Debian 11 supported kernel versions
Hello everyone,
I know Debian 11 images are running kernel v5.10.x-ti by default, would it be possible to replace it with v4.19.x-ti? I currently have some PRU interaction in the software, don’t want to break something by upgrading Linux kernel.
I can build the image myself, I just want to know if there’s any known incompatibility, things to consider, etc.
Hi @me21 this is no issue… Using…
Just run:
Disable auto kernel updates from 5.10.x-ti branch
sudo apt remove bbb.io-kernel-5.10-ti-am335x
Install and enable auto kernel updates from 4.19.x-ti branch
sudo apt install bbb.io-kernel-4.19-ti-am335x
sudo reboot
and you’ll be all set…
4.19.x-ti is the ‘oldest’ that gets active testing by me…
If you’re looking to enable PRU uio under the newer kernels, I’ve had great luck using this overlay:
https://github.com/mvduin/overlay-utils/blob/master/uio-pruss-5.4.dtsi
I was able to continue using my older PRU code with this overlay, and I’ve found the newer kernels to be much more stable.
Thank you. I use rpmsg.
