Hey Robert,
I’m trying to get the latest Debian 10 snapshot to boot on the Beaglebone AI and it doesn’t seem to boot. When I boot with the serial connector to see what’s going on, it continually resets:
U-Boot 2022.04-ge0d31da5 (Aug 23 2022 - 19:11:21 +0000)
CPU : DRA752-GP ES2.0
Model: BeagleBoard.org BeagleBone AI
Board: BeagleBone AI REV A
DRAM: 1 GiB
Core: 60 devices, 16 uclasses, devicetree: separate
MMC: no pinctrl state for default mode
omap_hsmmc_init_setup: timedout waiting for cc2!
mmc@480d1000 - probe failed: -110
OMAP SD/MMC: 0, OMAP SD/MMC: 1no pinctrl state for default mode
Loading Environment from nowhere... OK
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@48484000
Press SPACE to abort autoboot in 1 seconds
switch to partitions #0, OK
mmc0 is current device
Partition Map for MMC device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 8192 1835008 3b958808-01 83 Boot
Scanning mmc device 0
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
1395 bytes read in 3 ms (454.1 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt ...
debug: [uname_r=4.19.94-ti-r73] ...
loading /boot/vmlinuz-4.19.94-ti-r73 ...
10170880 bytes read in 443 ms (21.9 MiB/s)
loading /boot/dtbs/4.19.94-ti-r73/am5729-beagleboneai.dtb ...
253052 bytes read in 17 ms (14.2 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
loading /boot/initrd.img-4.19.94-ti-r73 ...
7411241 bytes read in 325 ms (21.7 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:711629 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x9b3200 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f8ee000, end 8ffff629 ... OK
ERROR: reserving fdt memory region failed (addr=95700000 size=100000 flags=4)
ERROR: Failed to allocate 0x40c7c bytes below 0x90000000.
device tree - allocation error
FDT creation failed!
resetting ...
Any ideas?
Hi @pocketnc_john which image is doing that? (date stamp)…
So i see… with: am57xx-debian-10.13-console-armhf-2023-05-03-1gb.img.xz
DRAM: 1 GiB
BeagleBone Cape EEPROM: found EEPROM at address: 0x57
BeagleBone Cape EEPROM: debug part_number field:[BBORG_FAN�������]
BeagleBone Cape EEPROM: debug part_number field HEX:[42424f52475f46414e]
BeagleBone Cape EEPROM: debug version field HEX:[4130ffff]
BeagleBone Cape EEPROM: 0x57 BBORG_FAN-A000.dtbo
1 8192 1835008 a6b3a970-01 83 Boot
1395 bytes read in 4 ms (339.8 KiB/s)
10170880 bytes read in 440 ms (22 MiB/s)
253052 bytes read in 16 ms (15.1 MiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r73/overlays/BBORG_FAN-A000.dtbo ...
526 bytes read in 7 ms (73.2 KiB/s)
uboot_overlays: [uboot_detected_capes=BBORG_FAN,] ...
7411271 bytes read in 322 ms (21.9 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait uboot_detected_capes=BBORG_FAN, coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:711647 88000000] ...
Loading Ramdisk to 8f8ee000, end 8ffff647 ... OK
Loading Device Tree to 8f84d000, end 8f8edfff ... OK
Starting kernel ...
[ 0.003404] /cpus/cpu@0 missing clock-frequency property
[ 0.003428] /cpus/cpu@1 missing clock-frequency property
[ 0.568645] omap-mailbox 4a0f4000.mailbox: no available mbox devices found
[ 0.568716] omap-mailbox 4883a000.mailbox: no available mbox devices found
[ 0.568782] omap-mailbox 4883c000.mailbox: no available mbox devices found
[ 0.568847] omap-mailbox 4883e000.mailbox: no available mbox devices found
[ 0.569510] omap-mailbox 48844000.mailbox: no available mbox devices found
[ 0.569577] omap-mailbox 48846000.mailbox: no available mbox devices found
[ 0.569644] omap-mailbox 4885e000.mailbox: no available mbox devices found
[ 0.569709] omap-mailbox 48860000.mailbox: no available mbox devices found
[ 0.569773] omap-mailbox 48862000.mailbox: no available mbox devices found
[ 0.569867] omap-mailbox 48864000.mailbox: no available mbox devices found
[ 0.569932] omap-mailbox 48802000.mailbox: no available mbox devices found
[ 1.161605] sdhci-omap 4809c000.mmc: failed to set system capabilities
[ 1.168890] sdhci-omap 480b4000.mmc: failed to set system capabilities
[ 1.370968] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[ 1.451465] omap_voltage_late_init: Voltage driver support not added
[ 1.546456] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 1.553141] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 1.559815] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 1.651011] dwc3 48890000.usb: Failed to get clk 'ref': -2
[ 1.665742] OF: graph: no port node found in /ocp/ocp2scp@4a080000/phy@4a084000
[ 1.674097] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[ 1.703212] omapdss error: HDMI I2C Master Error
[ 2.752924] omapdss error: HDMI I2C Master Error
[ 4.718750] systemd[1]: System cannot boot: Missing /etc/machine-id and /etc is mounted read-only.
