sudo /usr/share/beagleboard/gateware/change-gateware.sh ./my_custom_fpga_design is the command in question…
I have followed the instructions on the docs.beagleboard.org pages and I am currently facing an issue:
Changing gateware.
No gateware file found.
Is anyone having this issue so far? I downloaded the artifacts.zip and tried to install it but all I have currently is the mpfs_dtbo.spi file and this is not allowing me via USB C communication to get the customization installed…
P.S. If you understand, perfect! If not, please tell me what you need to help me, i.e. as I am courageously trying here!
Oh and I cannot update either. I am not sure exactly what the issue is for now…
deploy failed but build was successful on the section on openbeagle.org where I would find the artifacts.zip file…
If you cat the script, you should be able to ascertain what to point at.
Are you discussing the deploy file that I should command with cat?
dh_install: warning: Cannot find (any matches for) "gateware-builds-tester/artifacts/bitstreams/my_custom_fpga_design/DirectC/*" (tried in ., debian/tmp)
dh_install: warning: bbb.io-gateware-my-custom-fpga-design missing files: gateware-builds-tester/artifacts/bitstreams/my_custom_fpga_design/DirectC/*
dh_install: warning: Cannot find (any matches for) "gateware-builds-tester/artifacts/bitstreams/my_custom_fpga_design/FlashProExpress/*" (tried in ., debian/tmp)
dh_install: warning: bbb.io-gateware-my-custom-fpga-design missing files: gateware-builds-tester/artifacts/bitstreams/my_custom_fpga_design/FlashProExpress/*
dh_install: error: missing files, aborting
Here is the output of that command on the deploy file.
