Dead BeagleBoardY-AI?
I have a first issue of the BeagleBoardY-AI and am just now setting it up for some edge work. I’ve tried different images an none allow the device to boot - I get a double flashing LED and a hot processor. Does this sound dead? I’ve tried multiple SSDs but with the same result.
Are you able to boot from SD card?
Go here and follow the instructions on getting your debug connection set up.
After that, you can try to let it boot and then post the output;
don’t forget to enclose the data in tripple-`…
like so
Using the debug probe I saw it was booting but without WiFi. After setting WiFi up it’s up and running - thanks
