Custom Pin Configuration through .dtbo
I have a custom AM335x board.I want to configure GPIO0_1, GPIO3_10…etc as a GPIO.
If i try to change GPIO0_1(GPIO1) value through sys interface , nothing changed
sudo echo 1 > /sys/class/gpio/export
sudo echo out > /sys/class/gpio/gpio1/direction
sudo echo 1 > /sys/class/gpio/gpio1/value
sudo echo 0 > /sys/class/gpio/gpio1/value
When create .dtbo file, it effect the pin value but i couldn’t change the value from user space.
High-Side.dts
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/am33xx.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
 * Helper to show loaded overlays under: /proc/device-tree/chosen/overlays/
&{/chosen} {
	overlays {
		High-Side.kernel = __TIMESTAMP__;
    fragment@0 {
        target = <&gpio0>;
        __overlay__ {
            gpio-line-names =
                "[mdio_data]",
                "gpio0_1", /* Change [mdio_clk] to GPIO0_1 */
                "P9_22 [spi0_sclk]",
                "P9_21 [spi0_d0]",
                "P9_18 [spi0_d1]",
                "P9_17 [spi0_cs0]",
                "[mmc0_cd]",
                "P8_42A [ecappwm0]",
                "P8_35 [lcd d12]",
                "P8_33 [lcd d13]",
                "P8_31 [lcd d14]",
                "P8_32 [lcd d15]",
                "P9_20 [i2c2_sda]",
                "P9_19 [i2c2_scl]",
                "P9_26 [uart1_rxd]",
                "P9_24 [uart1_txd]",
                "[rmii1_txd3]",
                "[rmii1_txd2]",
                "[usb0_drvvbus]",
                "[hdmi cec]",
                "P9_41B",
                "[rmii1_txd1]",
                "P8_19 [ehrpwm2a]",
                "P8_13 [ehrpwm2b]",
                "NC",
                "NC",
                "P8_14",
                "P8_17",
                "[rmii1_txd0]",
                "[rmii1_refclk]",
                "P9_11 [uart4_rxd]",
                "P9_13 [uart4_txd]";
    fragment@1 {
        target = <&ocp>;
        __overlay__ {
            gpio0_1: gpio0_1 {
                //gpio-hog;
                gpios = <&gpio0 1 GPIO_ACTIVE_HIGH>;
                output-low;
                line-name = "HS_IN0";
What i need to change this GPIOx from user space?
Best regards.
Boot message:
U-Boot SPL 2022.04-ge0d31da5 (Dec 07 2023 - 16:17:19 +0000)
Trying to boot from MMC2
U-Boot 2022.04-ge0d31da5 (Dec 07 2023 - 16:17:19 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Timed out in wait_for_event: status=0000
Check if pads/pull-ups of bus are properly configured
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[unknown] ...
switch to partitions #0, OK
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Disk mmc@48060000.blk not ready
Scanning disk mmc@481d8000.blk...
Found 2 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
2420 bytes read in 3 ms (787.1 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.168-ti-r64 ...
11272704 bytes read in 718 ms (15 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/5.10.168-ti-r64/am335x-boneblack-uboot-univ.dtb ...
210612 bytes read in 18 ms (11.2 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r64/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 4 ms (157.2 KiB/s)
uboot_overlays: loading /lib/firmware/BB-CAN0-00A0.dtbo ...
1013 bytes read in 27 ms (36.1 KiB/s)
uboot_overlays: loading /lib/firmware/BB-CAN1-00A0.dtbo ...
1013 bytes read in 23 ms (43 KiB/s)
uboot_overlays: loading /lib/firmware/High-Side.dtbo ...
1426 bytes read in 6 ms (231.4 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.168-ti-r64/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 4 ms (391.6 KiB/s)
uboot_overlays: uboot loading of [BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_video=1]...
uboot_overlays: [dtb_overlay=/lib/firmware/dev-USB-PWR-CTL-00A1.dtbo] ...
uboot_overlays: loading /lib/firmware/dev-USB-PWR-CTL-00A1.dtbo ...
