Using a BeaglBone Black and Blackhawk BH-USB-100v2-ARM JTag simulator in CCS (code composer studio) to rework the attached assembly script so that I can cycle through USR0-3 and not just the two LED actions that light up now? How do I add 2 other ‘Pulses’ so that it will cycle through USR0-3? Also, how do I set the code so that when I hit the interrupt button turning off the led action and when I hit the button again it resumes where it left off? ie (if it is cycling through and I hit button when it is on USR3 to turn the action off and when I hit the button again, it resumes the led action on USR3 led?
ledinterruptbutton.s (8.5 KB)
