Hi Guys,
I need to recompile the debian 3.14 kernel but all the step by step guides I get all refer to 3.8.
Does anyone know of a proper guide to get the latests beaglebone supported kernel running on my beaglebone black?
Pieter
Hi Guys,
Pieter
git clone https://github.com/beagleboard/linux
cd linux
Look at the tag's: https://github.com/beagleboard/linux/tags
git checkout 3.14.34-ti-r53 -b tmp
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- bb.org_defconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig (to make changes)
make ARCH=arm KBUILD_DEBARCH=armhf LOCALVERSION=-ti-r53
CROSS_COMPILE=arm-linux-gnueabihf- KDEB_PKGVERSION=1cross deb-pkg
Copy *.deb to bbb, run: "sudo dpkg -i linux-image* ; sudo reboot"
Hi Robert.
Thanks for the guid. I have everything working up to the point where we compile the deb.
sudo make ARCH=arm KBUILD_DEBARCH=armhf LOCALVERSION=-ti-r53 CROSS_COMPILE=arm-linux-gnueabihf- KDEB_PKGVERSION=1cross deb-pkg
make: *** No rule to make target `deb-pkg’. Stop.
Any advice on whats missing in my configuration?
Pieter
Hi Robert.
compile the deb.sudo make ARCH=arm KBUILD_DEBARCH=armhf LOCALVERSION=-ti-r53
don't use sudo..
use "fakeroot" if you must..
make: *** No rule to make target `deb-pkg'. Stop.
Your probably in the wrong directory...
Reread my previous email.. If you've done every as specified,
pastebin.com your terminal log.
Hi Robert.
I followed your instructions and got to the point where I run “sudo dpkg -i linux-image*”.
Under /boot I see these files successfully unpacked:
root@beaglebone:/boot# ls
System.map-3.14.35ti-r55
initrd.img-3.14.35ti-r55
vmlinuz-3.14.35ti-r55
config-3.14.35ti-r55
initrd.img-3.8.13-bone47
dtbs
uboot
I run “cp /boot/initrd.img-3.14.35ti-r55 /boot/uboot/initrd.img-3.14.35ti-r55”
I edit /boot/uboot/uEnv.txt and set
initrd_file=initrd.img-3.14.35ti-r55
and reboot.
When I log in and run cat “/etc/dogtag” and “uname -r” I get:
root@beaglebone:/# cat /etc/dogtag
BeagleBoard.org BeagleBone Debian Image 2014-04-23
root@beaglebone:/# uname -r
3.8.13-bone47
I’t does seem like the kernel did not update to 3.14.
when I run : “update-initramfs -c -k $(uname -r)” it builds initrd.img-3.8.13-bone47
when I run : “update-initramfs -u” it builds initrd.img-3.14.35ti-r55
Is there anything else I need to do that I might be missing?
Pieter
If your going to use v3.14.x just upgrade first:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#2015-03-01
Then lots of things will just work..