1014 bytes read in 17 ms (57.6 KiB/s)
loading /boot/initrd.img-5.10.168-ti-r64 ...
11485162 bytes read in 736 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100] ...
debug: [bootz 0x82000000 0x88080000:af3fea 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xac0200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f50c000, end 8fffffea ... OK
   Loading Device Tree to 8f475000, end 8f50bfff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-ti-r64 (arge02@development) (arm-linux-gnueabi-gcc (GCC) 10.4.0, GNU ld (GNU Binutils) 2.39) #2 SMP PREEMPT Tue Jan 30 17:30:34 +03 2024
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 21 pages/cpu s54732 r8192 d23092 u86016
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 433652K/522240K available (14336K kernel code, 1442K rwdata, 3940K rodata, 1024K init, 444K bss, 39436K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000032] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000414] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.002546] Console: colour dummy device 80x30
[    0.002637] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.002666] pid_max: default: 32768 minimum: 301
[    0.003303] LSM: Security Framework initializing
[    0.003430] Yama: becoming mindful.
[    0.003730] AppArmor: AppArmor initialized
[    0.003754] TOMOYO Linux initialized
[    0.003954] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003973] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.005755] CPU: Testing write buffer coherency: ok
[    0.005848] CPU0: Spectre v2: using BPIALL workaround
[    0.028901] Setting up static identity map for 0x80100000 - 0x80100060
[    0.036489] rcu: Hierarchical SRCU implementation.
[    0.045750] EFI services will not be available.
[    0.056501] smp: Bringing up secondary CPUs ...
[    0.056527] smp: Brought up 1 node, 1 CPU
[    0.056539] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.056550] CPU: All CPU(s) started in SVC mode.
[    0.057468] devtmpfs: initialized
[    0.100889] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.101386] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.101430] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.105288] pinctrl core: initialized pinctrl subsystem
[    0.106455] DMI not present or invalid.
[    0.107389] NET: Registered protocol family 16
[    0.111457] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.151373] l3-aon-clkctrl:0000:0: failed to disable
[    0.152164] audit: initializing netlink subsys (disabled)
[    0.153727] thermal_sys: Registered thermal governor 'fair_share'
[    0.153743] thermal_sys: Registered thermal governor 'bang_bang'
[    0.153762] thermal_sys: Registered thermal governor 'step_wise'
[    0.153772] thermal_sys: Registered thermal governor 'user_space'
[    0.153783] thermal_sys: Registered thermal governor 'power_allocator'
[    0.154731] cpuidle: using governor ladder
[    0.154821] audit: type=2000 audit(0.144:1): state=initialized audit_enabled=0 res=1
[    0.154856] cpuidle: using governor menu
[    6.032593] hw-breakpoint: debug architecture 0x4 unsupported.
[    6.083041] Kprobes globally optimized
[    6.104921] raid6: skip pq benchmark and using algorithm neonx8
[    6.104957] raid6: using neon recovery algorithm
[    6.112611] iommu: Default domain type: Translated
[    6.117278] SCSI subsystem initialized
[    6.121092] usbcore: registered new interface driver usbfs
[    6.121158] usbcore: registered new interface driver hub
[    6.121247] usbcore: registered new device driver usb
[    6.122609] mc: Linux media interface: v0.10
[    6.122667] videodev: Linux video capture interface: v2.00
[    6.122850] pps_core: LinuxPPS API ver. 1 registered
[    6.122864] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    6.122893] PTP clock support registered
[    6.125427] NetLabel: Initializing
[    6.125454] NetLabel:  domain hash size = 128
[    6.125463] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    6.125562] NetLabel:  unlabeled traffic allowed by default
[    6.126845] clocksource: Switched to clocksource dmtimer
[    7.278760] VFS: Disk quotas dquot_6.6.0
[    7.279017] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    7.279322] FS-Cache: Loaded
[    7.279726] CacheFiles: Loaded
[    7.280745] AppArmor: AppArmor Filesystem Enabled
[    7.294335] NET: Registered protocol family 2
[    7.294641] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    7.296566] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    7.296889] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    7.296962] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    7.297025] TCP: Hash tables configured (established 4096 bind 4096)
[    7.297344] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    7.297444] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    7.297479] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    7.297726] NET: Registered protocol family 1
[    7.311313] RPC: Registered named UNIX socket transport module.