[ 4.727802] systemd[1]: Booting up is supported only when:
[ 4.733369] systemd[1]: 1) /etc/machine-id exists and is populated.
[ 4.739743] systemd[1]: 2) /etc/machine-id exists and is empty.
[ 4.745710] systemd[1]: 3) /etc/machine-id is missing and /etc is writable.
[ 10.178593] remoteproc remoteproc0: request_firmware failed: -2
[ 10.193660] remoteproc remoteproc1: request_firmware failed: -2
[ 10.208955] remoteproc remoteproc2: request_firmware failed: -2
[ 10.222779] remoteproc remoteproc3: request_firmware failed: -2
Debian GNU/Linux 10 beaglebone ttyS0
BeagleBoard.org Debian Buster Console Image 2023-05-03
Support: https://bbb.io/debian
default username:password is [debian:temppwd]
beaglebone login:
the ERROR: reserving fdt memory region failed (addr=95700000 size=100000 flags=4) is concering…
Ah…without the cape plugged in:
10170880 bytes read in 441 ms (22 MiB/s)
debug: [bootz 0x82000000 0x88080000:711647 0x88000000] ...
resetting ...
So your BBAI booted? Mine got into a reset loop and wouldn’t ever allow me to login.
Sorry, updated in mid post, when i have a cape installed, it boots okay’ish… but with no cape, it reboots… (All my bbai’s have a fan cape, so now to git bisect…)…
Ah, gotcha! Yeah, that’s the behavior I’m seeing. Thanks for looking into it!
Oh lovely! Bullseye version work’s… (same git source) U-Boot 2022.04-ge0d31da5 (Aug 23 2022 - 19:11:21 +0000)
DRAM: 1 GiB
1 8192 3678208 5f08c263-01 83 Boot
1368 bytes read in 3 ms (445.3 KiB/s)
debug: [uname_r=5.10.168-ti-r61] ...
loading /boot/vmlinuz-5.10.168-ti-r61 ...
10539520 bytes read in 456 ms (22 MiB/s)
loading /boot/dtbs/5.10.168-ti-r61/am5729-beagleboneai.dtb ...
344176 bytes read in 19 ms (17.3 MiB/s)
loading /boot/initrd.img-5.10.168-ti-r61 ...
6509902 bytes read in 283 ms (21.9 MiB/s)
debug: [bootz 0x82000000 0x88080000:63554e 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xa0d200 ]
Loading Ramdisk to 8f9ca000, end 8ffff54e ... OK
Loading Device Tree to 8f972000, end 8f9c906f ... OK
Starting kernel ...
[ 7.032684] reg-fixed-voltage fixedregulator-vtt: Failed to register regulator: -517
[ 11.103729] sdhci-omap 4809c000.mmc: failed to set system capabilities
[ 11.116119] sdhci-omap 480b4000.mmc: failed to set system capabilities
[ 11.167663] omap_voltage_late_init: Voltage driver support not added
[ 11.226074] reg-fixed-voltage fixedregulator-vtt: Failed to register regulator: -517
[ 11.361206] omapdss error: HDMI I2C Master Error
[ 11.425598] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@4000
[ 11.453063] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[ 11.459991] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[ 11.466461] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[ 11.473083] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[ 11.479492] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[ 11.485900] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[ 11.485900] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[ 11.485931] sdhci-omap 4809c000.mmc: no pinctrl state for hs mode
[ 11.485931] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[ 12.440917] omapdss error: HDMI I2C Master Error
[ 19.253356] remoteproc remoteproc2: request_firmware failed: -2
[ 19.260406] remoteproc remoteproc3: request_firmware failed: -2
[ 19.272949] remoteproc remoteproc0: request_firmware failed: -2
[ 19.279205] remoteproc remoteproc1: request_firmware failed: -2
[ 25.311920] vpe 489d0000.vpe: couldn't get firmware
Debian GNU/Linux 11 BeagleBone ttyS0
So let’s install 4.19.94-ti-r73 into bullseye to see if it’s kernel or u-boot build…
debian@BeagleBone:~$ sudo apt install linux-image-4.19.94-ti-r73
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 7 not upgraded.
Need to get 28.6 MB of archives.
After this operation, 49.0 MB of additional disk space will be used.
Get:1 http://repos.rcn-ee.com/debian bullseye/main armhf linux-image-4.19.94-ti-r73 armhf 1bullseye [28.6 MB]
Fetched 28.6 MB in 10s (2758 kB/s)
Selecting previously unselected package linux-image-4.19.94-ti-r73.
(Reading database ... 24490 files and directories currently installed.)
Preparing to unpack .../linux-image-4.19.94-ti-r73_1bullseye_armhf.deb ...
