Debian 13 trixie SPIDEV and UART dtbo
I need help getting SPIDEV and UART dtbo overlays to function. I found under /opt directory sources to compile and install overlays. I compiled and installed them, got the SPIDEV0 and SPIDEV1. Then I enabled the overlays within uEnv.txt, but nothing happen.
I ran the beagle-version program, listed below. There are few things interesting in it, like: WARNING:pkg:[bb-cape-overlays]:[NOT_INSTALLED] but where is it? it is a pkg but apt cannot find it or install it. I see also this: uboot_overlay_options:[uboot_overlay=/boot/dtbs/6.15.10-bone26/BB-SPIDEV0-00A0.dtbo].
I’m so frustrated that I’m on the verge of giving up. Your assistance would be greatly appreciated.
eeprom:[A335BNLT000C1739BBBG1679]
dogtag:[BeagleBoard.org Debian Trixie Base Image 2025-08-26]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-ge543709d (Jun 27 2025 - 18:09:26 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot.dts]
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
kernel:[6.15.10-bone26]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay=/boot/dtbs/6.15.10-bone26/BB-UART1-00A0.dtbo]
uboot_overlay_options:[disable_uboot_overlay_video=1]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-customizations]:[1.20250808.0-0~trixie+20250808]
pkg:[bb-usb-gadgets]:[1.20250523.1-0~trixie+20250527]
pkg:[bb-wl18xx-firmware]:[1.20230703.0-0~trixie+20240703]
pkg:[kmod]:[34.2-2bbbio1~trixie+20250522]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20250410-2]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input render netdev i2c bluetooth gpio admin tisdk weston-launch]
cmdline:[console=ttyS0,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 rootwait fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100]
dmesg | grep remote
[ 14.645354] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ 33.487525] remoteproc remoteproc0: wkup_m3 is available
[ 35.980950] remoteproc remoteproc0: powering up wkup_m3
[ 36.037075] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 36.080689] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 49.681080] remoteproc remoteproc1: 4a334000.pru is available
[ 49.702859] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
dmesg | grep pinctrl-single
[ 4.372398] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
dmesg | grep wlcore
lsusb
lspci
pcilib: Cannot open /proc/bus/pci
lspci: Cannot find any working access method.
END
can you proved the serial boot log?
remove quite from uEnv.txt file
Thanks, amf99 for your respose.
It is not clear to me what are you asking for. Do you mean you want to see the last boot log as if I run **journalctl --boot=XXXXXXX?
What do you mean when you say *“remove quite from uEnv.txt file”?
connect a USB serial adapter, capture the serial log while booting the board.
as for “quite”, it seems that /boot/uEnv.txt does not have it on this image , but check anyway
if “quite” is at the end of
cmdline=fsck.repair=yes earlycon coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100
then remove it.
checked on
6.15.10-bone26 image
did the same, spidev are there
debian@BeagleBone:~$ ls /dev | grep spi
spidev0.0
spidev0.1
changes i did to uEnv.txt
###Overide capes with eeprom
#uboot_overlay_addr0=.dtbo
#uboot_overlay_addr1=.dtbo
#uboot_overlay_addr2=.dtbo
#uboot_overlay_addr3=.dtbo
###Additional custom capes
uboot_overlay_addr4=BB-SPIDEV0-00A0.dtbo
uboot_overlay_addr5=BB-UART1-00A0.dtbo
I appreciate your help, it is working now.
I am guessing that what I was doing wrong was that I provided the full path to the overlay? Any way, thanks amf99.
R
I am experiencing similar issues with a new Trixie install. I unfortunately cannot get the spidev0.0 or spidev0.1 nodes created after compiling the overlays and updating uEnv.
amf99, thanks for you input, especially as a sanity check that I am following the correct path. Just seem to be stuck without the spidev nodes being generated, not sure where to go from here.
which image did you use?
this is the one i tested on
am335x-debian-13-base-v6.15-armhf-2025-08-26-4gb
one other thing,
can you post your serial boot log. i.e. connect usb serial connector and post the first part where the .dtbo s are loaded.