[    7.311342] RPC: Registered udp transport module.
[    7.311352] RPC: Registered tcp transport module.
[    7.311362] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.311379] NET: Registered protocol family 44
[    7.312287] Trying to unpack rootfs image as initramfs...
[    7.728445] Freeing initrd memory: 11216K
[    7.729587] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    7.735565] Initialise system trusted keyrings
[    7.736063] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    7.744340] zbud: loaded
[    7.752392] NFS: Registering the id_resolver key type
[    7.752478] Key type id_resolver registered
[    7.752491] Key type id_legacy registered
[    7.752691] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.752707] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    7.752754] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    7.753876] fuse: init (API version 7.32)
[    7.839988] xor: automatically using best checksumming function   neon
[    7.840023] Key type asymmetric registered
[    7.840036] Asymmetric key parser 'x509' registered
[    7.840114] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    7.844504] io scheduler mq-deadline registered
[    8.614631] ti-sysc: probe of 44e31000.target-module failed with error -16
[    8.744504] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    8.771375] ti-sysc: probe of 48040000.target-module failed with error -16
[    8.979228] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    9.103392] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    9.619085] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    9.619136] edma 49000000.dma: TI EDMA DMA engine driver
[    9.648071] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    9.649779] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    9.649808] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    9.672542] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    9.677635] printk: console [ttyS0] disabled
[    9.677758] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[   10.531945] printk: console [ttyS0] enabled
[   10.538158] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 27, base_baud = 3000000) is a 8250
[   10.548733] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 28, base_baud = 3000000) is a 8250
[   10.559466] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 41, base_baud = 3000000) is a 8250
[   10.569783] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 42, base_baud = 3000000) is a 8250
[   10.580149] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 43, base_baud = 3000000) is a 8250
[   10.593742] omap_rng 48310000.rng: Random Number Generator ver. 20
[   10.600353] random: crng init done
[   10.622613] at24 2-0054: supply vcc not found, using dummy regulator
[   10.658310] at24 2-0055: supply vcc not found, using dummy regulator
[   10.694291] at24 2-0056: supply vcc not found, using dummy regulator
[   10.730234] at24 2-0057: supply vcc not found, using dummy regulator
[   10.868822] vcan: Virtual CAN interface driver
[   10.873416] vxcan: Virtual CAN Tunnel driver
[   10.877733] slcan: serial line CAN interface driver
[   10.882652] slcan: 10 dynamic interface channels.
