Since upgrading to Debian 10.3 I seem to be getting more WiFi related events.
Syslog
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: wlan0: Trying to associate with f0:9f:c2:2d:df:2e (SSID=‘CALnet’ freq=2412 MHz)
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: Failed to add supported operating classes IE
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {RX} 16337 packets 133390130 bytes
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {TX} 1315 packets 65718136 bytes
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {update} flags 102403 <UP,LOWER_UP>
Mar 28 23:04:28 beaglebone kernel: [21047.944325] R8188EU: indicate disassoc
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {newlink} index 7 address 34:E8:94:DD:95:F9 mtu 1500
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {newlink} index 7 operstate 5
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {update} flags 36867
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: wlan0: Association request to the driver failed
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: wlan0: CTRL-EVENT-DISCONNECTED bssid=f0:9f:c2:2d:df:2e reason=0
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {newlink} index 7 operstate 2
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: dbus: wpa_dbus_property_changed: no property RoamComplete in object /fi/w1/wpa_supplicant1/Interfaces/1
Mar 28 23:04:28 beaglebone connmand[899]: Probably roaming right now! Staying connected…
Mar 28 23:04:28 beaglebone dnsmasq[1280]: reading /etc/resolv.conf
Mar 28 23:04:28 beaglebone kernel: [21048.024137] R8188EU: assoc success
Mar 28 23:04:28 beaglebone kernel: [21048.035779] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mar 28 23:04:28 beaglebone dnsmasq[1280]: using nameserver 8.8.4.4#53
Mar 28 23:04:28 beaglebone dnsmasq[1280]: no servers found in /etc/resolv.conf, will retry
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Withdrawing address record for 192.168.55.114 on wlan0.
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.55.114.
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Interface wlan0.IPv4 no longer relevant for mDNS.
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Withdrawing address record for fe80::36e8:94ff:fedd:95f9 on wlan0.
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::36e8:94ff:fedd:95f9.
Mar 28 23:04:28 beaglebone avahi-daemon[911]: Interface wlan0.IPv6 no longer relevant for mDNS.
Mar 28 23:04:28 beaglebone wpa_supplicant[925]: wlan0: Associated with 00:18:0a:22:f9:46
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {del} address 192.168.55.114/24 label wlan0
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {del} route 192.168.55.0 gw 0.0.0.0 scope 253
Mar 28 23:04:28 beaglebone connmand[899]: wlan0 {del} route fe80:: gw :: scope 0
Mar 28 23:04:38 beaglebone kernel: [21058.029750] R8188EU: indicate disassoc
Mar 28 23:04:38 beaglebone wpa_supplicant[925]: wlan0: Authentication with 00:18:0a:22:f9:46 timed out.
Mar 28 23:04:38 beaglebone wpa_supplicant[925]: ioctl[SIOCSIWAP]: Operation not permitted
Mar 28 23:04:38 beaglebone wpa_supplicant[925]: wlan0: CTRL-EVENT-DISCONNECTED bssid=00:18:0a:22:f9:46 reason=3 locally_generated=1
Mar 28 23:04:38 beaglebone connmand[899]: wlan0 {RX} 16337 packets 133390130 bytes
Mar 28 23:04:38 beaglebone connmand[899]: wlan0 {TX} 1315 packets 65718136 bytes
Mar 28 23:04:38 beaglebone connmand[899]: wlan0 {update} flags 36867
Mar 28 23:04:38 beaglebone connmand[899]: wlan0 {newlink} index 7 address 34:E8:94:DD:95:F9 mtu 1500
Mar 28 23:04:38 beaglebone connmand[899]: wlan0 {newlink} index 7 operstate 2
Mar 28 23:04:38 beaglebone wpa_supplicant[925]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: wlan0: Trying to associate with 0c:8d:db:18:0c:01 (SSID=‘CALnet’ freq=2412 MHz)
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: Failed to add supported operating classes IE
