Working with a Telit LE910 Cell Module and am trying to get a driver working for usb connection.
I am following the guide provided by Telit
I have loaded the kernel headers and such so that I can see
usr/src/linux-headers-3.8.13-bone70/drivers/usb/serial# ls
ezusb_convert.pl Kconfig Makefile Makefile-keyspan_pda_f
Did so by doing
apt-cache search linux-headers-3.8.13-bone70 apt-get install linux-headers-3.8.13-bone70
My issues is the guide is asking my to looking in /drivers/usb/serial/option.c
I cannot find option.c ??
https://github.com/beagleboard/linux/blob/3.8/drivers/usb/serial/option.c
It's not a header, so you won't find it in "linux-headers-3.8.13-bone70"
Thanks for the clarification Rpbert
What is the proper way to 'retrieve the appropriate kernel source code…" for 3.18.3-bone70?
git clone https://github.com/RobertCNelson/linux-stable-rcn-ee
cd ./linux-stable-rcn-ee
git checkout `uname -r` -b tmp
or if you have an existing linus clone:
git clone --reference <dir_to_linux_git>
uname -r = 3.18.3-bone70 or whatever version...
Thanks Robert.
I found the file and everything seams legit. The real issue I was trying to solve was that when plugging this device in to the USB input I was not getting the corresponding /dev/USBX’s.
After doing a
modprobe option echo 1bc7 1201 > /sys/bus/usb-serial/drivers/option1/new_id
I now see my /dev/USB1 thru /dev/USB6
Why do I have to do these manual commands? I guess I can scripts these on boot but is there a better option.
Kind Regards,
Matt
Yes I could but I have a custom device tree written to work in the old world of 3.18.3 Is there a simple way to port that into 4.1.13.ti.r35 ?
There is no porting. You simply compile it with the proper device tree version. Which is different from the version used for 3.8.x.
http://www.embeddedhobbyist.com/2015/09/beaglebone-black-updating-device-tree-files/
Anyway, if you apt-get install linux-image, and it ends up not working for you, simply change the uname-r variable in /boot/uEnv.txt ( to point to your 3.8.x kernel ). And problem solved. After that, an apt-get remove --purge should get rid of all traces of the newer 4.1.x kernel. IF that’s what you want.
Yeap, two options, install 4.1.13.ti.r35
Then use the dtb-rebuilder to build your matching *.dtb and boot with it:
https://github.com/RobertCNelson/dtb-rebuilder/tree/4.1-ti
or use the bb.org-overlays to build a custom *.dtbo overlay
https://github.com/beagleboard/bb.org-overlays
the biggest delta is gpio #'ing but the rest we can help with..
OK so I upgraded to 4.1.13.ti.r35
How do I use this rebuilder?
Just to confirm I have a custom .dtbo name BB-APA-01 that loaded on boot where I had it baked into the kernel. I did not add it uEnv.txt but it still loaded.
Here is what I tried to get cape loaded:
root@mmpTestBox:~# dmesg | grep BB-APA
[ 0.000000] Kernel command line: console=ttyO0,115200n8 capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN capemgr.enable_partno=BB-APA-01 root=UUID=38808bbf-7f2e-469d-8ff6-e5eec3303fc9 ro rootfstype=ext4 rootwait fixrtc quiet init=/lib/systemd/systemd
root@mmpTestBox:~# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
root@mmpTestBox:~# sh -c “echo ‘BB-APA-01’ > /sys/devices/platform/bone_capemgr/slots”
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
root@mmpTestBox:~# dmesg | grep BB-APA-01
[ 224.000061] bone_capemgr bone_capemgr: part_number ‘BB-APA-01’, version ‘N/A’
[ 224.000251] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00A0,Override Manuf,BB-APA-01’
So I was able to to get the custom dtbo loaded after recompiling it with:
dtc -O dtb -o BB-APA-01-00A0.dtbo -b 0 -@ BB-APA-02-00A0.dts
Did the UARTS get renamed? I also had to remove this from the dts to get it to comiple:
fragment@4 { target = <&uart6>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&uart5_pins>; status = "okay"; }; };
Doesn’t seam to be loading on boot despite having entered it in /boot/uEnv.txt:
cape_enable=capemgr.enable_partno=BB-APA-01
I can manually load it:
root@mmpTestBox:/sys/class/gpio# cat /sys/devices/platform/bone_capemgr/slots 0: PF---- -1 1: PF---- -1 2: PF---- -1 3: PF---- -1 root@mmpTestBox:/sys/class/gpio# sh -c "echo 'BB-APA-01' > /sys/devices/platform/bone_capemgr/slots" root@mmpTestBox:/sys/class/gpio# cat /sys/devices/platform/bone_capemgr/slots 0: PF---- -1 1: PF---- -1 2: PF---- -1 3: PF---- -1 4: P-O-L- 0 Override Board Name,00A0,Override Manuf,BB-APA-01
After manually loading it:
Now I have an issued with ADC.setup() from the adafruit library. Wasn’t an issue before I update:
/powerMGMT.py", line 46, in shorePowerCheck
ADC.setup()
RuntimeError: Unable to setup ADC system. Possible causes are:
A cape with a conflicting pin mapping is loaded
A device tree object is loaded that uses the same name for a fragment: helper
Any ideas?