[   10.887402] CAN device driver interface
[   10.893949] usbcore: registered new interface driver smsc95xx
[   10.902631] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[   10.911478] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[   10.928546] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[   10.937458] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[   10.953318] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   10.960195] ehci-platform: EHCI generic platform driver
[   10.966262] ehci-omap: OMAP-EHCI Host Controller driver
[   10.985488] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[   10.991167] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[   10.998972] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   11.007307] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.014585] usb usb1: Product: MUSB HDRC host driver
[   11.019591] usb usb1: Manufacturer: Linux 5.10.168-ti-r64 musb-hcd
[   11.025817] usb usb1: SerialNumber: musb-hdrc.1
[   11.031358] hub 1-0:1.0: USB hub found
[   11.035277] hub 1-0:1.0: 1 port detected
[   11.054222] omap_rtc 44e3e000.rtc: registered as rtc0
[   11.059759] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[   11.070418] i2c /dev entries driver
[   11.080594] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   11.088397] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[   11.096945] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
[   11.106918] cpuidle: enable-method property 'ti,am3352' found operations
[   11.115987] sdhci: Secure Digital Host Controller Interface driver
[   11.122283] sdhci: Copyright(c) Pierre Ossman
[   11.126684] sdhci-pltfm: SDHCI platform and OF driver helper
[   11.144020] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[   11.151943] ledtrig-cpu: registered to indicate activity on CPUs
[   11.161118] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   11.167521] omap-aes 53500000.aes: will run requests pump with realtime priority
[   11.179613] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   11.185934] omap-sham 53100000.sham: will run requests pump with realtime priority
[   11.198544] hid: raw HID events driver (C) Jiri Kosina
[   11.205101] usbcore: registered new interface driver usbhid
[   11.210959] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[   11.219049] usbhid: USB HID core driver
[   11.223857] remoteproc remoteproc0: wkup_m3 is available
[   11.239501] drop_monitor: Initializing network drop monitor service
[   11.246806] NET: Registered protocol family 10
[   11.287487] mmc1: new high speed MMC card at address 0001
[   11.296267] mmcblk1: mmc1:0001 MK2704 3.53 GiB
[   11.307850] mmcblk1boot0: mmc1:0001 MK2704 partition 1 2.00 MiB
[   11.319727] mmcblk1boot1: mmc1:0001 MK2704 partition 2 2.00 MiB
[   11.330165] mmcblk1rpmb: mmc1:0001 MK2704 partition 3 512 KiB, chardev (241:0)
[   11.351670]  mmcblk1: p1
[   11.358673] Segment Routing with IPv6
[   11.365360] mip6: Mobile IPv6
[   11.368566] NET: Registered protocol family 17
[   11.373145] can: controller area network core
[   11.379896] NET: Registered protocol family 29
[   11.384497] can: raw protocol
[   11.387601] can: broadcast manager protocol
[   11.392240] can: netlink gateway - max_hops=1
[   11.396877] can: SAE J1939
[   11.399635] can: isotp protocol
[   11.407288] Key type dns_resolver registered
[   11.411661] mpls_gso: MPLS GSO support
[   11.415764] ThumbEE CPU extension supported.
[   11.420101] Registering SWP/SWPB emulation handler
[   11.424941] omap_voltage_late_init: Voltage driver support not added
[   11.432360] registered taskstats version 1
[   11.436577] Loading compiled-in X.509 certificates
[   11.441569] zswap: loaded using pool lzo/zbud
[   11.450812] Key type .fscrypt registered
[   11.454887] Key type fscrypt-provisioning registered
[   11.467035] Btrfs loaded, crc32c=crc32c-generic
[   11.471770] AppArmor: AppArmor sha1 policy hashing enabled
[   11.498191] OMAP GPIO hardware version 0.1
[   11.527606] tps65217-pmic: Failed to locate of_node [id: -1]
[   11.544265] tps65217-bl: Failed to locate of_node [id: -1]
[   11.551759] tps65217-charger tps65217-charger: DMA mask not set
[   11.561761] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[   11.569127] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[   11.587817] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[   11.593796] at24 0-0050: supply vcc not found, using dummy regulator
[   11.601034] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[   11.608143] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[   11.621855] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[   11.629585] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[   11.637150] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[   11.644697] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[   11.652434] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[   11.660016] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[   11.667579] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[   11.675130] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[   11.682678] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[   11.690213] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[   11.697841] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[   11.705509] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[   11.713145] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[   11.720768] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[   11.728543] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[   11.736192] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[   11.743825] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[   11.751454] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[   11.759084] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[   11.766720] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[   11.774352] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[   11.781975] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[   11.789589] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[   11.797214] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[   11.804840] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[   11.812466] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[   11.820097] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[   11.827715] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[   11.835359] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[   11.842996] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[   11.850609] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[   11.858259] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[   