Hi.
I have an old BB Black (from 2016 IIRC).
It shows:
root@bbb:~# cat /etc/issue
Debian GNU/Linux 8 \n \l
BeagleBoard.org Debian Image 2016-01-31
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
The IP Address for usb0 is: 192.168.7.2
root@bbb:~# apt update
Ign http://security.debian.org jessie/updates InRelease
Ign http://security.debian.org jessie/updates Release.gpg
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
root@bbb:~# apt-get install apt-transport-https
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
apt-transport-https
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 135 kB of archives.
After this operation, 170 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
apt-transport-https
Install these packages without verification? [y/N] y
Err http://security.debian.org/ jessie/updates/main apt-transport-https armhf 1.0.9.8.6
404 Not Found [IP: 2a04:4e42:600::644 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/a/apt/apt-transport-https_1.0.9.8.6_armhf.deb 404 Not Found [IP: 2a04:4e42:600::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
--fix-missing doesn’t help either.
What can I do more?
… later …
Checking here here I can see that apt-transport-https_1.0.9.8.6_armhf.deb does not exist anymore.
Shall I try apt-transport-https_1.8.2.2_all.deb ?