to comiple:
fragment@4 {
target = <&uart6>;
__overlay__ {
status = "okay";
Yeap:
* Free up the pins used by the cape from the pinmux helpers.
fragment@1 {
target = <&ocp>;
__overlay__ {
P8_37_pinmux { status = "disabled"; }; /* uart5_txd */
P8_38_pinmux { status = "disabled"; }; /* uart5_rxd */
fragment@2 {
target = <&am33xx_pinmux>;
__overlay__ {
bb_uart5_pins: pinmux_bb_uart5_pins {
pinctrl-single,pins = <
BONE_P8_37 (PIN_OUTPUT | MUX_MODE4) // lcd_data8.uart5_txd
BONE_P8_38 (PIN_INPUT | MUX_MODE4) // lcd_data9.uart5_rxd
Doesn't seam to be loading on boot despite having entered it in
/boot/uEnv.txt:
cape_enable=bone_capemgr.enable_partno=BB-APA-01
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
Now I have an issued with ADC.setup() from the adafruit library. Wasn't an
ADC.setup()
- A cape with a conflicting pin mapping is loaded
- A device tree object is loaded that uses the same name for a fragment:
helper
There's a patch in this thread:
opened 10:02PM - 07 May 15 UTC
closed 02:44AM - 19 Oct 16 UTC
linux repo: https://github.com/beagleboard/linux/tree/4.1
overlay repo: https://… github.com/beagleboard/bb.org-overlays
slots:
enable/disable cmdline:
bone_capemgr.disable_partno=
uart:
target = <&uart(X)>; = target = <&uart(X-1)>;
edit 1: module name: beaglebone_capemgr -> bone_capemgr
How do I apply this patch?
Thanks that worked to adafruit library working.
Still having an issues getting the device tree to load on boot.
Is there a better way to do this than in /boot/uEnv.txt ? I have this line in there now but it does not seam to do the job as I do not see the overlay loaded after boot in …/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
root@mmpTestBox:/sys/class/gpio# sh -c “echo ‘BB-APA-01’ > /sys/devices/platform/bone_capemgr/slots”
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
I believe in the old kernel 3.8.x I fuound a way to bake the overlay kernel. Is this possible in 4.1.x?
The trick is in the "bb-customizations" package:
Encase you don't have it installed:
https://github.com/rcn-ee/repos/blob/master/bb-bb-customizations/suite/jessie/debian/dtbo
if [ ! -x /usr/share/initramfs-tools/hooks/dtbo ] ; then
sudo chmod +x /usr/share/initramfs-tools/hooks/dtbo
fi
then just:
sudo update-initramfs -u -k $(uname -r)
and it'll be in your initrd.
Thanks for bearing with me here.
I did a wget https://github.com/rcn-ee/repos/blob/master/bb-bb-customizations/suite/jessie/debian/dtbo
Now do I add this to the file?
if [ ! -x /usr/share/initramfs-tools/ hooks/dtbo ] ; then sudo chmod +x /usr/share/initramfs-tools/hooks/dtbo fi
and then
Just to confirm my BB-APA-01-00A0.dtbo is in /lib/firmware and loads manually.
I can see that usr/share/initramfs-tools/hooks/dtbo file matches what you have in the repo
That’s bash script programmer speak for making that file executable, if it’s not already
In other words. if the file */usr/share/initramfs-tools/hooks/dtbo *is not already executable run chmod +x on it. OR You could create a bash script, drop that code into it. Make the script executable, then run it. And it’d do it for you. Pick your poison.