11.865889] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[   11.873509] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[   11.881141] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[   11.888749] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[   11.896375] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[   11.904022] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[   11.911648] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[   11.919287] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[   11.926920] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[   11.934538] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[   11.942167] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[   11.949775] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[   11.957428] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[   11.965052] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[   11.972710] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[   11.980343] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[   11.987955] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[   11.995578] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[   12.003198] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[   12.010832] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[   12.018458] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[   12.026086] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[   12.033720] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[   12.041363] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[   12.048994] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[   12.056626] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[   12.064353] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[   12.072001] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[   12.079648] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[   12.087264] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[   12.094913] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[   12.102521] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[   12.110158] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[   12.117799] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[   12.125437] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[   12.133089] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[   12.140720] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[   12.148180] gpio-of-helper ocp:cape-universal: ready
[   12.156560] genirq: Flags mismatch irq 70. 00002000 (vbus) vs. 00002000 (tps65217-charger)
[   12.170966] musb-dsps: probe of 47401400.usb failed with error -16
[   12.182600] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[   12.192958] of_cfs_init
[   12.195830] of_cfs_init: OK
[   12.201122] sdhci-omap 48060000.mmc: Got CD GPIO
[   12.206099] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[   12.243334] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[   12.253733] Freeing unused kernel memory: 1024K
[   12.263591] Run /init as init process
Loading, please wait...
Starting version 245.4-4ubuntu3.22
[   16.226486] spidev: Unknown symbol __stack_chk_guard (err -2)
[   16.601178] spidev: Unknown symbol __stack_chk_guard (err -2)
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.34
[/usr/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
rootfs: recovering journal
rootfs: clean, 50339/231536 files, 638241/924672 blocks
done.
[   23.200333] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[   23.527379] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   23.876934] systemd[1]: System time before build time, advancing clock.
[   23.948042] x_tables: Unknown symbol __stack_chk_guard (err -2)
[   24.015948] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   24.039759] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 20.04.6 LTS!
[   24.084178] systemd[1]: Set hostname to <ubuntu>.
[   25.692636] systemd[1]: Unnecessary job for /dev/bone/uart/0 was removed.
[   25.699703] systemd[1]: Unnecessary job for /sys/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e09050.target-module/44e09000.serial/tty/ttyS0 was removed.
[   25.729106] systemd[1]: Created slice system-modprobe.slice.
[  OK  ] Created slice system-modprobe.slice.
[   25.753818] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[   25.777521] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   25.799812] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[   25.824923] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[   25.851716] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[   25.875172] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[   25.895215] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[   25.923125] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[   25.944316] systemd[1]: Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[   25.967778] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   25.993074] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   26.016185] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   26.040327] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   26.064652] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[   26.088368] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   26.111924] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   26.136168] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   26.154278] systemd[1]: Mounting POSIX Message Queue File System...
[   26.198147] systemd[1]: Mounting /sys/kernel/debug...
[   26.265176] systemd[1]: Mounting Kernel Trace File System...
[   26.325255] systemd[1]: Starting Journal Service...
[   26.373906] systemd[1]: Starting Set the console keyboard layout...
[   26.444781] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[   26.544746] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   26.591500] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   26.671054] systemd[1]: Starting Load Kernel Module efi_pstore...
[   26.752380] systemd[1]: Starting Load Kernel Module pstore_blk...
[   26.833148] systemd[1]: Starting Load Kernel Module pstore_zone...
[   26.932340] systemd[1]: Starting Load Kernel Module ramoops...
[   26.979562] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[   27.016949] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   27.043559] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   27.108855] systemd[1]: Starting Load Kernel Modules...
[   27.200329] systemd[1]: Starting Remount Root and Kernel File Systems...
[   27.308514] systemd[1]: Starting udev Coldplug all Devices...
[   27.426090] systemd[1]: Mounted POSIX Message Queue File System.
