gpmc_csn0.gpio1_29 RX_ENABLE | MODE7 /
0x078 0x07 /
P9.12 gpmc_ben1.gpio1_28 MODE7 /
0x048 0x07 /
P9.14 gpmc_a2.gpio1_18 MODE7 /
0x04c 0x07 /
P9.16 gpmc_a3.gpio1_19 MODE7 /
0x1a4 0x07 /
P9.27 mcasp0_fsr.gpio3_19 MODE7 */
bb_onewire_pins: pinmux_bb_onewire_pins {
0x7c 0x37 /* gpio1_29, RX_ENABLE | MODE 7 */ >;
fragment@1 {
target = <&spi1>; /* spi1 is numbered correctly */
overlay {
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <&bb_spi1_pins>;
#address-cells = <1>;
#size-cells = <0>;
/* add any spi devices connected here /
note that you can do direct SPI via spidev now */
spi1_0{
#size-cells = <0>;
compatible = “spidev”;
reg = <0>;
spi-max-frequency = <16000000>;
spi-cpol;
spi-cpha;
spi1_1{
#size-cells = <0>;
reg = <1>;
spi-cpol;
spi-cpha;
fragment@2 {
target = <&i2c1>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_i2c1_pins>;
/* this is the configuration part */
clock-frequency = <100000>;
#size-cells = <0>;
/* add any i2c devices on the bus here */
fragment@3 {
target = <&i2c2>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_i2c2_pins>;
#size-cells = <0>;
fragment@4 {
target = <&uart1>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_uart1_pins>;
fragment@5 {
target = <&uart2>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_uart2_pins>;
fragment@6 {
target = <&uart4>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_uart4_pins>;
fragment@7 {
target = <&uart5>;
overlay {
status = “okay”;
pinctrl-0 = <&bb_uart5_pins>;
fragment@8 {
target = <&tscadc>;
overlay {
status = “okay”;
adc {
ti,adc-channels = <0 1 2 3 4 5 6>;
ti,chan-step-avg = <0x16 0x16 0x16 0x16 0x16 0x16 0x16>;
ti,chan-step-opendelay = <0x98 0x98 0x98 0x98 0x98 0x98 0x98>;
ti,chan-step-sampledelay = <0x0 0x0 0x0 0x0 0x0 0x0 0x0>;
fragment@9 {
target = <&ocp>;
overlay {
onewire@0 {
status = “okay”;
compatible = “w1-gpio”;
pinctrl-0 = <&bb_onewire_pins>;
gpios = <&gpio1 29 0>;
My dtbo loads on boot and the cape is shown in slot 0 which is where my eeprom is addressed. I’ve tested the adc, some gpio, one wire and uarts so far. Uart4 and 5 are both operating correctly, however uart1 and 2 are not transmitting - they are receiving ok.
I initially thought I’d made an error with the pin mux but it looks ok. I haven’t probed the board yet with a scope, but physically the board looks ok (solder joints etc).
Is there a gotcha on the TX for uart1 and uart2?
Also in regard to the cape eeprom - is the pin usage section actually used at all? Perhaps I need to revisit my eeprom contents if that section is actually processed - or is it only used when a second cape is found and it uses the eeprom pin usage section to look for pin clashes?
Cheers,
Dean
0x00 = PIN_OUTPUT_PULLDOWN | MUX_MODE0
try:
0x20 = (PIN_OUTPUT | MUX_MODE0)
to see if it makes anydifference