Unpacking linux-image-4.19.94-ti-r73 (1bullseye) ...
Setting up linux-image-4.19.94-ti-r73 (1bullseye) ...
update-initramfs: Generating /boot/initrd.img-4.19.94-ti-r73
zz-uenv_txt: Updating /boot/uEnv.txt [uname_r=4.19.94-ti-r73]
There we go:
DRAM: 1 GiB
1 8192 31108063 5f08c263-01 83 Boot
1367 bytes read in 3 ms (444.3 KiB/s)
10142208 bytes read in 440 ms (22 MiB/s)
6904302 bytes read in 300 ms (21.9 MiB/s)
debug: [bootz 0x82000000 0x88080000:6959ee 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x9ac200 ]
Loading Ramdisk to 8f96a000, end 8ffff9ee ... OK
resetting ...
DRAM: 1 GiB
v4.19.x includes cmem: #include "am57xx-cmem.dtsi"
voodoo@hestia:/opt/github/buildscripts/bb.org/4.19.x/BeagleBoard-DeviceTrees/src/arm$ cat ./am57xx-cmem.dtsi
/* https://git.yoctoproject.org/cgit/cgit.cgi/meta-ti/plain/recipes-kernel/linux/files/dra7xx/cmem-am5729-beagleboneai.dtsi?h=dunfell */
/* 0x0c000000 -> 0x18000000 for tild */
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
cmem_block_mem_0: cmem_block_mem@a0000000 {
reg = <0x0 0xa0000000 0x0 0x18000000>;
no-map;
status = "okay";
cmem_block_mem_1_ocmc3: cmem_block_mem@40500000 {
reg = <0x0 0x40500000 0x0 0x100000>;
no-map;
status = "okay";
cmem {
compatible = "ti,cmem";
#address-cells = <1>;
#size-cells = <0>;
#pool-size-cells = <2>;
status = "okay";
cmem_block_0: cmem_block@0 {
reg = <0>;
memory-region = <&cmem_block_mem_0>;
cmem-buf-pools = <1 0x0 0x18000000>;
cmem_block_1: cmem_block@1 {
reg = <1>;
memory-region = <&cmem_block_mem_1_ocmc3>;
This is needed for TI TIDL… which we never got working on v4.19.x… (only v4.14.x)… do we trash cmem, and get the memory back??
root@BeagleBone:~# uname -r ; free -h
4.19.94-ti-r73
total used free shared buff/cache available
Mem: 577Mi 51Mi 451Mi 4.0Mi 74Mi 509Mi
Swap: 0B 0B 0B
5.10.168-ti-r61
Mem: 989Mi 51Mi 867Mi 4.0Mi 70Mi 909Mi
Swap: 0B 0B 0B
Hi @pocketnc_john so the big question… this has been broken for over a year an no one noticed! (or reported)…
Do we drop cmem, and grab the memory back for something we can’t even use on v4.19.x?
I vote for that! I certainly don’t use TIDL. We don’t update our build scripts often, but it certainly seems like a good idea to get to the latest snapshot before looking into updating to Debian 11 or 12.
Okay, this looks better:
DRAM: 1 GiB
1369 bytes read in 3 ms (445.3 KiB/s)
debug: [uname_r=4.19.94-ti-r73.3] ...
loading /boot/vmlinuz-4.19.94-ti-r73.3 ...
10179072 bytes read in 441 ms (22 MiB/s)
loading /boot/dtbs/4.19.94-ti-r73.3/am5729-beagleboneai.dtb ...
252439 bytes read in 17 ms (14.2 MiB/s)
loading /boot/initrd.img-4.19.94-ti-r73.3 ...
6907694 bytes read in 301 ms (21.9 MiB/s)
debug: [bootz 0x82000000 0x88080000:69672e 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x9b5200 ]
Loading Ramdisk to 8f969000, end 8ffff72e ... OK
Loading Device Tree to 8f928000, end 8f968a16 ... OK
Starting kernel ...
test with:
wget -cO - https://git.beagleboard.org/RobertCNelson/ti-linux-kernel-dev/-/jobs/11796/artifacts/download > deploy.zip
unzip deploy.zip
sudo dpkg -i deploy/linux-image-4.19.94-ti-r73.3_1xross_armhf.deb
I’ll start a full build and have new images for July 1st…
Thanks Robert! I’ll probably wait and test the July 1st image. I appreciate you looking into this.
Hi @pocketnc_john please test: Index of /rootfs/snapshot/2023-06-27/buster-console-armhf these will be staged for July 1st, if they are good…
That one booted for me no problem. Thanks Robert!
One of the reasons I started looking into the latest BBAI image was because of another issue I was having with our older image and wanted to see if something may have gotten fixed in the latest console image. It seems to exhibit the same behavior, though. I started another thread for that issue here: Some microSD cards aren't readable on BBAI: mmc0: error -110 whilst initialising SD card
