I was only using Snapdragon as an example of a future possible ARM
powered netbook. I assume at the moment a REVC board and some DIY
would get me on the platform I am looking at soonest.
My main query was:
If I get a powered USB hub can I run the Beagleboard, 5v flatpanel and
one
or more 2.5" hard disks off it?
I am interested in having at least 2 hard disks for compiles/swap
files and some file backup should one disk fail. (RAID would be nice
Can I run hard disks off the Beagleboard or do I need some interface?
I would be prepared to buy a second Beagleboard to run a NAS cluster
of disks if need be.
My background is Physics and mainframe IT. I am not an engineer. I
have built a Mullard pre-amp on Veroboard and a Linsley-Hood kit
amplifier and worked in an electronics workshop in the past so I can
solder and follow circuit diagrams. I wouild need help to get a
'laptop' Beagleboard goimg.
I live in Birmingham in the UK not far from a Maplin electronics shop.
A typical powered hub will provide 500mA to each port. As long as you are using USB-powered devices, they will work off of the power being supplied to the hub.
Depends on what you need to show, there are simple alpha numeric
LCD displays that can be assembled to work off the USB port.
For a full speed, full graphics display, I am not aware of any
simple solution.
Will a USB 2.5" HDD run straight off the Beagleboard, or via a cable
or adapter?
All the 2.5" HDD drives I have seen pull more then 500mA peak so you
will need a self powered hub and maybe a Y cable unless you want to
cheat and violate the USB spec on the EHCI port. Even the smaller 1"
Microdrive pull up to 500mA. Up to 500mA might be doable with the EHCI
port directly but for the OTG port, you will still need a self powered hub.
(Note: EHCI is RevC or later; OTG is available now.)
What are people using for the display on the videos of Beagleboard
demos?
I thought I had seen a small USB powered flat screen in a video.
I am happy to have the 'laptop' mains powered only.
I would prefer to keep all the bits powered off a USB hub as it seems
the simplest solution.
Otherwise I need a power supply to run the flat panel display and/or
HDD(s).
If HDDs are a problem I would want to use 2 SD cards.
What are OTG and EHCI?
I was assuming I would need to power a 2.5" HDD off a powered USB hub
at least, not off the Beagleboard directly.
Would a powered HUB run one 2.5" HDD off one powered USB socket? Can
a capacitor and/or small battery be used for power spikes?
Can the HDD data cable be plugged into the Beagleboard, via a cable or
adapter, and seen by Ubuntu?
I have no engineering knowledge. I have assembled my own PC's from
the large components but thats it.
I have an external USB hard drive and external USB DVD/CD drive which
I assume can be plugged into the Beagleboard via a socket on my case
for loading data and backup.
In order to connect a Hard Drive to the BeagleBoard, you need to do it
through the USB link with a "USB-to-PATA" or "USB-to-SATA" converter. (As
you would connect an external USB hard drive to you normal PC)
OTG = On the Go
EHCI = Enhanched Host Controller Interface
Basically two different HS-USB controllers in OMAP - Seen from an
application/"upper level" point of view there should as such be no
difference if the OTG port is configured in Host-mode - See more info at:
A digital monitor. I assume I will have to buy a new LCD monitor.
7 port powered USB Hub
I have got:
USB SD card reader
Powered Speakers or headphones
Microphone
USB Keyboard
USB Mouse
USB HDD
USB DVD/CD
USB Belkin Wireless G ???
I need:
Digital Monitor cable
(TV cable - Can I use a TV instead of a the monitor or is it for Video
output?)
USB Power cable to Beagleboard
USB data cable from Beagleboard to Hub
Null Modem cable to PC
A second USB SD card reader if I want 2 data stores without carting
the external HDD or DVD/CD drive around
Having looked at the Beagleboard presentation I noticed a small SD
card hanging out of the board.
I had not realised one could be plugged straight in.
Whats the maximum capacity which is supported?
Whatever is the maximum for the SDHC interface should be supported.
I'm using 8GB cards without problems.
Last, but not least it's actually possible to connect a card to the BeagleBoard Expansion Connector as well. In this way you can have two SD cards connected without using any card-reader... I however haven't heard about anyone trying this yet, but in theory it's supposed to work - Give it a try...
Best regards
Søren