[   27.447062] cdc_wdm: Unknown symbol __stack_chk_guard (err -2)
[  OK  ] Mounted POSIX Message Queue File System.
[   27.496983] systemd[1]: Mounted /sys/kernel/debug.
[  OK  ] Mounted /sys/kernel/debug.
[   27.542218] systemd[1]: Mounted Kernel Trace File System.
[   27.555202] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[  OK  ] Mounted Kernel Trace File System.
[   27.635859] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[   27.698967] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[   27.747269] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[  OK  ] Finished Load Kernel Module chromeos_pstore.
[   27.794234] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[   27.839309] systemd[1]: Finished Load Kernel Module efi_pstore.
[  OK  ] Finished Load Kernel Module efi_pstore.
[   27.878158] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[   27.923773] systemd[1]: Finished Load Kernel Module pstore_blk.
[  OK  ] Finished Load Kernel Module pstore_blk.
[   27.966238] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[   28.007253] systemd[1]: Finished Load Kernel Module pstore_zone.
[  OK  ] Finished Load Kernel Module pstore_zone.
[   28.054148] systemd[1]: modprobe@ramoops.service: Succeeded.
[   28.091462] systemd[1]: Finished Load Kernel Module ramoops.
[  OK  ] Finished Load Kernel Module ramoops.
[   28.136875] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Finished Set the console keyboard layout.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
         Starting Apply Kernel Variables...
[   28.652245] systemd-journald[564]: Received client request to flush runtime journal.
[   28.709201] systemd-journald[564]: File /var/log/journal/f0fa6df01a924363b4e94c0c316040d6/system.journal corrupted or uncleanly shut down, renaming and replacing.
         Starting Create System Users...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting udev Kernel Device Manager...
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Set console font and keymap.
[  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[  OK  ] Finished udev Coldplug all Devices.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Reached target Paths.
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Message of the Day.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting BeagleBoard Generate Symlinks...
         Starting BeagleBoard.org USB gadgets...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
[  OK  ] Started Save initial kernel messages after boot.
         Starting Remove Stale Onli…t4 Metadata Check Snapshots...
         Starting LSB: Load kernel …d to enable cpufreq scaling...
         Starting Dispatcher daemon for systemd-networkd...
[  OK  ] Started Set the CPU Frequency Scaling governor.
         Starting Authorization Manager...
         Starting Restore /etc/reso… the ppp link was shut down...
         Starting System Logging Service...
         Starting Login Service...
         Starting WPA supplicant...
[  OK  ] Finished Restore /etc/reso…re the ppp link was shut down.
[  OK  ] Started System Logging Service.
[  OK  ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[  OK  ] Started Authorization Manager.
[  OK  ] Started WPA supplicant.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
         Starting Modem Manager...
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
         Starting Permit User Sessions...
         Starting Hostname Service...
[  OK  ] Finished Permit User Sessions.
         Starting Hold until boot process finishes up...
         Starting Terminate Plymouth Boot Screen...
[  OK  ] Started BeagleBoard.org USB gadgets.
[  OK  ] Finished Hold until boot process finishes up.
[  OK  ] Finished Terminate Plymouth Boot Screen.
[  OK  ] Started Login Service.
         Starting Set console scheme...
[  OK  ] Finished Set console scheme.
[  OK  ] Finished BeagleBoard Generate Symlinks.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Getty on tty1.
         Starting OpenBSD Secure Shell server...
[  OK  ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
[  OK  ] Started Modem Manager.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Started Hostname Service.
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Started Network Manager Script Dispatcher Service.
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Started Serial Getty on ttyS0.
Ubuntu 20.04.6 LTS ubuntu ttyS0
output - high/low = use gpio-led… gpio-hog is more of a ‘software’ pull-up pull-down that get’s set at bootup… (aka not changable)…
Disable enable_uboot_cape_universal=1 if you are running custom overlays, it’ll just get in your way…
