Hello there,
we just recently got a new batch of bbb with debian 8.3 pre installed.
So we wanted to update our older bbb to 8.3 too - so we tried with the image provided by: http://beagleboard.org/latest-images and nearly anything on here: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#2014-12-11 - no success.
We can’t get a connection via usb, we can see the usb folders, but can’t access via ssh (like this guy here https://groups.google.com/forum/embed/?place=forum/beagleboard&showsearch=true&showpopout=true&showtabs=true&hideforumtitle=true&parenturl=http%3A%2F%2Fbeagleboard.org%2FCommunity%2FForums#!category-topic/beagleboard/beaglebone-black/qlnIUmAiP54)
Using ethernet is no option here, as our network policy doesn’t allow network access.
Is there a working image out there? Can we somehow get the image which was preinstalled on the bbb?
Lukas
Did you try: 2016-03-20?
it was only uploaded a few days ago on sunday...
on your pc, what does:
sudo ifconfig -a
show, when the bbb is plugged in?
I think i already tried it - at least the download link is purple.
ifconfig-a displays:
eth1 Link encap:Ethernet Hardware Adresse 54:4a:16:ca:aa:de
inet6-Adresse: fe80::564a:16ff:feca:aade/64 Gültigkeitsbereich:Verbindung
UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1
RX-Pakete:43 Fehler:3 Verloren:0 Überläufe:0 Fenster:3
TX-Pakete:2 Fehler:0 Verloren:0 Überläufe:0 Träger:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX-Bytes:10573 (10.5 KB) TX-Bytes:268 (268.0 B)
thanks for your help,
regards,
lukas
do you get an ip when you do:
sudo dhclient eth1
Otherwise, please fire up gtkterm:
gtkterm -p /dev/ttyACM0 -s 115200
and run:
journalctl -f
while running:
sudo dhclient eth1
on your pc, we should see the DHCP server fireing up..
So i installed gtkterm and ran it with the provided command… than in another terminal I executed dhclient eth1 - was this what you wanted me to do?
Nothing happened.
lukas
So when you fire up gtkterm, you should have a serial connection into
the bbb. if you hit enter it should ask you for the user, just type
root <enter>
in the bbb: fire up:
journalctl -f
then on your pc:
sudo dhclient eth1
you should see a bunch of log messages from "journalctl -f" on what's
going on inside the bbb.
Sry for my late response
I tried but couldn’t get a response from the bbb - as it seemed I was the only one having this problem, so I reinstalled once again (using debian console edition) and everything worked as expected
So perhaps there was sth. wrong with the image I downloaded or the creation of the bootable sdcard.
But there is something I don’t understand with the console edition:
If I restart a service via:
/etc/init.d/ssh restart
i get a response in form of:
[ ok ] Restarting ssh (via systemctl): ssh.service.
but when using “service ssh restart” I don’t get any response.
Probably just a missing package?
lukas