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: wlan0: Association request to the driver failed
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: wlan0: Associated with 00:18:0a:22:f9:46
Mar 28 23:04:40 beaglebone kernel: [21059.399212] R8188EU: assoc success
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {RX} 16337 packets 133390130 bytes
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {TX} 1315 packets 65718136 bytes
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {update} flags 102403 <UP,LOWER_UP>
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {newlink} index 7 address 34:E8:94:DD:95:F9 mtu 1500
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {newlink} index 7 operstate 5
Mar 28 23:04:40 beaglebone kernel: [21059.458065] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: wlan0: WPA: Key negotiation completed with 00:18:0a:22:f9:46 [PTK=CCMP GTK=TKIP]
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: wlan0: CTRL-EVENT-CONNECTED - Connection to 00:18:0a:22:f9:46 completed [id=0 id_str=]
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route fe80:: gw :: scope 0
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {RX} 16339 packets 133390500 bytes
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {TX} 1317 packets 65718424 bytes
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {update} flags 102467 <UP,RUNNING,LOWER_UP>
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {newlink} index 7 operstate 6
Mar 28 23:04:40 beaglebone wpa_supplicant[925]: bgscan simple: Failed to enable signal strength monitoring
Mar 28 23:04:40 beaglebone avahi-daemon[911]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.55.114.
Mar 28 23:04:40 beaglebone avahi-daemon[911]: New relevant interface wlan0.IPv4 for mDNS.
Mar 28 23:04:40 beaglebone avahi-daemon[911]: Registering new address record for 192.168.55.114 on wlan0.IPv4.
Mar 28 23:04:40 beaglebone dnsmasq[1280]: reading /etc/resolv.conf
Mar 28 23:04:40 beaglebone dnsmasq[1280]: using nameserver 8.8.8.8#53
Mar 28 23:04:40 beaglebone dnsmasq[1280]: using nameserver 8.8.4.4#53
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} address 192.168.55.114/24 label wlan0 family 2
Mar 28 23:04:40 beaglebone dnsmasq[1280]: no servers found in /etc/resolv.conf, will retry
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route 192.168.55.0 gw 0.0.0.0 scope 253
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route 192.168.55.1 gw 0.0.0.0 scope 253
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route 8.8.8.8 gw 192.168.55.1 scope 0
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route 8.8.4.4 gw 192.168.55.1 scope 0
Mar 28 23:04:40 beaglebone connmand[899]: wlan0 {add} route 0.0.0.0 gw 192.168.55.1 scope 0
Mar 28 23:04:41 beaglebone connmand[899]: ntp: adjust (slew): +0.230836 sec
Mar 28 23:04:41 beaglebone connmand[899]: wlan0 {add} route 212.227.81.55 gw 192.168.55.1 scope 0
Mar 28 23:04:41 beaglebone connmand[899]: wlan0 {del} route 212.227.81.55 gw 192.168.55.1 scope 0
Mar 28 23:04:41 beaglebone connmand[899]: ntp: adjust (slew): -0.008490 sec
Mar 28 23:04:41 beaglebone avahi-daemon[911]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::36e8:94ff:fedd:95f9.
Mar 28 23:04:41 beaglebone avahi-daemon[911]: New relevant interface wlan0.IPv6 for mDNS.
Mar 28 23:04:41 beaglebone avahi-daemon[911]: Registering new address record for fe80::36e8:94ff:fedd:95f9 on wlan0.*.
messsages
daemon.log
kern.log
debian@beaglebone:/var/log$ lsusb
Bus 001 Device 003: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
debian@beaglebone:/var/log$ uname -a
Linux beaglebone 4.19.94-ti-r41 #1buster SMP PREEMPT Sat Mar 21 03:13:40 UTC 2020 armv7l GNU/Linux
debian@beaglebone:/var/log$ cat /etc/dogtag
BeagleBoard.org Debian IoT Image 2020-03-26
Part of /boot/uEnv.txt
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
disable_uboot_overlay_adc=1
